Question about Maytag Neptune MAH6500A Front Load Washer
Can you replace barings on drum without replacing drum housing
  • 77 Answers
No the bearings come as a sealed unit on the tub.
Posted on Nov 15, 2009
Machine showing machine failure call service
The waste box is integrated into the drum unit housing. DIRTY JOB without a toner vac. There are two ports (one one each side). The covers pry off. The service manual doesn't cover this because they want you to replace the drum.
Jan 05, 2013 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
It is making a sqEALlling sound
Without hearing where the noise is coming from I have a few possible causes. None are easy fixes though.
1. The bearings in the wheels that support the drum are bad and need to be replaced.
2. The felt that is at the front of the drum that seals the gap between the drum and the housing has worn out and needs to be replaced.
3. The belt that connects the motor to the drum and causes it to spin is worn out. Not likely since the drum wouldn't turn well if at all.
If the dryer is older and near the end of its life then replacement of the dryer should be a consideration. The repairs will take a couple of hours of time if you do it yourself and if you have it done it will be 1/3 to 1/2 the cost of a new dryer.
Jul 02, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I replace the printer drum on my 5665 workcentre and I can barley see the print, I am told it the high voltage for the drum is out, Can you help?.
The problem occured right after you replaced the drum ?
You could have a defective drum module, but I would suspect that when you replaced the module and turned the orange handle the developer housing did not cam in properly.
You can remove the left cover and push the developer housing in toward the drum.
Sounds to me like the housing just did not return to the home position.
Mar 15, 2011 | Xerox 5665 Copier
Error code E11 on hoover washer dryer vhw854d
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
Nov 12, 2010 | Hoover Washing Machines
I need to know how to remove the bearing from the drum. I have split the outer drum but can't get the shaft out of the back of the outer drum? My washing machine is a Hotpoint WT 960
this just takes a bit of mucle and time.
remove rear pulley and then refit screw (without washer) into shaft. screw the whole way in. then using a lump hammer knock shaft out. may take a good bit of hammerin.
knock bearing out then and also unclog the weep hole in bearing housing.
grease the bearing housing and press in new bearing and seal.
if old shaft damaged ( which prob is if hard to knock out) you will need to replace it.
screws holding shaft to drum usually impossible to undo so drill them out using a 8mm bullet bit.
fit new shaft, put some bearing grease on the bearing seal and re-assemble the drum
Oct 19, 2010 | Hotpoint Washing Machines
Our Maytag gas dryer drum doesn't turn. Replaced belt. Heats up but drum isn't turning
There are three possible reasons why the drum doesn't turn.
  1. Broken belt. You replaced the so in this case it's not.
  2. Door switch. The dryer will not operate if teh door switch is defective. It is inside the drier main housing near the door frame. You need to raise or open the top or front of the dryer to reach the switch. Replace if defective.
  3. Motor. If the motor hums when the start button is pressed, the motor maybe burned-out. Check the dryer motor:
  • Check the blower fan housing for obstruction and manually turn the motor shaft.
  • If the motor is very stiff or cannot be turned manually, you need to replace the motor.
  • If the motor rotate freely, run the motor without the belt. If it runs fine, there maybe problem with the idler pulley or the clothes drum.
  • Rotate the drum by hand. If it is difficult to rotate it, correct any problem with the rollers or pulley. Reassemble the dryer and try it again.
  • If the motor hums but does not run on it's own even without the belt,but can be turned freely by hand, you need to replace the motor start capacitor or the motor itself.
Sep 25, 2009 | Maytag Dryers
Bulb replacement
Ok, you can buy the bulb separately and it will save you money. I will have to warn that , installing this bare bulb will be tricky and you can not touch this bulb with your bare hands. it will damage it. Other than that, it is possible to purchase the bare bulb alone. i will post a link to your replacement bulb without the housing below.
CLICK HERE FOR YOUR BARE BULB WITHOUT HOUSING.
Please rate and have a great weekend:)
May 16, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Yellow not printing - but only in streaks
Your yellow problem sounds like a bad yellow developer housing. Take the drum out and look at the developer housing, You will need a flash light to do so. See if the roller is solid yellow. Even if it is there may not be any developer left in the housing.
The Cyan sounds like the drum since it gets worse as it prints.
That can also be caused by the transfer belt cleaner. But that normally is the opposite. It has a rainbow sort of streak and it gets better as the machine runs.
Feb 02, 2009 | Xerox WorkCentre M-24 Color Copier
Lamp
Did you reset you lamp hours when you reinstalled you new lamp?
Sep 05, 2008 | Office Equipment & Supplies
Dust on Drum message after installinng new Drum
Dust on drum refers to as you correctly stated the wire, it carries a electric charge that transfers the image. If the wire gets contaminated the electricity dont flow right so dust on drum is desplayed, you drum cart is faulty, they are not repairable items, go buy another then claim new/old one as faulty from them. Um aH.
Dec 14, 2007 | Brother DCP-7020 All-In-One Laser Printer
Maytag Neptune MAH6500A Front Load Washer Logo
116 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
