Question about LG WM1814CW Front Load Washer
SOURCE: LG WM2032HW spin cycle
I had the same problem. You most likely have a drain pump issue. For me, after getting to the drain pump, I found that the hoses leading into it were clogged with dirt. I cleaned all the hoses, and took off the drain pump itself. The impeller (the little plastic blades inside) had come off the pump shaft. I was able to clean out the impeller and pump housing and it went back on. You'll know it's all the way on because it will click into place and then it won't easilty (if at all) pull back off. After this cleaning, mine worked fine. Hope this helps.
Posted on Feb 17, 2009
SOURCE: torn door seal on front loading washer
My husband used super glue on the tear and for now the washer is not leaking.
Posted on Mar 26, 2009
SOURCE: Machine is leaking out the front door
Check door boot seal for ripping/ holes in it
Posted on Sep 28, 2009
SOURCE: How do I replace my door boot seal/door gasket on
There are 2 springs attaching the door boot. The springs are really tough but there are 2 separat tools for each spring. Use the tools to remove & install. It's tough but can be done.
Posted on Nov 10, 2009
Sep 03, 2013 | LG WM-2032H Front Load Washer
Sep 13, 2011 | LG 24 in. LDS 5811 Built-in Dishwasher
Aug 13, 2011 | Refrigerators
Jan 24, 2011 | LG WM-2277HW Front Load Washer
Sep 28, 2009 | Washing Machines
Jan 05, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Oct 30, 2008 | Frigidaire FTF530FS Front Load Washer
Aug 14, 2008 | LG WM1814CW Front Load Washer
Feb 25, 2008 | LG WM1814CW Front Load Washer
Jun 29, 2014 | LG WM1814CW Front Load Washer
Jun 28, 2014 | LG WM1814CW Front Load Washer
153 people viewed this question
