Question about Kodak Carousel 4400 Slide Projector
The first slide advanced and then a black piece came across the lens and didn't retract. what do we do?
    President:
  • Kodak Master
  • 412 Answers
These projectors are equipped with a "dark shutter", which stays closed unless it detects a slide in the "gate" (projection path). With the projector on, try GENTLY inserting a pencil on the movable levers that hold the slide vertical in the gate. If the "dark shutter" does not open, then chances are the lever that "trips" it open has been bent or somehow moved out of position.
I recommend you contact a factory-trained repair dealer.
Posted on Dec 30, 2010
I replaced the bulb, works fine but now there is no light projection to view slides what do I need to replace?
It definitely has a lens in it then? Kids take them out to play with them and they are pretty useful as a magnifying glass.
If the projection bulb works and there is a lens in it, the only thing it can be is the shutter that comes across the lens to blackout the screen as the slide is changing. As the carousel starts to move, the shutter comes across, the old slide is removed, the new one inserted and then the shutter retracts to show that slide on the screen.
How you get to it and what is likely to be wrong with it, I am not sure, a linkage come off it or something similar?
Jan 24, 2016 | Kodak Carousel 4600 Slide Projector
I cannot retract the lens back to my Rollei 35 se
Your question seems to be mis-categorized under slide projectors, if you are asking about Rollei 35 SE camera, the lens will only retract if you cock the shutter with the wind lever, then press the button next to the shutter release and rotate the lens a few degrees.
Nov 13, 2013 | Rollei 66 Dual Slide Projector
Sliding Lens Door Problem -- Canon S50
I had the same problem with a S50, where the lens door would not operate properly and would not open enough to cause the camera to activate. I took it apart and found that there are two small gears that keep the door on track, one had split in half and jammed the mechanism. They were white plastic, perhaps nylon? I found another S50 on ebay with broken electronics but a working lens door and took parts from it to fix my system. Getting the tiny gear in place was tricky as there are several springs used to activate the camera on switch.
Jan 18, 2009 | Canon PowerShot S50 Digital Camera
Lens will not retract and camera will not work
When the lens will not retract and camera is not functional (no picture on display, and does not shoot) , and you already tried replacing batteries with a new fresh set (ensure please) , and then restarting camera with no memory card inside, then camera is faulty.
Try an easy fix by pushing gently the lens (do not force them, just help them) while you turn off camera at same time. Try also switching the mode selector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Dec 08, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Lens cap stuck
I was messing around with this today, ended up where it seemed in was working.
Power up, let lens out, then take out batteries. Pry off silver band patiently using fingernails. Then pry off overlying black plastic piece. There are four units underneath, pay attention to how these are put on, mine popped off, but it wasn't too hard to figure out how to put back together. There are pins and holes and kind of fits like a jigsaw. Once off clean with alcohol where you can.
Put batteries back in and open and close a few times. This will help understand movement where pins of lens cover pieces go. When putting these back on make sure camera is in off position.
The lens cover pieces need to be put on so that the pin portion has some resistance. Move one so that it drops in then push up to get other in place. Let them come together and hold these in place.
The two smaller pieces will close the cover. Put the hole of the closer piece over the pin. Then move slightly so you can retract spring with a small instrument and subsequently engages pin on closer. Place top black piece back on, then silver.
This worked for me, hope it does you also! Good luck.
Dec 03, 2008 | Canon PowerShot A510 Digital Camera
Aug 03, 2008 | Fuji FinePix F20 Digital Camera
Lense will not extend, or if it does it retracts after a short while. Batteries appear to be OK
After talking, without any success, to your expert I tried experimenting. It seemed like the sliding lens cover was the main reason for it to behave as it did. It turned out that the lens cover had a worn track and did not always operate the lens motor switch to open it, or pressure on the cover caused the lens to retract. All it needs is a new sliding cover.
Jul 18, 2008 | Olympus Cameras
Fuji FinePix F40fd-Zoom error
Unfortunately this is one of the hardest cameras I have come across to repair. The plastic guide lugs inside the lens which keep it stable are so small that once they get damaged they are virtually impossible to repair and only a replacement part seems to rectify the problem. Source a donor camera on ebay for a cheaper option than sending to fuji. F45fd and F47fd use the same lens so these are an option for a donor if F40fd is not available.
Jun 07, 2008 | Fuji FinePix F40fd Digital Camera
Canon sliding lens cover door
I have been having the same problem. Once opened, the sliding door will not close and the lens won't retract. But I have found that if you plug the camera into a computer via a USB, the lens then retracts enabling you to close the lens cover.
I'm still trying to find a way to fix this problem, since this is a great camers and still takes fantastic pictures.
Apr 21, 2008 | Canon PowerShot S50 Digital Camera
Kodak Carousel 4400 Slide Projector Logo
162 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
