Question about Belkin (F5D72304F5D7000) Router
Need to reset my address on my belkins some how it got changed and I cant seem to get it changed back. See what happened is we moved then when we hooked up it said my dns needed done then it still wouldn't work if I hooked up belkins without belkins works fine. So I went in and look and the iep isn't the normal 192.168.2.1 instead it was reset to another number.
  • 1 more comment
  • psumstead Nov 15, 2009
    I actual did this before I posted the comment but only held it in for 3 secnds. did it for 10 and problem solved. of course now I have to figure out why I have internet when the router isn't hooked up but can't connect once I hook it up.
    Problem Solver:
  • 10 Answers
There should be a small pinhole button on the router. hold the button in for 3-5 seconds 10 would be safe.
Posted on Nov 15, 2009
Hello, i wonder if anyone can help me.. i was given a router today i set it up and it was working perfectly. When i turned my xbox360 on and went on to a game and it said my NAT was moderate. so i tried to...
For resetting the router You have reset key on the back of the router, press and hold the reset key with any sharp objects like toothpick or a paper clip for 35 sec(or more) From the xbox you have to manually enter the ip address
Configuring port forwarding In order to configure this, you need to know:
- The IP address of the computer or device to have the port forwarded to.
- The port numbers to be used and whether these are TCP or UDP ports
(Note: We recommend you use a computer that has a wired connection to the router.)
Oct 04, 2010 | Belkin (F5D7230-4) Router (587009)
On belkin surf router clicked on set as access point. then i tried to change it but my computer cant get internet from the router so i cant access the belkin homepage. can u help
the only thing you need to do is reset your router to go the IP address original 192.168.2.1
because when you setup it as a access point the router change the Ip Address.
restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on theback of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
do this for 3 times and you will acces your router.
Good luck
Please rate me techbelkin
Aug 02, 2010 | Belkin Wireless Surf Router (F7D2301)
How can i secure a BELKIN WIRELESS G ROUTER
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Apr 09, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin wireless G router incompatible with netgear modem
connect your computer to netgear modem alone and check for the ip address in the computer
(make sure that you have selected "assign ip automatically" in computer)...
to open command prompt type "cmd" and hit enter in run box...
then you can check ip address by typing "ipconfig" in command prompt...
make a note of IP adress or ipV4 address found under the heading "ethernet adapter local area connection"
it might be 192.168.X.X
now connect only the belkinrouter and check for the ip address using the same steps above...
it might be 192.168.2.X
make a note of that...
now compare both the ip addresses if they both have the same value in first three places...that is
192.168.2.... or something like 192.168.1.... or 192.168.0.... then you are facing with double NAT issue...
all that you need to do for that is to change the ip address of belkin router...
if it is 192.168.2.1 change into something like 192.168.15.1...the issue will get resolved....if not you can reset the belkin
router by pressing and holding the reset button for 30 seconds using a toothpick when the power is turned on...
Apr 02, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cant get into the settings of my belkin router http 192 168 2 1
Step 1 : Check the IP Address of the Computer
Step 2 : If it is in the Range of the Router ( 192.168.2.x)
Step 3 : Try typing 192.168.2.1 on the address bar of internet explorer
Step 4 : If not working Hard reset the router by inserting a paper clip into the reset hole on the back of the router
Step 5 : If the IP Address is any public address or 169.254.x.x then also do step 4
Jan 10, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin g plus mimo nat problem
Step 1 : Check the IP Addressof the Xbox And take a note of it
Step 2 : Open RSP By typing 192.168.2.1 on the Address bar of the internet explorer
Step 3 : On the left side Click Firewall
Step 4 : Leave the Password blank and click Submit
Step 5 : Disable it And Apply Changes
Step 6 : On the left side Under Firewall Click DMZ
Step 7 : Add the IP Address of the XboX in DMZ
Step 8 : Click Apply Changes
Step 9 : Restart the Router
Step 10 : Test the Connection
Apr 12, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin wrong ip address
You may mean that it is not giving the right address to your computer. Try pressing the reset button for about 20 seconds then unplug the power wait for about 15 seconds then plug the power back in then restart your computer.
If you need further help just message back.
Nov 26, 2008 | Belkin (F5D7230-4) Router (587009)
Can not access ip address
Did you try to unplug the power for 30 seconds and plugging it back? you can also bring the router back to factory settings... usually that's accomplished by having the power cord removed, holding the reset button in WHILE plugging the power cord back into the router. Keep the reset button pushed in for atleast 30 seconds! Now you should be able to access the admin page. Keep in mind, any time you move an ethernet (network) cable from the cable modem to the device (pc/laptop/router), you have to unplug the power and plug back again 30 seconds later.
Jun 15, 2008 | Belkin (F5D7230-4) Router (587009)
Change password
There is a small button on your router. Press it in and hold it until your lights flash on it. It will take about 45 seconds.
This is a factory reset. Now you can connect to it either by plugging into it or wirelessly. It will be an unsecure access point with the SSID of belkin.
After you connect just open up your favorite browser (I use Firefox) and type in the address http://192.168.0.1
Change your password, choose a wireless SSID that is better than belkin. Set your security ( I prefer WPA/PSK )
Save your settings.
Jun 12, 2008 | Belkin (F5D7230-4) Router (587009)
IP address
Hi tammyhope,
I would guess that your ISP is providing a dynamic IP address for connectivity to the internet. If your router is changing the IP address back to default, I would think that your configuration is not setup properly, to receive a dynamic address, but is set with a static address instead. So what happens is that when you attempt to connect to your ISP your router is resetting. If this is the case then you need to go into the router configuration and set it to recieve a dynamic address from your ISP.
--RoadHawk
Nov 25, 2007 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D72304F5D7000) Router Logo
75 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
