Question about Dell Latitude Cp, Cpi, Cpx, C600, C800, Inspiron 3800 8000 4000 601212 CD-ROM Drive
Screen has red lines
I had a problem with power, the suggestion worked and Im back up and running! But now there's red lines horizonal in the screen...any ideas?
    Problem Solver:
  • 16 Answers
Try to reset default setting on monitor
Posted on Feb 13, 2008
Red horizonal line on kindle screen
Your screen has a problem. No way to solve this problem by any software. If it is on warranty, claim service If warranty is over, I'm not sure it can be repaired, probably screen must be changed and it is quite expensive.
Apr 15, 2014 | Compaq Presario M2000 Notebook
Nec pf-68v21 pwr led flashing red green after horizontal output
check the supply at horizontal driver trans former ,if voltage is correct at ho/driver trasistor ...then check allthe fusible resistances from power supply,,,if tv is taking h/oscillation for awhile ,,give more screen control in lot,,, & see for a horizontal line ,,,before tv becomes off,,, if so vertical ic problem...
Mar 16, 2010 | Televison & Video
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Jun 23, 2009 | Toshiba 36A40 36" TV
I have a Lg Vu CU920 and it has red, blue, and green lines
All I can suggest is taking it back to the phone provider and having them replace it.
Jun 21, 2009 | LG Vu CU920 Cellular Phone
Static verticle lines on screen
wiis dont do that but many tvs do im sure its the tv not the wii so it wont matter
May 21, 2009 | Nintendo Wii Console
Phillips plasma. red horizonal lines running thru picture
Nancy and Guest. This is caused by an overload in the Y main and buffers. If you are electronically inclined and want to fix this yourself its not hard, but it is a little pricey. There are actually two problems manifested here, the sparkles are from the y main and the lines are from the buffers trying to compensate. If you're up for the daunting task of fixing this yourself,
This should get you started. Don't hesitate to emial directly for further help.
May 07, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
My older Toshiba TV is showing horizonal lines on upper screen.
maybe dust in the back of set try giving it a hoover out but unplug first
Mar 19, 2009 | Toshiba Televison & Video
The only thing that happens is the red power light is flashing
The Vertical output ic is bad la7832 also has an open resistor in power supply off of pin 7 the ic.
Root cause is probably the zener diode next to the IC itself MTZJ75
Dec 23, 2008 | JVC AV-27720 27" TV
Philips 60p8342 chassy ptv 916
check all your solder connection and test the resistors on the conversion IC's , also check oscilating circuts
Oct 27, 2008 | Philips 60P8341 60" Rear Projection...
No picture or just one line across screen on hitachi ultravision rearproj.
Could be a loose connection on the printed circuit board in the Vertical deflection circuit.
You would have to have a qualified technician to repair this problem.
A intermittent connection in the circuit described can cause a horizonal line across the screen.
You have to be careful and not leave the TV on for a period of time with a bright line, as it can actually burn a line on the CRT screens, which is permanent.
Mar 24, 2008 | Televison & Video
Computers & Internet Logo
108 people viewed this question
Alun Cox
