Question about InFocus LP70+ Multimedia Projector
Where can I get an infocus projector repaired in
My infocua Lp755 projector won't show video it just stopped working it still projects the set up image but won't switch to video I think that a high V signal was applied to it is it self fixable or where in Australia can I get it fixed?
  • 2,237 Answers
Reset the settings to factory default. if that doesn't work, you may need to have the eca controller (main board) replaced. unfortunately, infocus no longer carries parts for that model anymore.
Posted on Dec 04, 2009
  • electro Apr 03, 2011
    you can get fixed alone if you know your way around electronics...
How do I correct a multiple image?
is the internal lens between the lamp an lcd cracked?
many do in that model.
May 10, 2015 | InFocus Lp755 LCD Projector
I got a projector infocus LP755 the standby lights
It might be over-heating. Make sure the unit is not clogged with dust.
Sep 16, 2014 | Office Equipment & Supplies
Infocus lp425z projector pushes latop display to left quarter of output image
Usually this is a hardware acceleration setting problem on the 'advanced' properties setting in your 'screen resolution' properties on your computer. Re-set the hardware acceleration to the 2nd setting and this should fix your issue. We have this regularly when we project on a double projector system and the one projector keeps shifting everything left until we adjust the hardware acceleration settings on the computer. No more issue.
Mar 11, 2013 | InFocus SOFTCASE, LP425Z Multimedia...
How to factory reset an infocus lp755
Just about anything electronic can be reset by pullilng the "power" or it has a reset button "somewhere."
Aug 27, 2012 | InFocus LP70+ Multimedia Projector
Turning it back to normal after ceiling mount for LP755
hi,
1. perss menu button
2. select controls
3. then select ceiling projecton (When you turn Ceiling Projection on, the projector turns the image upside down for ceiling-mounted projection. Highlight Ceiling Projection, then click either button to select turn this feature on and off.)
ok
Dec 21, 2010 | InFocus LP 755 Multimedia Projector
My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no signal....help
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    My projector has stopped projecting RED (snooker balls green). The lamp has only done 750hrs. I have tried to adjust in the system settings to no avail. Anyone know the problem?
    you have a bad colorwheel that probably lost the part of the lens. you can get the part from an infocus service center and do it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
    Jan 17, 2010 | InFocus ScreenPlay 5700 Multimedia...
    Infocus lp640 lcd projector
    check vga cable(cable between computer and projector)-try fn key with combination of f4orf5 orf6 or f7 or f8-confirm that input source assigned to pc.
    Jul 08, 2008 | InFocus Office Equipment & Supplies
    InFocus LP70+ Multimedia Projector Logo
    130 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
