Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Is there a adapter that is made for this product,my wall socket in the laundry room is made for a 4 prong cord, but the machine is a three prong Frigidaire FEX831CS Top Load... stakable
  • 8,197 Answers
Sorry there is no adapter for the plug. You need to change the cord from the dryer or change the plug in wall. You can get a parts at homedepot.
Posted on Nov 15, 2009
I have a three prong plug washer/dryer but a 4 prong outlet need an adapter
YOU DONT ADAPT IT, U REPLACE THE RECEPTACLE OR USE THE CORRECT PRONG CORD. THE CORDS ARE NOT THAT EXPENSIVE FROM 20 TO 30 BUCKS AND EVEN CHEAPER ON LINE. IF U HAVE A NEWER HOME IT IS MANDATED BY LAW THAT YOU USE 4 PRONG CORD NOT 3 PRONG UNLESS THE HOME CAME WITH A 3 PRONG OUTLET.
Feb 16, 2014 | Frigidaire Washing Machines
Three prong to 4 prong outlet
Yes it can be. I suggest you get a licensed electrician to handle it.
Jan 27, 2013 | Bosch Nexxt 500 Dryer
I have a Frigidaire FAFS4473LW Steam Washer- 3 prong. I moved into a new place with a 4 prong. Do I need a 4 prong cord, or can I change the 4 prong adapter on the wall?
Hi nancy huerta...
You can change the cord or the receptical...
It will be easier to change the cord...
Purchase a four prong plug cord that will fit into your receptical, then wire your dryer for 4 wire instead of three wire use.
To see a picture and explanation of how to wire your dryer for a 4 wire plug go to the following webpage.
Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Sep 06, 2011 | Frigidaire GLER331A Electric Dryer
My dryer's power cord has 4 prongs, my wall socket has 3 holes, can I change the power cord, or is there an adapter to change from 4 to 3 pronges.
Un screw the 2 hex screws from the back of the dryer where the cord goes in.
There will be 3 screws that connect the cord to the dryer, loosen or remove them to remove the 4 prong cord.
A hardware store will carry the 3 prong cord you need, tell them it is for a dryer.
Re-connect the 3 prong cord to the dryer.
Plug in and test after you have installed the new cord.
Jan 02, 2011 | Asko T701 Electric Dryer
I just moved and have a standard 3 prong outlet in my laundry room, the dryer has a 4 prong cord- what kind of replacement cord do I need to buy that will make the electricity of both the dryer and the...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-family: 'Times New Roman'; mso-fareast-language: EN-US; mso-bidi-language: AR-SA" lang="EN">Here is a tip that will help you with changing your dryer plug.<br /><br />Dryer Cord and Wiring Dryer 3 Wire or 4 Wire<br /><a href="http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire" target="_blank">http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span>
Aug 26, 2010 | Frigidaire Dryers
Our dryer has a four plug power cord and the wall socket has only three. Can this be adjusted any way?
Yes buy a three prong dryer cord and replace the four prong cord.The terminal block should be 3 terminal ground in center.
Jun 18, 2009 | Whirlpool Dryers
Won't power on
The product uses a power cord, if the power supply is a power cord with electrical connections at each end. Figure 1: Power cord c00057913.jpgThe product uses a power module, if the power supply is a power cord connected to a power module. Figure 2: Power module c00745315.gif
  • If the product uses a power module (adapter), go to Step two: Check if power is supplied from the power module.
  • If the product uses only a power cord, go to Step three: Check if power is supplied from the power cord.If the product uses a power module (adapter), follow these steps to make sure that power is properly supplied to the product. Figure 3: Power module c00745315.gif
    1. Check the power module part number against the part number listed in the User’s Guide to make sure that the proper power module is being used.
    2. If the power module has a permanently attached power cord, do the following.
      1. Disconnect the power cord from the wall outlet.
      2. Disconnect the power cord from the product.
      3. Wait 30 seconds.
      4. Reconnect the power cord to the product and the wall outlet.
    3. If the power module has a detachable power cord, disconnect the power cord from the power module and reconnect the power cord to the power module.
    4. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
    5. If the product does not turn on, or the power light built into the power cord does not glow, plug the product into a wall outlet in another room.
      • If the product or power light turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
      • If there is still no power to the product, then the power module, power cord, or product might be defective. Proceed to the next instruction.
    6. Connect the power module or power cord to another HP Deskjet or Photosmart product to see if the power module is functioning.
      • If the power light does not glow, the power module might be defective. Replace the power module and the power cord.
      • If the power module or power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
If the product uses only a power cord, follow these steps to make sure that power is properly supplied to the product. Figure 4: Power cord c00057913.jpg
  1. Inspect the power cord for visible damage.
    • If the power cord is damaged, replace the power cord.
    • If the power cord is not damaged, continue with the next instruction.
  2. Disconnect the power cord from the wall outlet.
  3. Disconnect the power cord from the product.
  4. Wait 30 seconds.
  5. Reconnect the power cord to the product.
  6. Reconnect the power cord to the wall outlet.
  7. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  8. If the product still does not turn on, plug the product into a wall outlet in another room.
    • If the product turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
    • If there is no power to the product, then the power cord or the product might be defective. Proceed to the next instruction.
  9. Connect the power cord on another HP Deskjet or Photosmart product to see if the power cord is functioning.
    • If the power cord does not work on the other product, the power cord is defective. Replace the power cord.
    • If the power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
Step four: Service the Product If you have completed all the steps listed above and are still experiencing a problem, service the product by calling hp at 1800-474-6836
Apr 29, 2009 | HP Photosmart D5160 InkJet Printer
I have a kenmore dryer model 11060212990, and the plug has three prongs, but the wall socket is a four prong. what do i need to do?
You will need to purchase a 4-prong power cord and convert the appliance to meet the needs of the wall receptacle. This is a requirement of the National Electric Code in homes that have the 4-prong receptacle. The following link explains how to convert your dryer cord from a 3-prong to a 4-prong:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
These rules apply to the conversion of electric ranges, as well. Read through the link thoroughly and let me know if you have questions. If you require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 29, 2009 | Dryers
Extension cord is black delonghi cf210)
well , yes , it could be fixable , but first the adapter is a three prong to two prong adapter ? if so , for your safety I recommend to plug A/C UNIT wheres a three hole outlet , using the adapter eliminate the UNIT to be grounded , there for causing problems like cord getting hot. hope this helps
Apr 27, 2008 | DeLonghi CF210 Portable Air Conditioner
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
82 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
