Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Compatability of a R22 air handler and a R410a heat pump
I have a York F2RP018H06B A/handler with a 5KW heat strip and a Ruud UPNL-018JAZ R13 H/pump. Both units are new. The York has a #53 orifice, will this work or will I need a txv or a different orifice? Also, can I pull power for the heat pump from the air handler or will I have to pull power from the breaker box? I had planned on putting a 50 amp breaker in and running both units off of it.
Any advise is appreciated, Thanks, John
  • 89 Answers
1. The units should match up without a problem.
2. You will need a 40 or 50 amp breaker for the A/H and 5 KW heat strip. You will probably need a 20 or 25 Amp for the condensing unit. I would check the FLA (full load amps) rating on both units, total them and install a breaker with no more than 20% more rating than the total. You can install a small box at the A/H with a breaker for the A/H and one for the condensing unit.
Posted on Nov 17, 2009
  • frankrhoney Nov 20, 2009
    The A/H is designed for r-22 Freon and the condensor is designed for r-410a freon and they will not match up. My mistake tewlling you they would match up.
OD model#, CKL36- 1F and the indoor model#, AR36-1. The indoor does not have the electric heat strip in it but has the place for it. I want to convert it to a heat pump. Is it a 3 ton system? How many KW...
You can use the existing air handler for a heat pump condenser unit up to 3 tons. The line set, evap coil are fine for a heat pump.
The electric heat strip issue can be another problem, you can put several different size strips in depending on what may be needed where you live, the power requirements will differ with each heat strip, for example a 5KW (5000 watt) heat strip requires a 2 pole 30 amp circuit for heat strip and air handler combination.
Aug 22, 2011 | Goodman CKL36AR36 Air Conditioner
I have a blown BDP 7.5 ton Condsor unit. The old unit is R22. I want to replace it with a new BDP which has R410A. Question: I am being told that If I flush my old R22 Air Handler Coil & install a TXC...
I've done what you are describing - "however" you could void the warranty on the new condenser - by not having 'matching' coils (inside/outside). I would do some serious checking with whoever you are buying the new condenser from.
Note: I would (if possible) go back with a R-22 condenser unit (price is about the same), and you would not have any 'warranty or matching issues' going on.
Jun 03, 2011 | Heating & Cooling
The heat relay is closing on call for heat but opening quicly
Ok rheem and ruud is the only co that the hp is set to the b term on the stat for heat. is the stat wired corectly? is it a hp stat? and on a 2 1/2 ton hp you should have more than 5 kw. what kind of stat? the relay is correct because you have transformer that takes 208/230 down to 24 va. let me know.
Feb 04, 2009 | Ruud UAKA030 Air Conditioner
Match up Carrier equipment
carrier did sell some systems with R407c as a quick fix to gov regulations for about 2 yrs. R407c is a blend . and is treated like R410a except R407c pressures are more simular to R22. being that the pressures run the same the system should work with out changing any parts that being said if the evaporator has been used for R22 the oil residue wiil give you problems ifit is a new unit you would be ok.
Jan 08, 2009 | Carrier 38CKC042 Air Conditioner
RUUD HVAC UNIT - HEAT STRIPS COME ON WITH THE A/C
What you are talking about I think are the strip heaters in the Air Handler this must be a Heat Pump system right??? If so please check your thermostat and make sure it is not in EMRGY HEAT mode.. One other note there is a 2 stage bulb system inside the stat if it is too cold outside and the heatpump on its own cant keep up with the call for heat the 2nd bulb closes and turns on the heater as a supplumnetal heat also these will come on or should come on when the unit goes into defrost.. plz let me know what it is you are trying to test and i can walk you thru it.. Also need a model # off the A/H to get a Wiring diagram
Feb 03, 2008 | Ruud Handler Air Conditioner
Wiring connection for a Ruud air handler & seeking its wiring diagram.
we are trying to install a goodman heat pump with a rheem air handler, the orange wire is hook up and the unit is still staying in the heat mood. does anyone have a wiring diagram for the air handler, their is some white wires in the air handler one with a purple strip and one with a black strip we need help
Jan 05, 2008 | Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
491 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
