Question about LG DLE5932W Electric Dryer
Accessing heat element
Have removed all screws from back panel and panel still does not come off. Is there another way to access the heat element or is there a trick to removing the back panel after all screws have been removed?
  • Pllister Dec 14, 2008
    I have sprung the spring clips and the top is moveable but the front (at the bottom) still will not come loose any ideas?
    Thanks
    Pam
    New Friend:
  • 60 Answers
You get into the unit from the top. Use a putty knife about 2 inches in from the right and left in the seam on the front of the unit and push in on the spring clip then lift on the top. After that take the front off and work your way down. The heating elements are on the bottom right when facing the front of the unit.
Posted on Jan 09, 2008
Dodge magnum pickup heater wont get hot
test the parts and fix it. God bless you
Test and replace a heating element:
  1. Turn off power at the electric service panel and post a sign warning others not to turn it on.
  2. Remove the access panel on the electric water heater.
  3. Disconnect one of the element wires and set a multimeter to RX1000 (resistance times 1,000). Touch one probe to an element mounting bolt and the other to each element terminal screw, in turn. If the tester displays anything but infinity ( open circuit), replace the element.
  4. If necessary, set the multimeter to RX1 and touch the probes to the terminal screws. If there is any resistance reading at all ( closed circuit), then the element is good. If not, replace it. Both upper and lower elements are tested in the same manner.
  5. To remove the element, first drain the heater.
  6. Disconnect the remaining element wire. Remove the mounting bolts holding the element in place. Remove the element.
  7. Replace the heating element with one of the same model, shape, and rating. Make sure you also replace any installation gaskets.
Test and replace a high-limit cutoff:
  1. Disconnect power to the heater at the electric service panel and post a sign warning others not to turn it on.
  2. Remove the upper access panel and push the reset button.
  3. Replace the access panel and turn the power back on. If the water is hot, the reset was the problem. If not, you'll need to turn the power off again and reopen the access panel.
  4. Use a multimeter to test the cutoff terminals for continuity. If faulty, replace with an exact replacement part.
Oct 28, 2013 | Water Heaters
Tip
How to remove heating element from dishwasher.
1)      First of all, turn the circuit breaker off  to the dishwasher . The circuit breaker is located  inside  your    home's electrical panel.
2)      After the circuit breaker is turned off , open the dishwasher door and carefully pull the lower dish rack out of  the dishwasher.
3) Then look at the  dishwasher's heating element. The heating element is the very thin, circle shaped  tube  located at the base of your dishwasher.
 4)  Then locate the access panel to the dishwasher  which is directly below the door. Properly remove the screws that secure the access panel to the dishwasher with a proper  screwdriver. There are mostly   two screws at the top edge of the access panel. To remove the screws, you will need to open the dishwasher door and remove them from the access panel.
5) Then carefully pull the access panel out  from the dishwasher. You can use a flashlight to locate the wires that are connecting  to the heating element terminals( the two ends of the element).  One wire is connected on each of the terminal ends. The heating element terminals are located at  the rear of the dishwasher.
 6)Slowly pull the wires out  of the heating element terminals. Hold the wire at the metal leads where they connect to the terminals. If you hold  the wires anywhere else, the wire may get cut in between or wire may break out.
7)Then  you will have to remove the nut  located on each terminal .The nut  secures the heating element tight  to the dishwasher . You have to remove the nut. After the nut is removed , then pull the flat washers and the rubber washer from each terminal.
8)      Then carefully open the dishwasher door and  properly un-clip the heating element from the holding  clips in the bottom side of the dishwasher. Then hold  the ends of the heating element and without applying force on any other part slowly pull them straight out of the dishwasher bottom. You will see two rubber grommets. That should come up out with the terminal ends. If the grommets  does not come up with the terminals and remain stuck up in the bottom of the dishwasher, then pull them out of the holes with bit of force.
9)      Now the heating element is out. You can get new replacement element from local appliance part store. You can reinsert the new element in reverse instructions of how you removed the old element.
Good luck.
on Dec 22, 2009 | Kenmore 15899 Built-in Dishwasher
I am trying to take the back off of my Whirlpool clothes dryer model LEQ8611LW1 to replace the heating element, but the back will not come off. How do I get to the heating element?
The dryer doesn't have a removable rear access panel and the heating element is accessible through the bottom front panel. Using a flat-blade screwdriver, locate and release the two bottom front panel clips approximately 4 inches from the sides.
Once the panel is off, locate the heating element housing is on the right side and remove the hex-head screw from the heater shield.
Remove the hex-head screw from the side of the heater housing and slide the heating element out then slide the new heating element in and secure it with the hex-head screw.
Note:
The heating element is not necessarily busted and needs to be replaced when the dryer fails to heat up. The first thing to look at is the thermal cut-off. It blows open and cut power to the heating element if the high-limit thermostat is faulty. Disconnect the red wire from the thermal cut-off and the red/white stripe wire from the heater. Connect the red wire disconnected from the thermal cut-off to the heater terminal where the red/white stripe wire is disconnected from.
Reconnect power then start the dryer. The problem is indeed with the two bypassed components if the dryer heats up. Replace both the thermal cut-off and the high-limit thermostat and it should solve the heating problem. Do not use the dryer with those parts bypassed due to high risk of fire hazards.
Apr 01, 2011 | Whirlpool Dryers
I HAVE A RED4340SQ1 ELECTRIC DRYER WHERE IS THE HEATING ELEMENT LOCATED
The heating element is located at the rear of the dryer behind the rear access panel. Disconnect power then remove the screws attaching the rear access panel to the cabinet and remove the panel.
Your dryer seems not heating but it doesn't mean the heating element is busted. The problem is obviously in the heating circuit which is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed procedures.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 27, 2011 | Whirlpool LER4634J Electric Dryer
How do i change the heating element.
The heating element is accessible through the lower front access panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the two screws attaching the bottom of the lower front access panel to the cabinet then slide the panel down then off the cabinet. The heating element can now be accessed and repalced.
Remove the screws securing the heating element to the heater box then pull down the heating element to remove it from the heater box.
Disconnect and label the wires for the heating element and the components. Remove the components from the old heating element then transfer it to the new heating element.
Slide the new heating element up into the heater box and secure it in place. Align the slots on the top of the lower front access panel with the locating tabs on the front access panel then slide it into position and secure the bottom of the lower front access panel to the cabinet.
Apr 13, 2010 | Amana DLE330RAW Electric Dryer
No heat, but dryer turns.
There are three common causes of a dryer not heating. First is a busted heating element. Second, the thermal cut-off has blown. Third, the high limit thermostat is not working.
Disconnect power to the machine and remove the screws at the bottom of the lower front access panel (toe panel) holding it in place. Pull the panel down and off the cabinet. You now have access to the heating circuit.
Remove the heater shield by removing its mounting screw and pulling it off the heater housing.
The heater terminal block is located at the left opening of the heater housing. Disconnect the wire from one of the heater terminals and measure the resistance of the heating element using an ohmmeter set to X1. The resistance should read 7.8 -11.8 ohms. Replace the heating element if the resistance reads open.
Disconnect the wires from the terminals of the heating element and remove the screw securing it to the heater housing. Slide the busted heating element out of the housing and install the new heating element. Secure it with the screw and put the terminal block in place. Connect the heater wires and reinstall the heater shield.
Slide the lower front access panel up into the cabinet and secure it with the screws.
Feb 28, 2010 | Kenmore Elite HE4 Electric Dryer
How to replace heating element
Remove the power plug from the wall socket. The front panel must be removed after getting the case top loose--remove screws from back near the top, then slide top back and lift the front of the top. The front panel is held by screws near the top inside, then lift panel off. Remove wiring from inside the panel and set panel aside. Take back lower panel off and release the drive belt from the motor. Remove the drum--screws inside near center. Leave belt around the drum and set aside. You now have access to the heating element. Reverse the above to reassemble. Whew!!
Jul 17, 2009 | GE DWXR483EBCC Electric Dryer
Repalcing an infinite switch on Kitchen Aid KERC607HBS4
If you are replacing the infinite switch, you need to remove the back panel of the console. This may include having to remove all, or part, of the entire back panel to gain full access. If you are replacing the thermostat on the heating element, or the element all together, you will need to lift the cook top up for access. This is acommpished by removing the screws along the front edge of the top panel. You will need to open the oven door to see the screws. Make sure you unplug the range prior to servicing any internal components. I hope this answers your question. If not, please let me know.
Jun 09, 2009 | KitchenAid KERC607HBS Electric Kitchen...
Dryer
hi Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
Step 1: Remove the back of the dryer. If necessary, also remove the cabinet top.
Step 2: Disconnect the leads and remove the screws that hold the duct in position. Then lift the entire heater unit out of the dryer.Step 3: Remove the screws that hold the heating element in the duct.
Step 4: Slip the new heating element into the heating duct the same way the old one came out. Be careful not to damage the resistance coils. Replace the screws that hold the heating element in the duct, reconnect the leads, and screw the unit back into position.
now see whether it is ok..............
Sep 12, 2008 | Dryers
Dryer belt replacement
Take the top panel off by slideing a putty knife about 2 inches in at the front and releasing the tabs. remove screws from top of front panel after top removed. also remove 2 screws from inside of front panel on both sides about 4 inches down screwing back into front panel. pull front off and slip belt through opening. Feed belt around drum and put tension on the idler spring release onto belt. reassemble unit.
Aug 09, 2008 | Frigidaire AEQ7000ES Dryer
LG DLE5932W Electric Dryer Logo
348 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
