Question about Motorola Mobility RAZR V3x Cellular Phone
Phone power up but phone is locked - Motorola Mobility RAZR V3x Cellular Phone
How do I factory reset my lg7530 ?
  1. Turn the phone off.
  2. Press and hold the following keys at the same time: Volume Down Key volumedn_key.png + Power/Lock Key powerlock_key.png on the back of the phone.
  3. Release the Power/Lock Key powerlock_key.png only when the LG logo is displayed, then immediately press and hold the Power/Lock Key powerlock_key.png again.
  4. Release all keys when the Factory hard reset screen is displayed.
  5. Press the Power/Lock Key powerlock_key.png to continue or either of the Volume Keys volume_keys.png to cancel.
  6. Press the Power/Lock Key powerlock_key.png once more to confirm or either of the Volume Keys volume_keys.png to cancel
Jun 24, 2016 | Tablets & eReaders
Tip
Unlock codes for Samsung Sgh J700i
<span>1- Power on phone, type : *#7465625#<br />you will identify which code is active , which is inactive. <br /><br />2- Remove battery, Put your sim card, not all of it, just to prepared for it to be full inserted, put your battery back and power on phone you must see " insert sim" not "invalid sim.." <br /><br />3- Type : *2767*3855# <br />your phone should restart after 1 min,<br />now, and before it restarts, push your sim card in, without removing battery. <br /><br />4- Your phone should work and accept the sim card ,, but if you chek locks you will find that your phone is still locked <br /><br />5- Now type : *7465685*638*00000000*00000000#<br />your UNLOCK CODE is 00000000 now , Enjoy <br /><br />6- Now , back to Locks table with : *7465625*, and for each active code you can disable it, here details :<br /><br />* Disables CP lock : #7465625*27*00000000#<br />* Disables Network lock : #7465625*638*00000000#<br />* Disables SIM lock : #7465625*746*00000000#<br />* Disables SP lock : #7465625*77*00000000#<br />* Disables Subset lock : #7465625*782*00000000#</span>
on Dec 25, 2010 | Cell Phones
I screenlocked myself out of my LG optimus dynamic ii phone how do I getin to it
http://img-tf.deviceanywhere.com/tracfone/pub/252610/docs/L39C%20English%20UG.pdf
Locking and unlocking the screen If you do not use the phone for a while, the screen will be automatically turned off and locked. This helps to prevent accidental taps and saves battery power. When you are not using your phone, press the Power/Lock Key to lock your phone. If there are any programs running when you lock your screen, they may be still running in Lock mode. It is recommended that you exit all programs before entering Lock mode to avoid unnecessary charges (e.g. phone calls, web access and data communications). To wake up your phone, press the Power/Lock Key . The Lock screen will appear. Touch and slide the Lock screen in any direction to unlock the screen. The last screen you viewed will open.
Mar 01, 2015 | Tracfone Wireless LG Optimus Dynamic II -...
I cant get the code for screen its locked lgl34c
if you want you can reset the phone using the method below
.turn the phone off
2.press and hold volume down + power + lock key at the same time
3.release the keys when the factory hard reset screen appears
4.read the warning and press the power/lock key to confirm.press any other to cancel
5.press the power/lock key to confirm once more or press any other to cancel
6.your device will perform a hard reset
Nov 26, 2014 | Cell Phones
How do I hard reset my virison lg vs920 modle phone
Follow the following steps:
  1. Turn the Power Off.
  2. Touch and hold the following keys at the same time for 8-12 seconds: Power/Lock Key + The Volume Down Key.
  3. Press the Power/Lock Key when you see the pop-up "Permanently Erase User Data & Reset Settings?". Press the Power/Lock key to confirm, or touch any Up and Down key to cancel.
  4. When you press the Power/Lock key to confirm, another pop-up stating "Are you sure you want to continue with erase?" will show up. Press the Power/Lock key to confirm or touch any up or down key to cancel.
  5. After pressing the Power/Lock key, your phone will be restored to factory settings.
Please remember that when you perform factory reset, then all your user applications and user data will be deleted.
Please make sure you back up any important data before a factory reset. I recommend Titanium Backup (https://play.google.com/store/apps/details?id=com.keramidas.TitaniumBackup&hl=en). However, your phone should be rooted.
The picture attached should show you the buttons highlighted in green.
However, if your phone is still in working condition, then you can follow the following steps:
  1. From the Home screen, touch the Menu Key.
  2. Touch Settings > Privacy > Factory Data Reset.
  3. Note: Touch the check box to erase all contents from your microSD card when the phone is reset.
  4. Read warning and touch "Reset Phone".
Hope that helped.
Cheers,
Sami Memon
Aug 17, 2012 | Cell Phones
How to turn LG phone on?
Usually you push the power button. Which is the red one
Mar 19, 2011 | Cell Phones
Touch screen is locked up can't type anything
Do a hard reset by holding down the power button for a few second and powering down. If that is not an option, remove the back covering and take out the batter for a few seconds. After a few second, replace the battery, and power up the phone. You should be able to type what you need provided you have your lock code if the phone is locked by your pass code. If it is locked by your pass code and you do not remember it, then you will have to contact your service provider.
Nov 22, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
I DONT REMEMBER THE LOCK CODE..
pls press the power off button once and go to lock phone and type 00000000.u will solve ur prblm...........
Feb 27, 2009 | Samsung SGH-i450 Cellular Phone
Need phone lock code
mechanic213 hello,
By default, all Sony Ericsson phones are locked with "0000" as a code.
Sep 29, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Motorola Mobility RAZR V3x Cellular Phone Logo
37 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
