Question about LG WM1814CW Front Load Washer
STOPS WORKING ON SPIN CYCLE.
WHAT IS THE HOSE NEXT TO THE WATER PUMP FILTER USED FOR.
  • debkarcox Nov 15, 2009
    WHAT IS THE HOSE NEXT TO THE PUMP FILTER FOR
    Brigadier General:
  • 3,006 Answers
I'm unfamiliar with your exact machine, but on many other similar quality brands it's used to drain the machine in a controlled fashion before unscrewing the filter.
Without it, as soon as the filter is unscrewed the remaining water in the machine will gush out. The tubes fitted to most machines have a simple plastic bung on the end which must be removed to drain and replaced afterwards and the tube is normally long enough to be pulled out to enable drainage into a tray or bowl.
Have a towel handy as even after using the tube to drain down there will always be a small amount of sump water spillage when the filter is removed.
Posted on Nov 15, 2009
My Simpson Eziset 550 will not drain after a (normal) wash cycle. When the drain hose is lowered to the floor drain water flows heavily from the hose (gravity). When the hose is returned to the sink d
Hi Erin just read your post,I have worked on these machines alot.Now I need you to manually drain the machine of all the water. Once drained i want you to select drain and spin cycle. Now push the start button,do you hear the pump working?If you do stop the machine and select normal cycle on small water level and push the start button.The machine will then fill.Once it stops filling stop the machine and select drain an spin cycle.Does the machine pump out? Now if you do not hear the pump, could be the pump is faulty or jammed.Does the water flow very fast when you lower it to the floor? Please reply with answers to these questions and I will try my best to help you.
Jan 25, 2014 | Washing Machines
My NEC NFL855 E3 error
E3 error is discharging water problem. ie 1.the pump not working (under bra wire will stop it spinning) or 2. the discharge hose blocked or most likely 3. the pump inlet hose from the drum is blocked (with small article of cloth or coins or similar).
To Fix:
1. Open the pump filter and check if spinning during empty/spin cycle, make sure nothing jamming or twisted around impellor.
2. Check discharge hose is not crushed or kinked.
3. Lay machine on its side, access pump and remove inlet hose assembly and remove any blockage.
Jeremy
Jul 19, 2009 | Washing Machines
Blocked filters/dodgy pump?
The problem you are having could simply be the inlet valve.
The inlet hose is attached to the inlet valve on the machine. Where it screws on that is.
You can get a valve from an appliance parts shop and they are inexpensive.
Jun 18, 2009 | Hoover HTC243 Top Load Washer
Stopped working mid cycle. The timer still counts down but does not fill, agitate, spin, drain. And before it stopped, the water that was draining out smelled really bad.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 30, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Washing machine stops mid cycle and lights start flashing
Drain the water by lowering the hose into a bucket or something and then try it on spin, if it spins o/k then you probably have blocked pump or filter.
The filter is located in the large black hose that is fastened to the bottom of the drum, remove and clean.
Hopefully this will solve the problem.
Plz rate this solution.
Thanks.
Dec 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Kenmore Elite
First if you have a wet vac pull the drain hose out of the drain spout and use the vac to pull the water out of the washer through the drain hose.If not you will need a pair of radiator hose clamps from the auto parts store. Pull the screws from the lower panel at the front of the washer and remove it.in side you will see a rubber hose coming down from the tub to the drain pump. Put the radiator hose clamp there if you didn't have a shop vac.On the front of the pump is a round part with a handle turn that and remove the pump filter .Clean any foreign objects out of the pump and look inside the pump to make sure no impeller blades are broken if any are you will have to replace the pump. put the filter back in and tighten it. If you had to use the hose clamp remove it now.reassemble and don't forget to give the tech his four boxes if this fixes it
May 24, 2008 | Kenmore Elite 45986 Front Load Washer
GE Top load washing machine stop and stars during spin cycle
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
Mar 31, 2008 | GE WDSR2080D Top Load Washer
Draining, spinning?
check the filter as a matter of course, i bet there is something blocking the pump/filter flow.
Jan 06, 2008 | GE WSXH208A Front Load Washer
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 24, 2007 | Hotpoint WF430 Front Load Washer
LG WM1814CW Front Load Washer Logo
191 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
