Question about Optics
I took the main lenses out of my William Optics ZS 66 SD to clean them and now, since I put them back in ( in the right order) I cannot get it to go to pinpoint focus, I always get bloom. HELP!
  • 3,186 Answers
The lenses are out of collimation, and must be rotated either on an optical bench or using a star test.
Here is a web site that may help you:
http://www.spacealberta.com/equipment/refractor/collimate.htm
Posted on Nov 15, 2009
How do I put my foot controller back together, I took it apart because it will not turn off. My model # 66 - AA307535. Controller # 192257
more than likely, your variable resistor in the foot pedal is shot. cleaning is a low probability repair. replace the pedal assembly.
Oct 19, 2014 | Singer Sewing Machines
Coated optics tasco 302048
If its a chemical rubberized coating it gos outside, should be able to feel the difference.
Oct 02, 2013 | William Optics FLT-110 APO F/6.5 Telescope
Cleaning and lubrication
Cleaning a lens should only be done with a non-scratching cloth and tissues designed for optics; moistened with plain water or cleaning solution designed for optics. Use of paper towels, glass cleaners, ammonia, etc. can scratch and strip special optical coatings from lenses. Apply water or solution to cloth or tissue - not to optics.
Do not lubricate lenses. Lubes attract dirt and dust and can seep into the lens and gum up aperture blades and eventually cause them to stick. Nearly all lenses do NOT require lubrication. Lenses should be cleaned professionally when not working correctly.
Jan 11, 2012 | Cameras
Hey guys , after a little bit of tweaking a managed to open the monocular , cleaned the lenses, tightened the bolts , but i don't really remember the order of the lenses & their orientation. I have...
Hello, did you remove the lens from its tubes? Also did you remove the lens set rings? If you did, O boy. These lens are set to give a center line focal point in the NV tube. The adjustment on the eye piece is for the focal point on you eye. While adjustment on the large 50mm lens is to adjust the center line focal point. If you removed and of lens rings and took them out. Then the lens need to send a lens Opitic company for reclibration to the correct focal point..
Now send me a diagram on what lens you have and I will see if I can reassembly in the correct manner. stewbison
Aug 14, 2011 | Night Owl Optics Explorer NOCX3 Monocular
I took out 3 lenses but there is still one inside and it has a fingerprint on it that i would like to clean & i can't reach it because it is on the inside, don't know how it got there... &...
It is a wigit finger print. Anything that happen, does happen, could happen, will happen, happen to disappear, you can count on it that a darn wigit had something to do with. There could be more than one wigit also.
The optics on you Night Owl are Russian manufactured. So, it a Russian wigit finger print.
Now which optics lens has the finger print, viewing optic, 50mm input optics. So you need to tell me which optics and I will help you remove the lens by written instruction OK. I have a Night Owl NOCX3 setting on my work bench. stewbison
Wollensak 15x, rochester ,usa I took the lens out of the smallest tube and need to put the lenses ,washers ,spacers, back in right order from eye side to fourth lens/
No one can answer this question-- there are multiple ways that lenses can go together. You should NEVER disassemble the entire lens-- only the outside surfaces ever need cleaning.
Mar 04, 2011 | Optics
Someone took it apart to clean it and i don't think they put the parts back in the right places. i need a blow apart of the scope to put it back together right. Can you help?
This is a small 60mm refractor telescope. The main lens probably screws on the from of the telescope.
You will also have a small finder scope that mounts on top of the main tube.
Several eyepieces
and a diagonal.
You may also have a 2x barlow.
Put the diagonal into the back of the telescope, then put the eyepiece into the diagonal. That's it.
Now practice focusing on a distant object during the day time. Read my tips on my profile page, and read this:
http://www.texasastro.org/telescope.php
Jun 23, 2010 | C-Star Optics 60700 (60x700) Telescope
I cant see clearly in my telescope not matter how much i adjust the focus lines
If it is a focused image but hazy or foggy, you have to clean the optics in your telescope. If you have a focus problem but a clean image, then you are having travel limitations of your focus equipment usually rack and pinion. Wearing eyeglasses can also effect that mechanical problem and so does other added components like "Barlow Lenses" that are used to double or triple eyepiece magnifications. You might also have the lenses in the optical system not in the right order or direction when it was taken apart.
Apr 17, 2008 | Optics
Optics Logo
56 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an Optic Expert? Answer questions, earn points and help others
