Question about Dryers
Making a knocking noise
My refridgerator is making a knocking noise. Seems to be coming from the black round thing (ha) in the bottom (back)
  • 77 Answers
Broken spring in the compressor use it till it dies.
Posted on Nov 15, 2009
The car is making a noticeable thumping noise which seems to be coming from the rear end. What are possible issues?
check lug nuts make sure their all tight, check tire make sure it's not out of round, simple things first.
Mar 03, 2015 | 2011 Ford Escape
My Haier fridge freezer is making a very loud and constant knocking sound. Is it still safe to have switched And does anyone know what the problem could be?
Pull the fridge freezer out and see if the loud knocking sound is coming from the compressor. It's that black round thing at the bottom in the back. If it is, it's time to go shopping.
Feb 17, 2015 | Haier Refrigerators
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
Knocking on side of refridgerator
Where is the knocking coming from? The freezer section, the bottom of the unit?
Oct 22, 2011 | Refrigerators
I have a knocking noise, in the bottom of the motor. The lowest round thing, with the belt attach to it. The noise comes and goes, but its getting worse. It started after the last oil change, 4 weeks...
This sounds like the crankshaft vibration dampener is coming apart it is what the pulley that the belt runs over is bolted to, they knock like crazy, common issue on some Ford models.
Apr 07, 2011 | Ford Aerostar Cars & Trucks
Refrigerator knocking noise
If it seems to be coming from underneath the unit it could be the compressor. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} That's usually mounts inside the compressor. Usually when the compressor cuts off. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Any other noise would be from a fan. One in the freezer behind the back panel and one under the unit where the compressor is.
Dec 29, 2009 | GE Profile Stainless Bottom-Freezer...
2002 Laguna estate - knocking noise!!
the most common problem on the lagunas are the bottom ball joint, id take it to a garage asap to get it checked out
Jun 18, 2009 | 2003 Renault Sportwagon
Ice build up in bottom of refridgerator, loud fan noise
check gaskets for air leaks or blocked drain in freezer section
Jun 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Amana refridgerator mdl abl2222fes knock noise
sounds like the compressor vibration dampers are wearing out. the dampers are the rubber washers that seperate the compressor from the chassis of the fridge. when they start to deteriorate, and the compressor kicks on, it will bounce against something in the chassis, causing a knocking noise.
Jan 22, 2009 | Amana ABL2222FES Stainless Steel Bottom...
the motor could be on the way out. Put your hand (carefully) on the motor (back of the refridgerator), if it is too hot to touch then the motor is burning out and will need to be replaced.
Nov 15, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Dryers Logo
61 people viewed this question
Top Dryers Experts
