8gb iPod touch has a usb port and itunes cd on the screen and it wont let me do anything
  • 25 Answers
U need songs on it first if that dosent work try charging it then put songs on it
Posted on Nov 15, 2009
IPod Touch won't be read
Wont read what ?
Sometimes, you might find that your computer does not read that the iPod is connected to the USB port, preventing the synchronization of new files.
There are several potential causes for this lack of hardware recognition and many steps can be taken to troubleshoot the causes.
Reset your iPod's internal software using the key combination appropriate for your model. Apple's support documentation details how to do this for each available model.
(See Resources)
Install all iTunes software updates and restart your computer.
Connect your iPod directly to a USB port on the computer.
Do not attach through a keyboard port or USB hub.
These might not provide enough power to operate the iPod.
Connect the iPod to a secondary USB port.
If the iPod is recognized now, the original USB port might be damaged.
Connect the iPod using a secondary iPod USB cable.
If the iPod is recognized now, the original USB cable might be damaged and should be replaced.
Restore the iPod using a computer that can read it as a last resort. Connect the iPod to another computer, launch iTunes and select "Restore" from the iPod information screen.
This will erase all data and restore default settings.
Contact Apple support or visit an Apple store for further help if your iPod still cannot be seen. An advanced hardware issue might be present and a warranty hardware replacement might be indicated.
Hope this helps
Oct 24, 2012 | Sony Cdx-gt420u - Mp3/cd Player With Usb...
Restore software for ipod 16GB touch
i would be checking the usb lead before doing anything or even replacing it with a new one make sure iis securely connected
the cable near the iTunes symbol represents a problem with the cable
and the cd will not not be able to activate without a connection
Connect one end of the USB sync cable to one of your computer's unused USB ports, and connect the other end to the bottom of the iPhone or iPod Touch.
If iTunes does not start on its own, run it using the desktop or Start menu shortcut.
When iTunes starts, you should see an icon for the iPhone or iPod Touch on the left side of the window.
Click "Summary" in the right pane of the window if it is not already active.
Click the "Restore" button to begin the device restoration process.
ITunes displays a message asking if you want to save the contents of the device to your computer before restoring it.
If you have not backed up the device already, click the "Back Up" button.
If you have already done this, click "Don't Back Up."
Click "Restore." ITunes clears the data from your iPhone or iPod Touch and reinstalls the device's original firmware.
The screen of your iPhone or iPod Touch may shut off while iTunes works.
Do not remove the USB sync cable.
When iTunes is done restoring the device, it displays a message letting you know that the device is about to restart.
Click "OK" to restart the device. If you are restoring an iPhone or iPod touch, wait for the "iPhone / iPod touch is activated" message to appear on the screen of the device before you disconnect it from the computer.
You may now restore your backup of the device or remove it from the computer.
hope this helps
Sep 15, 2012 | Apple iPod touch
My itouch wont startup on screen u wil see a usb arow up pointing itunes
This usually means you need to connect your iPod to your computer and open iTunes. You may need to restore the iPod to original settings in order to fix.
Apr 24, 2012 | Apple iPod Touch 8GB 32GB 64GB 3rd...
HOW TO USE IPOD TOUCH
you have to download itunes2_bing.gif from here:
http://apple.com/itunes
install it
then connect your ipod with your pc
Dec 25, 2009 | Apple iPod touch
My ipod wont load up
OK, all new iPods need to be plugged into iTunes before you can use them. So,here's what you need to do, take your iPod and using the USB cable that came with it, plug it in to your computer. This will charge it. Next, you have to have iTunes 8 downloaded and installed onto your computer, click here to download it. Once you have this done this, keep your iPod plugged in, and iTunes should prompt you to go through a set up, go through it. Then you should be good to go!
I really hope this helps! -cj
Aug 16, 2009 | Apple iPod touch
My Computer and iTunes does not recognize my iPod Touch
Try resetting it while it is connected. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
If you have not already tried, I would also try the other ports on the computer.
Are you running iTunes 8?
And what kind of computer do you have?
Jun 01, 2009 | Apple iPod touch
Ipod is not recognized by itunes
IF YOU HAVEN'T SYNCED IT TO ANYOTHER PC THEN SHUT OFF YOUR IPOD TOUCH CONNECT THE USB WIRE TO YOUR PC AND TO YOUR IPOD THEN HOLD THE POWER AND HOME BUTTON THEN ITUNES SHOULD GRAB IT.
May 04, 2009 | Apple iPod touch
Ipod wont turn on
If you just purchased it, you will need to install iTunes on your computer and connect the new Touch to the PC after iTunes installs. When you use your Touch for the first time, it needs to synch/register via iTunes first.
Also, to unlock it, just slide the slider on the bottom of the screen after synching with iTunes.
Apr 10, 2009 | Apple iPod touch
Ipod Touch
get on your laptop download itunes if you don't already have it... then connect your ipod touch to the usb port. After that itunes will come up... just follow the instructions... once all that is done... disconnect your ipod and start adding music to your itunes then connect your ipod touch again to load your music into your ipod.
Jun 21, 2008 | Apple iPod touch
Open Questions:
27 people viewed this question
 Grubhead
Grubhead
