Question about Fisher Washing Machines
My GW612 washer leaves pockets of dirt in my cloths
  • 585 Answers
Any time that happens it is usually because the machine was overloaded to the point where the clothes do not get properly circulated in the wash. Try not stuffing it too tightly.
Posted on Nov 15, 2009
Fisher & Paykel GW612 won't spin
you want to check the drain pump if there is nothing stuck there sometimes a drain restriction will cause the machine to stop
Jan 27, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Ken more washer leaves dirty marks on clothes
Pull the agitator out and clean the inside of it and the area of the tub that it covers. A buildup of crud won't be removed by simply washing out the machine. Rinsing out a frying pan will get a lot of the dirt out but, it must be properly washed to get it all.
Jan 20, 2013 | Washing Machines
My 4 year old roper washer leaves grease on clothes. On spin cycle the machine makes a screaching noise, and the clothes don't spin dry.
Possible that the belt is slipping and also there is some issue with the agitator as the gaps within seems to bring up the dirt or grease mix to the clothes.
So it is important to remove the panel and check the play on the belt, replace if the play is high and check if the agitator bearings are worn out. If so the agitator assembly must be taken out and checked.
Dec 09, 2011 | Washing Machines
Lg washer leaving black greasy marks on clothes
This is usually to do with fabric softener. Dilute it with more water. The fabric softener makes clots, and these make the marks on your clothing.
Hope it helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM2077CW XL Front Load Stackable Washer...
Washer is leaving dirty spots on clothes
If you use fabric softener it may be from the softener. Dilute your softener 50% before pouring it in.
Sep 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
The dryer dispels sand and dirt after each cycle- I think it needs to be cleaned?
do you see marks on your clothing if not the problem may not be with the dryer but the washer. do you live in a sandy area? with kids check the pockets of item before washing generally not a very good chance of dirt or sand coming from the dryer
Aug 19, 2009 | Frigidaire Dryers
Dirt left in creases after washing clothes. Clothes never look clean
Too many clothes in the load , if it says 5lb then that is the maximum you should fill it with otherwise the clothes do not seperate as they are being agitated
Also
Not enough detergent (Try the old powder types)
Hard Water area (Use a small amount of Washing Soda)
Water level too low , use add water button if fitted
May 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
My Whirlpool Calypso top loading washer (purchased in June of 2002) is starting to leave brown or dirt colored marks on clothing and sheets (I think they are permanent!) - I don't see any obvious place...
Run the washer empty with vinegar on the hottest, longest cycle. Usually this is caused from fabric softener and liquid detergent build up. Use powder detergent only and don't use cold water to wash in all the time. Only use cold water for your bright, finer cloths. Cold water use causes detergent build up.
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Bosch Washer
You know, Dealers would tell you any thing just to sound clever.
it needs a service,The reson being,on the back of the drum and under the drum you get bearings, i think 3 of them,they r filld with grease.Just take if for a service or if you can do it ur self,after that you can clean that door rubber with petrol, YES Petrol :).
Hope this helps you...
Sep 08, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
105 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
