Question about Dryers
How do I remove the top from a Maytag Model LDG490 gas dryer?
  • adamdietzel Nov 16, 2009
    Wrong, You have to remove the front panel with the door by removing two phillips screws at the bottom front. Then remove the two 5/16" hex head screws at the front corners that hold the top on.
  • Dryers Master
  • 8,404 Answers
It is held down by spring clips - pop it open
Posted on Nov 15, 2009
  • A Miller Nov 16, 2009
    Great! Im glad you got t figgered out!
    Thanks for your interest in FixYa.com
How do I remove the top from my Maytag gas dryer model number LDG8426ABE
Go to www.repairlinic.com and enter LDG8426ABE. With luck, you will be presented with a list of common replacement parts and assemblies. You also may be able to view a generic Maytag video showing disassembly.
Mar 30, 2018 | Maytag Dryers
Dryer ldg490 will dry on timer dry but runs forever on permapress (not much heat) what sensor is bad ?
sounds like bad timer points, they tend to burn and get stuck on some places ?
Oct 02, 2014 | Maytag Dryers
Maytag Centennial 7 Cu. Ft. Electric Dryer, how to remove front
unplug it,remove the top panel screws in the back,remove the control panel and then you can remove the front.go here
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MDG9700AWW/3048/0151200/M0702017/00001?
blt=06&prst=&shdMod=
you'll see number 14 and 15,you have to remove the 4 1/4 inch screws on the top and the two phillips screws that are behind the door.
Oct 13, 2013 | Maytag Neptune MDG9700A Gas Dryer
I have gas dryer, model SDG4606, and the light inside drum does not work. How do I replace it?
When you open the door on your dryer your light bulb is located at the top of the opening. There will be a clear plastic cover over it that is held in place by one screw. Remove the screw and allow the cover to hinge away from the opening. The bulb is Maytag part number 67001316.
Sep 17, 2010 | Maytag SDG4606A Gas Dryer
How to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
Apr 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
One of the fins in my Maytag gas dryer, model Atlantis has come loose. I need to flip the tiop and need assistance
Unplug unit first and turn off gas .Page 5-2 of the service manual below (Similar to yours) will cover removal of front and top. Good Luck.
Service Manual
Sep 09, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
How do I replace the gas valve coils on Maytag Quiet Plus model#LDG9606AAE ?
You gain access through the front. To remove the front you will first take the top off.
Eric
Jun 17, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag dryer model mdg5500aww
OPEN THE DOOR AND REMOVE THE TWO SCREWS IN THE MIDDLE OF EACH HINGE. LOOK AT THE OPPOSITE SIDE OF THE OPENING AND REMOVE TWO SCREWS FROM THAT SIDE ALSO. PULL FRONT TOWARD YOU FROM THE TOP. IT IS HINGED AT THE BOTTOM. ONCE THE TOP IS FREE, LIFT THE FRONT OFF THE HINGES. THERE IS A CLIP HOLDING THE TOP TO THE CABINET AT THE FRONT CORNERS. REMOVE THE SCREWS HOLDING THE CLIPS IN PLACE AND SWING THE CLIPS TO THE LEFT AND RIGHT TO REMOVE THEM. THE TOP SHOULD SWING UP AND TO THE BACK AT THIS TIME. IT IS HINGED AT THE BACK.
Mar 24, 2008 | Maytag Neptune MDG5500AW Gas Dryer
How to remove a back panel of maytag neptune dryer?
You have a choice for which side front door should be on this model. There are 4 screws on front door. Take all 4 screws and pull down the front panel. You will see two metal parts each side which holds top panel. Remove two screws and metal parts. Now you can push up the top panel.
Mar 17, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
67 people viewed this question
Top Dryers Experts
