Question about AudioBahn Immortal AWIS10P Subwoofer Car Speaker
How do you wire up a audiobahn immortal - AudioBahn Immortal AWIS10P Subwoofer Car Speaker
    Problem Solver:
  • 8 Answers
Is it a singel or dual connector. can u conn 2 or 4 speaker wires je
Posted on Nov 17, 2009
I have 2 12" solobaricL7 kickers and a audiobahn2200HCT and the amp clips before it gets very loud. is my power wire too small?
You should be useing 4 gauge power wire from your battery to the fuse holder, and from the fuse holder to the amp also 4 gauge, make sure you are also useing a short (18 inches or less) 4 gauge ground wire also. Make sure you are providing a GOOD ground, try to ground to the frame!!!!!!!
If you cannot ground to the frame, connect to the body of the vehicle close to the amp,drill a hole where needed and scrape paint or any coating around the drilled hole, then solder a ring terminal onto the gound wire,then put a bolt,lock washer and nut through the ring terminal through the drilled hole and tighten sufficiently to the vehicle!!!
Also what comes to mind is make sure the subs are in good condition(not blown) make sure they move freely without any scratching from the voice coils as you depress the cones in and out!!!
Depending on the vehicle you made need to upgrade the alternator and battery.
Make sure the battery has good cables and ground also, no corrosion,loose clamps,etc.
Good luck !
Mar 14, 2010 | AudioBahn Immortal AWIS10P Subwoofer Car...
Sub repair
Well actually you can repair it your self with geat ease i may add,,
actuall all that can go in the speaker is the coil.. Yep the coil thats all
You will need a coil for it, a dust cap and the cone.
1.) using a knife, cut the cone off
2.) ulsolder the coil from the speaker
3.) resolder the new coil
4.) firmly fit and glue the coil to the new cone
5.) glue the cone to the metal edges of the speaker
6.) glue on the dust cap..
7.) have a beer your done..
You can get the parts at any local electronisc shop, I'd recommend you cut the cone and the coil off and take it with you when buying parts.
Jul 15, 2008 | AudioBahn Car Audio & Video
Audiobahn a8002t schematic
audiobahn.com under tech support you can download your manual for almost any thing even shows you wiring diagrams helped me out...
Mar 01, 2010 | AudioBahn A8002T Car Audio Amplifier
Need to wire to mono block amp
4 ohm voice coil? on the mono amp it should be from left to right ++ -- you want to go + x x -
Feb 19, 2010 | AudioBahn Immortal AWIS10P Subwoofer Car...
Need wiring diagram for sub
u should have two pos, an two neg. on the back of the sub run a wire from one pos to the other same with neg. now just run a pos an neg from the box to one side of the sub u should have one side with two wires runing to the pos. an neg. if u need more help let me know bertman285@hotmail.com
Apr 25, 2009 | Car Audio & Video
ABR100T Audiobahn Bass remote not working correctly?
i had the same thing happen to me on my 2300hct audiobahn. it turned out to be the remote. but soon after my amp went dead. i than switched to JL no problems since.
but i still use audiobahn immortal 12's.
Apr 11, 2009 | AudioBahn ABR100T Remote Bass Control For...
I need wiring diagram for audiobahn AWES12P 4ohm speaker
you can go to audiobahns website. just fill in the specs like how many subs you have and what kind of amp/amps and it will give you all available wiring options.
Jan 26, 2009 | AudioBahn AW800 Car Subwoofer
AUDIOBAHN A3351 WIRING HARNESS
you have to find one that somebody has audiobahn dosnt carry them any more i called them today for mine but no luck
Oct 30, 2007 | AudioBahn A3351 CD Player
Is it enough
Audiobahn subs are not too powerful and they can not handle too much continuous RMS, be careful they will heat up and tear off the voice coils off ur subs. run about 100 - 150 RMS at 75 HZ to each sub and keep the gains at about 3/4 this way you will avoid blowing out your subs. It also depends on the amp? What kind of amp is it?
Let me know if you wish. Otherwise
Oct 21, 2007 | MA Audio HK4000D Car Audio Amplifier
American legacy II LA690 amp
it's shutting off for a reason. What speakers are you trying to run? Do you know what impedance they are wired for? Where is the gain set? When bridged that amp is only stable at 4 ohms mono and will/should shut down at impedances lower than that.
Mar 22, 2006 | Legacy Audio American Legacy II LA690 Car...
Car Audio & Video Logo
301 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Jerry Naidoo
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
