Question about Pioneer DEH-P3900MP CD Player
No sound I tried installing the p3900mp in a 98 mazda protege, used the appropriate harness and made sure the ground was secure. When I turned the unit on, it powered on fine and was fully functional, but I got no sound from any of the speakers. I checked all speaker wires, all connections are good, and the speakers worked before with the factory radio...any suggestions? Did I miss something? This is a present for someone, please help!
  • 2 more comments
  • Anonymous Jan 11, 2008
    I am having the same problem. I will call Pioneer for help tomorrow.
  • cthepositive May 05, 2008
    same issue with 98 bmw 328i . all lines appear to be mapped correctly in harness. but no sound out anywhere, no hiss, just silence
  • Anonymous Jan 04, 2009
    no sound, had sound before removing sub and amp
  • Jango Fixit
    Jango Fixit May 11, 2010
    Did you ground the speaker negative terminal wires during installation?( or maybe just one of them is touching chassis)
    That might have blown the sound power output chip.
    Jango
DID YOU TRIGGER THE AMP WITH THE BLUE WIRE TO TURN ON THE FACTORY AMP[IF IT HAS ONE]
Posted on Sep 29, 2008
Replaced battery in 1997 mazda protege DX. dash lights come on, but engine will not turn. small red light on left side of dash is on now, it was not prior to the battery swap. we bought this car used,...
First make sure your battery cables a secured tightly, then look under your dash on driver side for a little black or red button if not there then by your fuse block for a little hide away toggle, you can also unhook ground for 5 min then re-hook and hit the brake rapidly for 5 sec resets your ECU
Jun 25, 2011 | 1996 Mazda Protege
I need to know how to change a oil pan gasket in a 2000 mazda protege
Mazda Protege Oil Pan
m_mzp05a.jpgThe Mazda Protege Cheap Oil Pan that we sell could be mounted easily at the bottom of the crankcase of the vehicle. For fast and helpful information on a Mazda Protege OEM Oil Pan give us a call toll-free! We guarantee a secured server, so you can rest assure your information is kept safe when you place a Mazda Protege Oil Pan order! You can rest assure that you will always be treated with the best care and service with your Mazda Protege Replacement Oil Pan purchase! Excessive tightening of Mazda Protege Oil Pans can cause the gasket to get smashed, so put an extra care during installation. Ordering Mazda Protege Drain Oil Pan online is fast and simple, however, giving us a call toll free can have greater benefits because we can provide expert advice and suggest additional parts that may be needed that you are not aware of! We have proficient sales specialists who are ready to answer your queries regarding Mazda Protege Aftermarket Oil Pan. Did you know that our online catalog is available at all hours to take and process your Mazda Protege New Oil Pan order? That's right! The Mazda Protege Discount Oil Pan is considered as one of the major components of the cooling system.order it to .......racepages.com/parts/oil_pan/mazda/protege.html
Nov 09, 2010 | 2000 Mazda Protege
CK 3100 and 99 Mazda Protege
make sure your ground on the parrot and radio are in the same position on the iso block, sometimes you have to move them to different position
Jan 25, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Heat and a/c only workd with the knob on 1, 2 and 3, but turns off when I put it on 4
CHECK THE BLOWER MOTOR RESITER ITS OVER BY THE BLOWER FAN MOTOR HOUSING.
Nov 05, 2009 | 1999 Mazda Protege
Put in new headlight wiring harness an car won;t start 98 protege I noticed some kind of black fuse or relay with bubbled side in the gob of wires before i replaced
THE BLACK FUSE LOOKING DEVICE IS A DIODE, OR ONE WAY SWITCH. IT ALLOWS CURRENT TO FLOW ONLY IN ONE DIRECTION. MAKE SURE THAT IS GOOD.
Aug 24, 2009 | 1998 Mazda Protege
Wire diagram for the mazda protege stereo what
Sometimes if its the factory harness, you can see fine print on the wires telling what each wire is for. If not, remember, red is hot,black is ground, and your smaller wires all colored purple,brown, gray, green, orange, blue..there will be two of each color, one with a black stripe, that is your ground for the speaker hook up..There also might be a yellow or light blue wire, test that wire for power when the key is off, that is your memory power supply.good luck.
Jun 24, 2009 | 1999 Mazda Protege
I have a deh p3900mp
Antenna does act as ground, just not the best way to do it. Use the 6mm bolt hole in the rear of the chassis for a mounting strap, run a wire from there to the factory (vehicle) radio harness ground.
May 17, 2009 | Pioneer DEH-P3900MP CD Player
Mazda protege don't start
Go to an auto repair store and have them check everything. If you do not know cars, your best bet is to get it checked out rather than take risks.
Dec 27, 2008 | Mazda Protege Cars & Trucks
Pioneer DEH-P3900MP CD Player Logo
150 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
