Question about Fuwa Fuwa Kutsuwa Fuwa Air Compressor MA - 2500 1/8 Hp
I have a stand up pro air compressor that does not shut off when at pressure
    President:
  • 1,167 Answers
Well thats due to the pressure switch broken or faulty buddy replace it these sometimes do play up so buy one off ebay
Posted on Nov 16, 2009
Compressor has air coming out the air in take, and has air pressure in the crankcase. When shut off. I shut it off at 150psi.
home compressors should cut out at 100- 110 psi so check / replace the controller
air out of the inlet is air under pressure holding the valves open
pressure in the sump is a blocked breather for the sump possibly from excessive air pressure
remember it is not pressure that drives tools but volume flow so if you have a 10 cubic ft /min compressor but are running a tool that requires 12 cubic ft /min air then 150 psi is not the answer
a bigger capacity compressor is
Nov 06, 2016 | Air Tools & Compressors
What will cause my Kohler Command Pro 12.5 Engine on an air compressor to shut down after the tank fills instead of going to an idle. Carb is new.
Does this have the solenoid on the bottom of the carb? That is a automatic shut off device installed in the pot of the carb to shut off the gas if the carb is overflowing with gas. If the carb is new, is the solenoid? Also, is there a bleeder line for condernsation to the tank on the bottom of the air tank? If so, sometimes that is a problem. Too much water inside the air tank. I don't know if it would cause this problem though.
Sep 29, 2014 | Dayton Audio Dayton Speedaire Air...
Charge air pro model ir330e20 builds pressure to only 60 psi and will not stop running
Cbillgreene:
Your compressor is leaking air somewhere between the compressor head and the tank. With the compressor running, feel carefully around the ends of the tube that leads from the compressor head to the air tank. You will probably feel some air leaking around one end or the other. If so... remove the tube and find out which packing has failed.
Mar 09, 2013 | Craftsman Air Tools & Compressors
While using my compressor (Husky WL65004AJ) the compressor used to go on when the pressure dropped down to about 85-90 psi. Now it doesn't. The only way that I can build up the pressure again is to shut...
Hi and welcome to FixYa, I am Kelly. I tried several places too cross this model number: WL65004AJ without success. The pressure switch has 2 settings one for HIGH cutoff and one for LOW cycle on. 1/2 of your pressure switch is not functioning properly. With the proper model number I could find a source for the pressure switch for you. There are a couple of different types of presure switchs, One is a stand alone switch on the air plumbing with no external controls (under $30.00) and one is an all-in-one switch that has the on off switch and air lines connected to it that runs around $86.00. You need a pressure switch.... it is just a matter of finding out which one fits your model and replacing it.
Thanks for choosing FixYa,
Kelly
Apr 15, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Leaking air
When the Pressure switch shuts off, the little air valve in the pressure switch vents the copper line from the compressor, to blead the pressure from the compressor so it's easier to start the next time. If it continues to leak, the check valve between compressor and tank must not be holding.
Jul 16, 2010 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
My husky air compressor is suppose to shut off at at 125psi
Pressure switch may be stuck. May need to adjust pressure switch.
May 27, 2010 | Air Tools & Compressors
My PRO-SOURCE air compressor will not go over 50 psi
Your compressor has got a 'ring' problem. The rings on the pistons that compress air are leaking air by them and need to be replaced. Unless it's the 'pressure release' leaking. When it gets to 40 PSI or so, unplug it and listen for a leak. If no leak then it's the rings. inside on the piston. If you adjust the pressure switch all the way low, it might shut off near where it builds pressure to and you could at least use it some.
Sep 26, 2009 | Air Tools & Compressors
Compessor trips circuit
IT SOUNDS LIKE YOUR COMPRESSOR IS NOT UNLOADING WHEN IT SHUTS DOWN. YOU SHOULD HEAR AN AIR RELIEF SOUND TYPICALLY ON THE SIDE OF THE PRESSURE SWITCH WHEN IT SHUTS DOWN. ITS A SMALL VALVE WITH A TIRE VALVE THAT THE LEVER HITS AND RELIEVES THE PRESSURE FROM THE DISCHARGE LINE AND THE TOP OF THE PISTON.
YOUR CHECK VALVE COULD BE BAD LETTING PRESSURE BACK UP BUT IT WOULD BE BLOWING AIR OUT ALL THE TIME WHEN SHUT DOWN.
IF YOU THINK THE VALVE OR SWITCH IS WORKING AND WANT TO CHECK IT, LET THE COMPRESSOR BUILD UP AND SHUT DOWN, LISTEN FOR THE AIR RELIEF,IF IT DOESNT THEN CRACK THE DISCHARGE LINE AND SEE IF THERES ANY PRESSURE, MANUALLY RELIEVE THE PRESSURE THEN USE SOME AIR AND SEE WHAT HAPPENS. REPAIR VALVE ON THE SIDE OR CHANGE PRESSURE SWITCH $30-40.00. HOPE THIS HELPS. PLEASE REPLY. JODY
Apr 04, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Cycling compressor
The pressure switch will shut off when the set pressure is obtained. Usually about 100 to 120 lbs. If the compressor stops at lower pressure than mentioned you may try to adjust the pressure by looking under the switch cover for adjustment screw/nut.(no more than a few turns) Increase pressure by increasing spring tension. Quick cycling is usually caused by air leaking from tubing, drain valve or check valve. After compressor shuts off unplug it from the outlet and spray soapy water on all fittings and drain valve. Repair leaks and test for quick cycling, however the compressor should reach 100-120 before shutting off. Some small compressors have a thermal reset but that usually takes a few minutes to reset. Pressure switch is defective if it shuts off before setting mentioned. Enjoy
Dec 11, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air compressor leaking
The problem that you are having is caused by the in tank check valve not holding the tank pressure. Simple test is to carefully loosen air-hose that feeds air to tank and check for air leaking. Replace check valve if leaking. Generic parts may be used. Enjoy
Dec 06, 2008 | Air Tools & Compressors
Fuwa Fuwa Kutsuwa Fuwa Air Compressor  MA - 2500 1/8 Hp Logo
146 people viewed this question
Top Fuwa Fuwa Kutsuwa Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Fuwa Fuwa Kutsuwa Air Tool and Compressor Expert? Answer questions, earn points and help others
