Question about Whirlpool Dryers
Whirlpool Imperial Dryer (electric). I need to replace the belt but one of the parts that the belt goes through came off when I took out the drum. Not sure how the part goes back in. Do you have a picture of assembly for replacing the belt?
  • Whirlpool Master
  • 7,482 Answers
Look for a wear sign on the frame of the dryer, and also the wear on the idler arm with pulley. The wear on the frame will tell you where it goes, and the wear on the idler arm will tell you which way it faces.
Also after you determine where the bracket goes,. then reinstall the spring into the hole on the bracket and move it around to see where it might attach, there should be a small amount of wear where the spring will attach to the frame.
I will include a website that has a repair manual for this dryer, it would be a wise choice to get one if you plan to keep and work on this dryer, it will pay for itself in tech costs.
Check under repair manuals
http://www.applianceaid.com/
Good Luck,
I hope this helps
Posted on Nov 15, 2009
WHIRLPOOL LE7800XSN1 SUPERCAPACITY IMPERIAL 6 CYCLE INFINITE TEMP ELECTRIC DRYER NOT TUMBLING. HAVE HEAT. BELT ISSUE? BELT PART #? GETTING CONFLICTING ANSWERS FOR PARTS.
Go to www.repairclinic.com and enter LE7800XSN1. With luck, you will be presented with a list of common replacement parts (including the belt) and may be able to get troubleshooting information.
Sep 30, 2017 | Whirlpool Dryers
Changing dryer belt on kirkland/whirlpool dryer took apart dryer but dont see where belt suppose to mount.
Hello. The belt goes around the tub and the tension pulley. In fact, it is always a good idea to replace both the belt and the idler/tension pulley at the same time. J.
If you want a schematic go to searsdirect.com and enter your model number. J.
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool imperial series dryer heats not spinning
This problem is almost always a broken belt. Yes you can do it yourself.
Go to repairclinic. com and put in your model number for the exploded view of your dryer. Locate the belt part number and belt orientation.
Jan 03, 2010 | Whirlpool Dryers
Need model number or part number for whilpool dryer
The model number for your dryer is usually located on a plate or sticker inside the door on the body of the dryer hidden by the closed door.
The most common (but not the only) belt number for Whirlpool dryers is 341241 and the idler arm for that common dryer has tabs that fit into the floor beneath the motor drive pulley. Take a loop of the belt with ribs inside the loop and pass it through the opening below the roller and loop it around the motor pulley. If it's the most common unit the end result should look like the image below for Whirlpool:
Belt Configuration
Good Luck
Sep 07, 2009 | Whirlpool Dryers
Whirlpool Imperial dryer heats; drum doesn't turn. (electric 80s
Good Afternoon,
Is this a tall front load dryer with the round glass door?
Mar 27, 2009 | Whirlpool ET8CHEXSQ Dryer
How to install a belt on a Whirlpool dryer model LEW0050PQ?
The tech I paid to replace the belt opened the case from the top and the back, and pulled the drum back away from the front, keeping the drum attached to the back panel. This exposed the motor and the broken belt, which had been cut by the motor drive wheel, probably because the drum was too heavy. Don't you just love renters?
Mar 26, 2009 | Whirlpool LEW0050P Electric Dryer
Belt on dryer
The belt goes around the outside of the drum and an idler pulley and then to the motor. below is a kit you will need to complete the replacement.8b2b1a9.jpgThe kit is $30.00 and below is a link so you can view the parts. Click link below. Let me know if I can help you more, Thanks Sea Breeze
http://www.repairclinic.com/Appliance-Parts?s=t-LER4634J-%3d%3dd583376
Feb 27, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer heats but the drum doesn't rotate
There is usually a large belt that goes around the drum to turn it ...it is either fallen off the motor pulley , broke .....or the motor may be gone in it ....not sure if there are any fuses for the motor on your dryer .
If you can tip the dryer over the bottom is usually open and you can see the motor and belt from there
Jan 09, 2009 | Kenmore 64952 Electric Dryer
Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Jul 12, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Lent belt
no, you need to put a new one on. it will come with the proper glue to hold it in place. the dryer will have to come apart to get it on properly
Nov 27, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
134 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
