Question about Logitech X-530 5.1 Speakers
Hi there, my dog broke the 15 pins cable of the logitech x-530 5.1. and I'm trying to repair it with a new terminal but I need the pin terminal alocation diagram. do you know where can I get it? thanks in advance!
3 Suggested Answers
SOURCE: I need a circuit diagram for My Logitech Z-640 Computer Speakers
You may have to call Logitech support or email to find out what the pin out is. that would be my only solution if there is one.
Posted on Apr 24, 2009
SOURCE: logitech x-230 9 pin problem . i need to manualy
worked on this for 3 days but i finaly got it I had to open it an follow coper lines using datasheet, the connector is RS232 the pins are
1 = LED+
2 = IN R
3 = OUT R
4 = OUT L
5 = GND
6 = ON
7 = 5V
8 = GND
9 = IN L
so you have to put a swiths between pin 6 and 7
you should also put a potentiometer GND-IN-(AUDIO SOURCE)
and a led between pin 1 and GND
and that is it!
---POXTRON---
Posted on Aug 04, 2010
Car
Speed Sensor probably. Try:
1. Ensure mainshaft and countershaft speed sensors are installed properly. Disconnect mainshaft speed sensor harness connector. Using a DVOM, measure resistance between sensor terminals.
2. If resistance is not 400-600 ohms, replace mainshaft speed sensor. If resistance is 400-600 ohms, disconnect 25-pin PCM harness connector "B". Check for continuity between ground and 25-pin PCM harness connector "B", terminals No. 15 (Red wire) and No. 14 (White wire).
3. If continuity is present, repair short to ground in Red or White wire between PCM and mainshaft speed sensor. If continuity is not present, reconnect mainshaft speed sensor harness connector. Measure resistance between 25-pin PCM harness connector "B", terminals No. 15 (Red wire) and No. 14 (White wire).
4. If resistance is not 400-600 ohms, go to next step. If resistance is 400-600 ohms, go to DTC
P0720 (FLASH CODE 9) . Check for loose PCM harness connectors. Replace PCM with a
known-good unit if necessary.
5. Disconnect mainshaft speed sensor harness connector. Check Red wire for continuity between 25-pin PCM harness connector "B", terminal No. 15 and mainshaft speed sensor harness connector. If continuity is present, go to next step. If continuity is not present, repair open in Red wire between 25-pin PCM harness connector and mainshaft speed sensor
harness connector.
6. Check White wire for continuity between 25-pin PCM harness connector "B", terminal No. 14 and mainshaft speed sensor harness connector. If continuity is present, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary. If continuity is not present, repair open in White wire between 25-pin PCM harness connector and mainshaft speed sensor harness connector.
Mar 21, 2014 | 1998 Acura Integra Type R
I have a 2 pin computer connection but the speakers have a 3 pin connector . How do i connect to the pc
You need to connect all the tree of them using the adapter you got in the package, flo210_4.jpg
May 14, 2010 | Logitech X-530 Computer Speakers
Dog chewed off usb connector need pin to repace
You will have to buy a USB connector cable and cut off one side. I hope you know how to solder. The USB cable is very cheap, and if you know how to solder well, your problem is solved.
Dec 21, 2009 | Logitech ClearChat Pro USB Headset
How do I change the input from the DVI-I input to the 15
I found the online manual and followed the instructions to set to "auto" input. Everything works fine.
It had been a discouraging ordeal trying to locate a new DVI cable (which came with the projector)
and as it turns out the 15 pin cable works fine. Thank you.
Rick
Jun 11, 2009 | Sanyo PLC XU50 Multimedia Projector
I'm trying to use the cable from my Saitek P750 on my Logitech wingman extreme because the P750 has a USB and a 15 pin the wingman only has a 15 pin. My notebook doesnt have the 15 pin but has 3 USB ports....
Buy a USB to gameport adapter from Radioshack ($1.85!!!! cos it's sooo old) set the switch on the adapter to joystick B (with "hat" switch) and then you can hook it up.....drivers are another issue...I'm still searching..:-)
Apr 11, 2009 | Logitech WingMan Extreme Digital 3D...
VGA Pin Configuration
Pls find below the Pin configuration.
Pin 1 - Red Signal
Pin 2 - Green Signal
Pin 3 - Blue Signal
Pin 6 - Red Ground
Pin 7 - Green Ground
Pin 8 - Blue Ground
Pin 10- Horizontal Ground
Pin 11- Vertical Ground
Pin 13- Horizontal Signal
Pin 14- Vertical Signal
Best Wishes
Jul 22, 2008 | Samsung 793S 17" CRT Monitor
Mx518 cable problem
Most PC repair shops can make you a new one.
The mouse itself is only around £20.00 / $40.00
Jan 13, 2008 | Logitech MX518 931352-0403 Mouse
Cable problem
I checked your problem which you fasing. If you are not monitor specialist after than you should try one monitor specialist in local market. First you should say to engineer that mansion origional data cable in monitor.Engineer says that original data cable is not available in market.after than if engineer pressure to you regrading for 15 pin connenctor.than you should agree for 15 pin connector because if you are only one single user than this connector will carry for one year because this connector is temprary for some time.
Nov 28, 2007 | SAMTRON 55V 15" CRT Monitor
Open Questions:
See all Logitech X-530 5.1 Speakers Questions
Logitech X-530 5.1 Speakers Logo
188 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
