Question about Garmin GPSMAP 440 Chartplotter GPS with Ocean Shoreline Info
We can not see AIS display on Garmin GPSMAP 440 display?
4 Suggested Answers
SOURCE: Garmin GPSmap 76 not acquiring satellites
You need to do an auto locate. This also corrects your time issues (wrong date and/or time will be corrected. To do an auto locate do the following.
  1. Start with the unit turned off.
  2. If you have a GPSMAP 76, GPSMAP 76C, or GPSMAP 76S, hold down the Page button. If you have a GPSMAP 76CSx or GPSMAP 76Cx, hold down the Zoom Out button.
  3. While holding down the first button (Page or Zoom Out), press and hold the Power button.
  4. Continue to hold the two buttons until the Satellite page displays. You can then then let go of the buttons.
  5. Finally, let the unit sit outside with a clear view of the sky. Allow about 20-40 minutes for the unit to acquire satellites.
Posted on Nov 24, 2008
reef runner
  • 7 Answers
I had the same problem? GPSmap76S was hung up trying to AutoLocate. It just couldn’t find itself, and it just stopped working all of a sudden one day, while I was traveling. I spoke with Garmin about the problem, and they advised me of an ongoing problem with WAAS. I was told that I should "Disable" WAAS, because the signal from the WAAS satellites had been changed by the government, and Garmin had not yet put out a software update to address the problem, on the 76 units, anyway. Also said that an update "should" come out, in the future, however, no commitment or promise on that. Evidently, once your unit hits one of the WAAS signals, it scrambles up the receiver in the GPS, because mine sure went crazy. The support guy also said, that if this did not correct the problem, I might also want to try a "Master Reset". So here’s what happened.
I disabled WAAS, but this did not correct the problem. The unit was still lost out there somewhere, trying to AutoLocate, so I ended up doing the “Master Reset”. Please read up on this procedure before trying it, and understand that you “will loose” any settings that you might have made to the GPS, along with all waypoints, routes, tracks, etc., however, my maps actually remained in tact? This procedure will actually set the unit back, just as it was when it originally came from the factory. Once completed, you will then have to allow the unit to initialize it's self again, just as you did when the unit was new. If you have forgotten about doing that, it simply means that you need to set the unit outdoors and leave it “on” for a while (15 – 20 minutes), until it actually AutoLocates it’s self, or locks in on your current position. Once this is done, re-do your setting preferences, back to the way you had them before the Master Reset. At the very least, you’ll have to re-set it to the correct time zone, and tell it about daylight savings time. Note: It’s a very good idea to go thru first, and jot down your page settings and main menu settings, before doing this procedure, or the screens may not look familiar to you, once the unit resets. You think you’ll remember them all, but you won’t. But whatever, once you have done the “Reset” and “Initialization”, you must now hook the GPS up to the computer and reload your waypoints, routes, etc, back to the GPS. You did have them saved on your computer, didn’t you? Hope so… If so, you should now be good to go…………….
My unit now works like a champ, good as new, just not as accurate, due to WAAS being turned off. I still don't know if the WAAS issue, was part of the problem or not, but I do know that the Master Reset got the unit back to working immediately, allowing it to locate itself almost instantly. What a relief…………..it’s a little work, but it takes much less time than it took you to read this post…………..
Hey, when all else fails, call Garmin 1-800-800-1020. They are good guys and willing to help, in fact, I would advise you to call them before you do anything, so you can describe to them, exactly what your unit is doing. I am only relating my situation and what happened to me. Your situation may be different…….
Posted on Dec 13, 2008
  • 638 Answers
SOURCE: would like to buy a garmin gpsmap 178/178c owners manual
Contact Garmin and they will sell you one.
Posted on Apr 15, 2010
Compass will not caibrate
Garmin GPSMAP 62 - Initial Setup - Calibrate Compass ...
? 7:27
https://www.youtube.com/watch?v=OG7uVh2kQ24
Nov 9, 2010 - Uploaded by Jim Cyr
have owend 3 garmins. will be using handheld for biking. this looks like fast map ... Anyways, your review was decent, just don't know if I like garmin (possibly not). .... Compare Garmin GPSMap 62S vs Garmin GPSMap 60Csx ...
How to Reset the Garmin GPSMap 62 Series Handheld ...
? 1:23
https://www.youtube.com/watch?v=v-M7Ev6YTcA
Jul 20, 2012 - Uploaded by GPSCity
GPS City will show you how to RESET your Garmin 62 series GPS back to factory default settings. Back up all ... -My GPSMap 62s will not track satellites! -Forgot what ... -My barometric altimeter will not work or calibrate.
[PDF]GPSMAP® 62 series - Garmin
static.garmin.com/pumac/GPSMAP62_QSM_EN.pdf
Jan 04, 2016 | Garmin Gpsmap62s Hand Held Gps
440s will turn on but the screen is too dark to see
This is happening to mine also, but Garmin is saying they no longer service the item. ANY HELP out there?? You CAN see that the unit is functioning but the light level is so low you need to shade the screen to be able to tell what is happening. The slider for brightness is all the way to the right and it is not set to NIGHT view. jogging the power button does not help.
Oct 20, 2012 | Garmin GPSMAP 440 Chartplotter GPS with...
Where do i go to down load update for my gps 295. garmin said thay dont support this unit. thanks joe
Joe,
The Garmin "GPSMap 295" is at, as far as Garmin is concerned anyway, "end of life". This means Garmin will no longer support, repair, etc. this product. C'est la vie.
Garmin's older product lines lack the hardware to decompress the new "NT" (New Technology) maps that Navtek (the map company) is producing now. The NT maps are compressed so that they would fit on smaller capacity memory cards. By doing this, the maps required Garmin to include hardware (special designed circuitry) that could quickly decompress these maps "on the fly" for display. The much of Garmin's older GPSMap & StreetPilot lines predate this hardware requirement.
Our "still-functioning" GPSMap & StreetPilot GPSr will still pinpoint our location on the Earth as always - but lack the latest & greatest maps. You should review the maps that your GPSr can use and choose the one you prefer. I switched mine to display topographical maps. These show many of the road names like the City Navigator maps do, but lack important things like the POIs and routing. If you can do without them, this could be good enough. If you can't, you'll need to decide on whether the last non-NT map version is sufficient or purchase a new GPS that can accept the maps you want to put into it.
I hope this helps and good luck!
Sep 06, 2011 | Garmin GPSMAP 295 GPS Receiver
My Garmin GPSMAP 178C screen backlight failed
Backlight problem: Remove the display, remove the light tube from behind the LCD. Buy a led panel from Ebay for around $5 and install it behind the LCD under the drfusing layers. Run the wires out to a 12 VDC source and there you have it.
Jul 13, 2010 | Garmin GPSMAP 178C Sounder GPS Receiver
I have a garmin gpsmap 440s that will only read sonar depths a no wake speed. When I increase speed much past this the depth number blinks but does not track or change until I slow back down to idle again....
Sounds like the transducer is installed at the wrong angle or in such a way that it is getting a lot of air from something on the hull. If it is a transom mount, check that it is angled correctly and not too close to the motor or aft of some kind of thru-hull fitting that will cause turbulence.
Aug 18, 2009 | Garmin GPSMAP 440 Chartplotter GPS with...
New GPSMap 440 S Depth flashing
You need to visit the garmin site and download a software upgrade its free and should fix any glitches you may be experiencing with your unit.
Jul 01, 2009 | Garmin Gpsmap 440s Dual Frequency Combo
Garmin GPSMAP 60CS displays wrong date
mou exoun dvsei ena gps to opoio mesa einai ola sbismena.
prospathw na tou perasw ena ellhniko xarth alla den mporw...
xreiazomai help.......
Feb 03, 2009 | Garmin GPSMAP 60CS GPS Receiver
Sonar not working properly, intermittent
Generally, that indicates air bubbles in the water under the transducer. If you have a transom-mount transducer, make sure the bottom surface is level or angled slightly down. If you have a thru-hull, make sure your bottom is fairly clean in that area.
Oct 20, 2008 | Garmin GPSMAP 440 Chartplotter GPS with...
Garmin GPSMAP 440 Chartplotter GPS with Ocean Shoreline Info Logo
61 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
