Question about Frigidaire GLTF2940ES Front Load Washer
Same problem. Stinky, moldy, gunky. Clothes won't clean.
Same problem. Stinky, moldy, gunky all around the opening, inside the lip of the rubber seal. i am washing clothes twice. how's that for efficient? i am very discouraged - laundry is a pain but it should at least result in clean clothes. i wish Frigidaire would stand by their product.
  • 77 Answers
First take a gallon o bleach pour it in on hot and run,then from know on after washing leave the door open so it can dry out and not mold between loads.
Posted on Nov 15, 2009
Moldy smell in clothes, especially towels
need to clean the bellow ( rubber around door). theres a tablet you can buy called "Affresh". It will help to remove the moldy smell. just throw it in washer and run through a regular wash cycle. no clothes, just the tablet. If there is a clean cycle on the machine then use that cycle. Whenever you're finished washing, you should leave the door open for about 20-30 minutes so unit can air out. Also you should wipe around the glass and bellow after each use.
Mar 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a front loading washer - have had for 8 years or so. Began smelling moldy smell - noted little stuff around the holes in the rubber seal around the door. Then I began to pull it back and found mold...
you need to wipe down that part of boot seal after every wash,tide has tablets that you stick in the washing machine and run it through and it removes the smell but it will come back if you don't wipe it down.also if you are using to much detergent that will make it stinky and eat the spider gear and if that happens it's new washer time,you hear a loud banging noise when it's in spin.call your local appliance store and ask them for the pack of tablets,it's like washer magic or something like that,good luck.let me know how you make out
Aug 26, 2010 | Kenmore Washing Machines
What does de mean on the display of the washing machine? Yesterday I ran a tub clean because my clothes have been smelling moldy. I have cleaned the rubber seal & leave the door open. Please help??
de means your door isn't closed completely.
The moldy smell is really common with this machine, and maybe all of them, but I have the LG TROMM and was ready to throw away all of my towels. Here's a solution I found that helped alot. First, Clorox makes a solution just for front-end loading machines. You run it through on a cycle with no clothes, that helps to clean it out.
I ran my towels through on the cotton/towel cycle on HOT, with nothing more than white vinegar filling the detergent dispenser. After that, I then ran them through again with just a bit of soap and fabric softener. They came out soft and smelling like new.
I read recently that we all use WAY too much soap in both our washers and dishwashers, even though that's what's recommended in the directions. Excess soap in clothes that doesn't get rinsed out will begin to smell moldy. So I now use about 1/4 of what the directions call for, and they come out fine. I have found, however, that I need to repeat the vinegar cycle once every few months. I think the problem is inherent in that model machine.
And that rubber seal? Disgusting! I clean it out regularly, but when it's full of water after every load of clothes, what do they think is going to happen??? You'll find that Clorox cycle will clean the seal pretty well, though. Good luck!
Apr 03, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have an LG washer that smells like rotten clothes. My clothes come out smelling real bad. I checked inside and noticed that the rubber seal around the door is holding moldy rotton gunk. It's not self...
Run a cup each of baking soda and vineger thru a hot wash. Might have to do this a couple of time if smell really bad.
Take out the unit where the liquid soap, softner, etc goes and clean by hand.
Soak a cloth in vinegar and clean the inside of the rubber around the tub.
And finally DO NOT LEAVE THE DOOR CLOSED IF NOT IN USE.
Oct 31, 2009 | LG WM2688HWM TROMM SteamWasher
Our front-loading HE washing machine delivers
try putting in 2 caps of a citrus or pine bleech straight in to the drum with some old rags. then select a boil wash. the rags will spray the water around the tub, the bleech will clean the tub and make it smell fresh. DON'T put any clothing in whilst doing this. if you are worried about bleech in the machine just select a rinse cycle after. i do this once every 3 months
Aug 05, 2009 | Maytag MAH2400A Front Load Washer
Is there a way to clean rubber seal around the opening?
Use a vinagar solution to clean the rubber seal. bleach will damage the rubber.
Apr 29, 2009 | Washing Machines
Large rubber door seal came apart
Yes it can be put back on without taking the drum apart. The larger end goes on the drum side. Fit larger end around drum lip make sure it seals all the way around, install spring around seal. Smaller end goes around door opening. Install seal around outter lip and install spring around seal.
Mar 05, 2009 | Kenmore 44102 Front Load Washer
Mold & Smelly in Washer
Thanks for your suggestion about looking in the lip of the seal. I found one of my three year old granddaughters socks. Also, the seal for very dirty so I mixed a 50% solution and 50% solution of chlorox and used an old towel rag to wipe and wash throughly around the lip seal.
I noted that the aluminum ring inside the washer had also accumulated a lot of dirt. With one hand and fingers I held the wet cholorx towel inside the ring and with the other hand spun the tub around several turns until I had removed all the dirt and grime.
It did have a moldy smell. I'll let you know if this fixed the problem.
dundat45
Jul 19, 2008 | Whirlpool GHW9100L Front Load Washer
Aeg santo fridge water leaking into door seal and runs onto floor when opening the door, also the door has incredible suction after closing and is difficult to open soon after closing
Had the same problem. I'd already tried waggling the drain rod from inside the fridge but to no avail. I pulled out the fridge and pulled off the 'top hat' end on the very end of the corrugated drain pipe. Inside was pretty gunky.
Just clean it thoroughly especially around the little rubber mushroom and the problem goes away. Simples
Jul 09, 2008 | Refrigerators
Moldy smell in washer
run cycle using bleach only in water after cycle use a bleach/water solution to thoroughly wash door seal be sure to pull seal at bottom of drum opening and clean inside lip in future leave door open as much as possible between cycles just remember YOU ARE NOT ALONE..all front loaders no matter the brand have same issue some just worse than others
Jun 18, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
174 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
