Question about Meade Optics
I have a problem with my ext125 hand controller it will not start just shows red squares
  • 3,186 Answers
Could be just the cable. Before buying a new hand controller (about $100 on Ebay) try a new cable from www.scopestuff.com
Posted on Nov 15, 2009
Am a new user of netflix and stuck in a screen from last show I watched how I do get back to list of movies and shows?
in the upper left hand corner, there is an arrow pointing to the left... that would be your "Back" button. Click that arrow and it should take you to the previous menu. I have highlighted the arrow with a red square... that will not appear on your screen.
Feb 03, 2018 | Computers & Internet
JET 3 ULTRA. WHAT SHOULD THE LIGHTS LOOK LIKE WHEN YOU TURN IT ON? THE CONTROLLER SHOWS ONE RED LIGHT IN THE LEFT HAND CORNER BLINKLING. YELLOW DOWN BELOW FOR SPEED CONTROL.
All the battery lights should be on and the yellow speed control should not be blinking. a flashing red indicates charging is needed. Strege Mobility
Oct 28, 2016 | Jet Health & Beauty
Photos are not showing, square is blank with a red X in the upper left hand corner
depending on the browser your are using are different these are Internet explorer's AKA the blue E on your desktop or start menu
The easiest way to correct this is to reset IE's settings back to defaults. Here is how you can do this: 1. Open Internet Explorer
2. Click on Tools
3. Click Internet Options
4. Click the Advanced tab
5. Locate the Reset Internet Explorer Settings heading
6. Click the Reset button
7. Click Ok
8. Restart Internet Explorer
if you have a different browser post back to this question and I will attempt to walk you thru changing the setting
if you
Jul 25, 2015 | Computers & Internet
Cheat code central
this is some red faction 2 cheats
Unlock All Cheats
At the cheat screen, enter SQUARE, CIRCLE, TRIANGLE, CIRCLE, SQUARE, X, TRIANGLE, X.
Gibby Explosions
To show gibby explosions, go to the Cheat screen and enter TRIANGLE, CIRCLE, X, SQUARE, TRIANGLE, CIRCLE, X, SQUARE.
Unlimited Ammo
To have unlimited ammo, go to the Cheat screen and enter this code: SQUARE, TRIANGLE, X, CIRCLE, SQUARE, CIRCLE, X, TRIANGLE
Unlimited Grenades
To have unlimited grenades, enter this code at the Cheat screen: CIRCLE, X, CIRCLE, SQUARE, X, CIRCLE, X, CIRCLE.
Super Health
To get Super Health, enter this code at the Cheats screen: X, X, SQUARE, TRIANGLE, SQUARE, TRIANGLE, CIRCLE.
Dec 18, 2013 | Sony PlayStation 2 (PS2) Console
My google screen is to far right I cannot move it fully to the left
In the top right hand corner there is an X in red and next to it is a square with another square behind it. Click on the square and that will restore your full screen.
Nov 05, 2010 | Computers & Internet
What has happned if i can't use my touchpad?
press fn key and the square and hand on it and it will unlock the touch pad if this doesn't work then let me know
Nov 07, 2009 | Office Equipment & Supplies
93 grand cherokee 5.2 V8, red square flashing on VIC display
Your VIC doesn't provide you with codes per se, it supplies other information and what you describe here is what should be written on your VIC, "Coolant Sensor Bad." The actual Coolant Sensor runs to your PCM or computer and your check engine light will come on if it runs at or above 5 volts or below 0.1 volts. If the red square on the vehicle layout is illuminated under the hood area, it means that your Coolant Recovery jug is either low on anti-freeze or the sensor next to the yellow filler cap is faulty...meaning you're low on Coolant and the VIC says that the "Coolant Sensors Bad" yet it's the amount of fluid in the plastic bottle next to the passenger side firewall, right in front of your PCM or computer. If you're low on anti-freeze, keep an eye on it, or have the coolant system pressure tested...including the 18 pound cap on the radiator itself. Also check the two wires hooked to the Coolant LEVEL Sensor in the jug with an Ohmmeter and it should be an open circuit if the level is fine, or hardly any Resistance if the level is low, causing that circuit to complete it's ground circuit and thus signaling the VIC through your BCM to turn on. (Body Control Module). The Haynes Manual you will need is # 50025 which encompasses all Jeep Grand Cherokee's from 1993 thru 2004.
~Stillin~
Nov 05, 2009 | 1996 Jeep Grand Cherokee
- All Songs Cheat Code? Rock Band.
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } You might be playing the rythm a tad off. Try to keep it at the same pace pretty quickly without stumbling.
The rythm should be pretty quick. Like eighth notes or sixteenth notes if you're musica
Jul 20, 2008 | MTV Games Rock Band for PlayStation 2
Sony Rear Projection TV - Red tube too strong
remove the front speaker assembly and the small access panel behind it and you will see a small square control assembly with 6 dials on it 3 control the color guns and 3 control the 3 gun focus. Try turning down the red control slightly they will be set up just like the CRTs red green and blue.
May 16, 2008 | Sony KP-57WS500 57" Rear Projection...
My monitor is monkeying around
The problem is with your Memory IC. Replace it.
Dec 04, 2007 | Gateway FPD2275W LCD Monitor
Optics Logo
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
