Question about Kenmore 22422 Top Load Washer
Inside the washing machine "tub" there is a black scummy ring at the top....can't get rid off. Seems like its a rubber ring that is disintegrated.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If you look at the section for the Agitator and Tub, you should see a part called the Tub Seal. This could be what is disintegrated.
See the following for how to remove the cabinet and Tub Ring in order to get to it.
Sears has part numbers for either the complete tub ring and gasket or just the gasket.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=0c973faf3f16f7a1164288d4e610c748
Posted on Nov 15, 2009
Black debris is coming out of the jets when you start it up. What is this and how do I get rid of it. Thanks Gord
If the tub is more than 5 years old the rubber pump impeller could be disintegration.
If the debris just seems to be dirt then fill the tub above the intake with HOT water ... then add some dish washing detergent to the water ... run the pump about 1/2 to 1 hour
Feb 25, 2011 | Whirlpool Home
Black marks on washing
This could be due to the upper bearing rubber seal getting too old and disintegrating. It
Jan 25, 2011 | Fisher and Paykel IWL12 Top Load Washer
Backimg to bath mat disintegrated in washer.
have you tried cleaning inside the rubber gromit attatched to the underneath of the drum? if its not that you might wanna try cleaning out the pump itself. may have jammed hope that helps
Feb 23, 2010 | LG WM-2277HW Front Load Washer
Black rubber deposits in wash tub
If that is the same color as the rubbber boot or ring that connects the basket with the door then the boot, it's deteriorating, maybe you are using too much detergent, any way the boot needs to be replaced
Jan 06, 2010 | Samsung SW62ASP Top Load Washer
I have a bosch classixx 1200 when i wash a load of whites there is often a small amount of dark spots of deposit on the sheets if this is wiped off when wet it rubs into the material if we wait until dry...
Yes - I get this - you have to wipe the inside of the drum rubber ring - not just throught the groves but sludge seems to collect in between the rubber ring and metal drum; you will need quite a bit of kitchen towel!
Nov 09, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Leaking door due to the wire ring that holds rubber seal
Bosch Nexxt 500 WFMC3301 Front Load Washer how
to get the metal ring back on.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to replace the metal rings.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 06, 2008 | Bosch Nexxt 500 WFMC3301 Front Load Washer
A penny fell underneath the agitator & went underneath inside the tub
remove 2 rubber plugs on each side of lid remove the screws underneath lift top up remove the plactic ring around tub top by pulling up on clips along top edge remove the spring on left attached to ring lift ring off remove agitator again lift inner tub up and out ..when reinstalling inner tub be sure it drops completely in so the center gear drops in place
Sep 07, 2008 | Fisher Paykel EcoSmart GWL15
My clothes are catching between the drum and casing(?), the drum seems to be loose. My dryer is a GE profile/prodigy
suspect front tub support/bearing ring worn remove top by removing screws under front edge of top lift top 1 screw each side of front on inside front ring attaches to front panel look for worn plastic ring and pads
May 31, 2008 | Dryers
MAYTAG Wahing machine model MAV6000AWQ
I believe your machine is equipped with a "snubber plate" under the transmission. A lot of Maytag top-loaders are. This is a white teflon ring that is used as the wash tub and transmission support and assists in dampening vibrations during the spin cycles. It's located on the inside case of the machine under your transmission. When the snubber goes bad they generally start to squeak. They cannot be lubricated and must be replaced. If you try to oil them, they will eventually disintegrate. The snubber costs less than $10 to purchase. I hope this helps.
Apr 04, 2007 | Maytag MAV3855A Top Load Washer
Kenmore 22422 Top Load Washer Logo
64 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
