Question about LG enV VX9900 Cellular Phone
LB env3 LG phone: bluetooth problems syncing with Garmin Nuvi 660 cycles on and off when paired.
Pairing my garmin nuvi to my blackberry
Nuvi 200 does not have bluetooth capability.
See this link:
https://buy.garmin.com/shop/shop.do?pID=9160#specsTab
- Jim
SHARCNET-USA
Jan 18, 2009 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 + omnia
Hi, version 3.1 is supposed to help with disconnects. Please see this link:
http://www.gpspassion.com/FORUMSEN/topic.asp?TOPIC_ID=109459
However, Garmin released 3.4 which will include the changes in 3.1 and also makes the bluetooth compatible with more phones.
You need to go to www.garmin.com and download their webupdater and run it with your Nuvi connected to the PC with a USB cable. It will check (via the Internet) if you need a firmware upgrade. The latest firmware version for a Nuvi 660 is v4.7. There is a second menu after the main firmware option that allows you to select additional software. Select yes and check the bluetooth 3.4 box and the Chipset "G" box if it's shown.. The Chipset "G" is the upgrade for the receiver in the flip-up antenna. Let it download. When finished, select to safely remove the Nuvi. You can now unplug the USB cable. Your Nuvi will reboot and load in the new changes. Whatever you do, don't turn your nuvi off! Let it go and update. You will see it say "Loader", then "Loading Software" and you'll see a task bar that says "Updating Bluetooth Software" and "Updating GPS Software" (if required). Once you get to the main menu and there are no more texts coming up on the screen. Press the power button and turn your unit off and then back on again. Check the GPS and Bluetooth firmware versions in your Nuvi. It should be 3.0 for the GPS and 3.4 for the Bluetooth. Check the firmware version if you selected v4.7. You will have to re-pair your phone with your Nuvi as the update erases any previous set-up. Let me know how it went for you. If you have trouble with this, let me know. I can do it for you. I have done it many times. Please rate my solution if you found it helpful.
- Jim
SHARCNET-USA
Jan 06, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin 760 Blutooth pairing
I also have the 760 & the first gen Boulder (before the front speaker was added). I had the same issue with the M07 firmware (the latest you can get over the air), but took it into a Verizon store & updated it to M09. I am now able to pair the two devices.
Jan 04, 2009 | Garmin Nuvi 660 GPS Receiver
Bluetooth
GB,
The phone information isn't stored in your Nuvi. Each time it pairs with your phone the call, phonebook and other information is retrieved by the GPS.
To manage your phone activity you have to do it within the cell phone itself. Clear your messages and the next time you pair with the Nuvi you'll notice everything is gone.
Cheers
Nov 22, 2008 | Garmin Nuvi 660 GPS Receiver
Pairing the Garmin Nuvi 660 with my Verizon LG Voyager
yes your phone will work with this unit i have hooked up plenty of them .... if you have any problems contact me and i will help
thanks nate
Aug 25, 2008 | Garmin Nuvi 660 GPS Receiver
Enabling Bluetooth locked up
I had the exact same problem, very similar scenario. I seem to have fixed it by...
1. entering maintenance mode (press finger on upper left corner of screen during power up)
2. Press 'View Diagnostics'
3. Page to (Press 'Next' 5 times) Bluetooth Status Page
4. Press 'Updt PR'
5. Wait for 100% progress bar
6. Exit by pressing 'quit', then 'restart'
Good Luck
Feb 06, 2008 | Garmin Nuvi 660 GPS Receiver
Need Info
Read the manual and you will be able to connect Bluetooth TO 660 , menu Bluetooth active , be sure you LG phone is active on his bluetooth, connect and recognize will be done , you will see.
GARMIN 660 is working with a battery and also with your car adapter. I don't see any reason why it would not work on battery ?.
Your issue is not clear concerning the battery ?
best regards
Dec 31, 2007 | Garmin Nuvi 660 GPS Receiver
Need Info
Well your are on 660 review forum sir not 760.
Easy contact GARMIN and ask for the list of recommended cell phone who work with it. Normally most of them are working fine and the connection BLUETOOTH is recognize
Dec 28, 2007 | Garmin Nuvi 660 GPS Receiver
My Garmin 680 bluetooth stopped working w/ my LG Vx8600
I have found the only thing that works thus far is to click on the red phone in progress icon then go to "call options" then click transfer audio to phone, then transfer audio to nuvi. Sometimes I have to do this twice. but it works.
Nov 22, 2007 | Garmin Nuvi 660 GPS Receiver
LG enV VX9900 Cellular Phone Logo
202 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
