External usb hard drive problem
I have been using a Western Digital WD3200JB hard drive in a usb enclosure for some time without problems. (under linux) recently the usb device is not seen by the OS. Tried to use it under WindowsXP, this says that the usb device has a problem. What may have gone wrong? What can I do to fault find and maybe fix
  • 1 more comment
  • Hartog Jan 09, 2008
    Thank you.
    The computer in question is a notebook and I am not game to rip that open for this. I have an old windows machine that I already have some extra drives in. I connected the drive to the secondary IDE. It was recognised as WD3200JB etc but there seemed to be something with the master/slave situation. And it could not determine the number of heads etc. It is an old machine/motherboard that may not be able to cope with this model?
    About the motherboard:
    AOpen AX6DC R2.41 with 500Mhz Pentium III
    Award BIOS 4.60PGMA
    I have a feeling that 320Gb for the disk is outside its limits.
    Sorry, not AX6DC but AX6Bc
    Scholar:
  • 135 Answers
Can you try connecting the hard drive to the computer without the enclosure? This will enable us to see whether the enclosure is causing the problem. Since you're using linux, I assume you know how to open your PC and connect the IDE\SATA cable to the hard drive.
Posted on Jan 09, 2008
  • 1 more comment
  • Yonatan Horan Jan 09, 2008
    It might be, but it's highly unlikely. If you can give me the motherboard model I could try and see. Did you try playing around with the jumper? (changing from master to slave to cable select while also changing the settings on the other drives). I'd try and disconnect all other drives, connect just this one as master and see if it's recognized properly. If it is, then the problem is with your enclosure and if it isn't, you'll likely have to RMA your hard drive.
    Erm... sorry, when you disconnect all other drives you need to connect this one as single, not master, so follow the jumper instructions on your hard drive to change it to single.
  • Yonatan Horan Jan 10, 2008
    It's very likely that the motherboard doesn't support it. In order to check if the enclosure is the problem, try putting a different hard drive in it and seeing if it functions okay. If it doesn't, you probably need a new enclosure. Also, try changing the USB cable with another one you have (if you have another one, that is) and connecting the enclosure to a different USB port on your computer.
Western Digital Hard Drive Help Needed
Hi, The drive you are connecting to this USB enclosure can be set up as an auto select, master, or slave drive by changing the jumpers. Suggest to check your USB enclosure manual to see what is required for this device as to the configuration of the drive jumpers. Regards, Rongg
Mar 29, 2014 | Western Digital Computers & Internet
Using Western Digital Hard Drive as External Hard Drive Problems
OK! First of all try to disconnect all usb's from neighbouring usb ports as they might be using up too much current resulting in your HD not having enough power to be powered up properly! Also, try to use a different usb port.
If all these fail, please use a voltmeter (if any available...) to check if your devices actually function...
Hope this helps! If not, please report back!
I have a Western Digital external hard drive. It just sits there and suddenly I cannot find it in Windows Explorer. It does show up under Device Manager, and I have uninstalled/reinstalled the drivers,...
Welcome to Fixya
Try to plug it in to a different computer. If you are getting the same thing using a different computer then its gonna be the enclosure or the HD is having the problem. One way to check is to use an extra HD and put it inside the enclosure. If the enclosure was able to detect the new HD then its gonna be you HD that is having the problem. If enclosure still cant detect the HD then the problem is the enclosure.
Please let me know if you need further assistance.
Thank you for using Fixya!
Apr 19, 2011 | Western Digital 320GB MyBook External USB...
Western Digital External USB 2.0 Drive sometimes won't connect
problems like these are usually because of the usb connections, if the usb connection isnt strong enough i.e getting enough power,
try it on another pc if you can see if the problem persists
Sep 09, 2009 | Western Digital USB 2.0 External Enclosure...
WD 500gb external HD shuts down when plugged into USB port
Try a replacement USB cable first. If that does not fix the problem, then the USB to SATA adapter board is faulty, in that case you will need to take out the internal disk to replace the external enclosure.
see
YouTube - How To: Take Apart A Western Digital My Book Enclosure
If unit is under warranty see : WD Support > Warranty Services > End User > Warranty Policy.
Note any SATA external enclosure willl work wthe same with the internal WD HD.
Apr 17, 2009 | Western Digital My Book Home Edition 500...
How do I Recover data from an old hard drive
This may sound silly, but does the external enclosure have power? You may have neglected to connect the required power adapter, or it may not be working properly. You might also have a problem with the enclosure's internal power or data cables. They are sometimes pretty flimsy, and sometimes they can go bad.
There's also the chance the drive itself is bad and isn't being detected as a result. Or the interface board in the external enclosure may have failed, and the drive is OK but the computer doesn't see it. If you are connecting to a desktop PC, you can try connecting the drive directly to the main board using an IDE cable and try accessing it that way. Just be sure to set the master/slave jumper accordingly if you do that.
Feb 07, 2009 | Western Digital USB 2.0 External Enclosure...
Cannot see a drive letter
You look like a dodgy character! Not personal!
Jul 30, 2008 | Western Digital USB 2.0 External Enclosure...
Computers & Internet Logo
245 people viewed this question
David Payne
David Payne
