Question about Dell V305w All-In-One R840635AU InkJet Printer
V305w communication is not available problem
Same v305w communication is not available problem more than a month now. It's ridiculous. Have installed and uninstalled several times without luck. I wonder if it's a manufacturers defect as the cable and usb pc ports work with other devices and there should be no question of pc and printer compatibility as the pc is a dell studio 540 with vista home premium. Has anybody even got a working solution from dell?
  • 7 Answers
SOURCE: Communication Error DELL 926 AIO Printer
Follow these steps in order to resolve the issue:
Stop the Print Spooler Service: 1) Click Start. 2) Type ‘cmd’ in the Start Search box.Search results should appear. 3) Right-click on ‘cmd’ in the search results, and select Run as Administrator.The command window will appear.4) Type ‘net stop spooler’ into the command window and press <ENTER>.The Print Spooler service should now be stopped.
Delete the Printer Drivers: .
1) Click Start.
2) In the Start Search box, type ‘C:WindowsSystem32SpoolDriversw32x86’ and press <ENTER>.
3) Delete all the files and folders in this directory.
NOTE: If the folder will not delete, rename folder to w32x86.old.
Remove the Dell printer software:
1) Click Start.
2) Click Control Panel.
3) Click Programs.
4) Click Programs and Features.
5) Click the software related to the attached Dell printer to highlight it.
6) Click Uninstall/Change.
7) Follow through the prompts in order to remove the software.
8) Restart the computer.
At this point, the user should install the latest printer software from http://support.dell.com and be able to print successfully.
Posted on Dec 24, 2008
  • 7 Answers
SOURCE: Dell 946 will not print after one print
1) Click Start.
1) Click Start.
3) Click Programs.
Found on another forum. For 926 this worked great.
1. Go to Control Panel - Printers : Delete 926 printer
2. Go to Control Panel - Programs and Features : Uninstall All Dell 926 related software. There should be 3 programs. (When prompted to restart, respond to wait.
3. Rename Folder C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32x86 to W32X86OLD
4. Now restart your computer
5. Reinstall 926 Software.
This worked terrific for me.
Posted on Feb 05, 2009
  • 85 Answers
SOURCE: Dell Color Printer 725 - Communication Not Available
I have seen that in most of the cases (with lexmark and dell printers) it is fixed by reinstalling the printer software. Be sure that you completely remove the older drivers using the cd or using add/remove programs.
Posted on Jul 29, 2009
SOURCE: Error Message "Communication Not Available
I have a dell i810 and a HP dv6 laptop running windows 7 64. Ever since i upgraded from vista I cannot get my printer to work. The scanner works just fine however, whenever i try and print something the error "could not communicate with printer" appears and nothing prints. There is no avalible patch for this printer. Under the Devices and Printers tab on the start menu i right clicked all the printers and removed them all. I have tried reinstalling and still the problem persists.? anything else guys?
Posted on Mar 01, 2010
I have misplaced the cd to install V305/V305w All In One Printer to my laptop. Is it possible to install it without the cd?
Yes, go to this site, select your operating system and then download file Dell-driver and install it.
If my answer helped you, please take time to rate it :)
Sep 06, 2011 | Dell V305w All-In-One R840635AU InkJet...
My Dell V305 only prints occassionally. An error
I used to have a Dell all-in-one and had same problem.
I asked Dell for new installation disc and re-installed it and that seemed to to solve the problem.
Feb 07, 2010 | Dell V305w All-In-One R840635AU InkJet...
I have just installed quickcam express (bought several years ago) and used it to communicate via skype. For audio I am using creative communications headset. It all worked fine for several hours, but then...
Right click on my Computer -select Properties-select Hardware- device Manager-right click on the sound icon and there is drop down list then right click on them one by one and uninstall any uninstallable and restart the computer
OR try to upgrade to window XP pro
Or
control panel- select systems and right click on the sound icon and there is drop down list then right click on them one by one and uninstall any uninstallable and restart the computer
Jan 17, 2010 | Logitech QuickCam Express Web Camera
Dell V305 won't print
Try changing the USB/LPT cable. If does not work, circuit board problem - circuit joint breakage - communication will be a problem.
Jul 09, 2009 | Dell V305w All-In-One R840635AU InkJet...
Dell Inspirion 530 won't communicate with Dell V305 printer
The problem could be because of ONE out of FIVE problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Jun 26, 2009 | Dell V305w All-In-One R840635AU InkJet...
X4530 "communication not available" with laptop
I already experience it ..it becuase of the driver..I think you have 2 or more printer driver installed on your computer right??
you need to uninstall all exisiting driver and install again the printer driver...
and then..
after installing the driver
go to >programs
>printer and faxes
right click the printer icon ..
select used printer as default printer..
and right again..and select >use printer online..
Thank you for using FIXYA..
please a rate ..if it solve your problem..
good luck.
and thank you for choosing lexmark.
May 22, 2009 | Lexmark X4530 InkJet Printer
Dell V305 Printer No communication
wolfhaus: Did you try creating another user account 'Administrator' or 'Standard' and see if it will print from that ?. Let me know if this helps or not.
Mar 10, 2009 | Dell V305w All-In-One R840635AU InkJet...
Cannot uninstall WinFax Pro 10 even after doing manual uninstall.
For the next 12 hours you can download for free cleanse UnInstaller Pro At Giveaway of the Day. Install it and then keep attacking every bit of Symantec you find on your computer. You may have to go back several times and keep on deleting more pieces of the programs that were there but this truly works. It's the only program I found so far that could get rid of WinFax Pro including the stuff provided by Norton. Good luck
Jul 02, 2008 | Symantec WinFax Pro for PC
Dell V305w All-In-One R840635AU InkJet Printer Logo
109 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
