Question about Sharp Aquos LC-32D40U Television
How do i put my sharp tv on video 1 or video 2 input ?
  • 405 Answers
Press input button then select input1 or input2.
Posted on Nov 15, 2009
I have a sharp lc30hv6u LCD flat screen TV I'm trying to only watch TV what cable do I need and what is the difference between inputs 1 2 & 3 thank you
You need to re-thnk how this tv works. The AVS system box that came with the TV which is at the bottom of your picture controls the inputs. So a TV antenna goes into the ANT-A in the top left corner of the back of the AVS system box. The AVS cable has to connect the TV to the AVS system. So the inputs 1 2 3 have to be all connected . I assume to watch TV you need to somehow tell the AVS system to switch the AVS to TV.
I have seen a similar system with an after market sound and video processor that switches the audio and video to the tv from many different sources.
Mar 13, 2017 | Sharp Televison & Video
Not detecting devices
test this steps and fix it. God bless you
    • 1
      Check the back of your Sharp TV for the HDMI input. These will be long, thin rectangular jacks labeled "HDMI." Most Sharp TVs will include another label on those jacks with an input number ("Input 5," "Input 6" or the like). Remember that number. It will have a bearing when you turn on the TV.
    • 2
      Connect one end of an HDMI cable to the input jack on the Sharp TV and the other end to a compatible component such as an HD DVR from your cable/satellite company or a Blu-Ray disc player. The TV won't broadcast in HD if you can't connect these devices with an HDMI cable (though it will still broadcast in standard definition using RCA cables or S-video cables).
    • Sponsored Links
    • 3
      Turn on the TV and the requisite component (Blu-Ray, DVR).
    • 4
      Press the "Input" button on your remote. A list of signal sources will appear on your screen ("Input 1," Input 2," etc.). Use the cursor to maneuver down to the input number corresponding to the HDMI outlet you just hooked up and press the "Input" button again.
    • 5
      Press the "Menu" button and maneuver the cursor to select "Option." Go to "HDMI Setup" and press "Enter." Move the cursor up or down to the desired item and hit "Enter" again. Then move the cursor from side-to-side to select the proper setting. Hit "Enable" to allow the Sharp TV to automatically recognize the HDMI signal and "Digital" to get the proper audio signal from the HDMI cable. Then hit "Enter" again.
    • 6
      Exit the menu and watch TV as normal.
Read more: http://www.ehow.com/how_4840499_turn-hdmi-input-sharp-tv.html#ixzz2a6Xat0JU
Jul 25, 2013 | Seagate 1TB GoFlex Cinema Multimedia Drive...
My tv has a audio but no video?
If your TV has features to put off the display either on the TV or on remote, change it. If not, check the input cable for any loose contacts. Try changing channel and see whether some channel is being shown. If it is shown, the problem is in the input cable connector. If you are using input from yellow, red, white RC cable through a desk top or some other device, the yellow cable might have come off while cleaning the TV or may not be tightly fit. In short, check all the inputs and let me know.
Jul 04, 2012 | Sharp Televison & Video
I have a Bose home theater system and a Sharp Aquos tv. I'm trying to hook up the Bose dvd directly to the tv. Problem - tv only has HDMI input capability and Bose does not. I purchased a HDMI convert
Hello
You haven't given any description about the converter you bought. Please send me the model number and brand name of the converter did you bought. OK.
Nov 18, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
How to hook up sharp dolby surround pro-logic model- HTDP3000 to my RCA tv I need to know exactly how to connect the wires from sharp surround sound to my RCA high definition tv
The source of your program will determine how you hook things up, and if you want to (if it's possible) route the video through the Sharp as well. Some systems have video switching, so you can run all sources through the system, and have a single video cable running to the TV.
If you are using a DVD player, typical Pro-Logic requires a red/white RCA cable from the DVD player to the amplifier unit. The video cable, either a 4-pin S-Video or a yellow composite cable, will run to the amplifier unit for switching purposes, or ditect to an input on the TV.
You can also run red/white RCAs fron the HDTV to an input on the Sharp. You likely have to set the TVs audio output to "fixed" or "external", which will disable the TVs speakers, while putting out sound to the Sharp.
Jan 06, 2011 | Sharp HT-DP3000 System
25A S2000 TV...20 years old. Worked yesterday with DTV. Snow now. Touch buttons, talked to DTV, they said call Sharp because the DTV remote didn't recognize the TV video impute. It did yesterday, so I...
Ok,I am assuming you are using a converter box on this old tv,so first try to manually put the tv on ch 3 if you are hooking it to the VHF terminals of the tv......if you are using a video input(red/wht/yel/wires) then that must be selected using the input button on the tv or the original Sharp remote
Jun 13, 2010 | Televison & Video
Hooking up T.V. to my camcorder
Does your TV have an input which would be lited as Video 1?
There should be video and audio outputs from the camcorder and if you have video and audio inputs to your TV you just need a cable and the capability to view it on your TV. If you don't have audio and video inputs to your TV you should check out the sales at the local electronics store. I hope this helps.
Dec 12, 2008 | Sharp VL-E765U Camcorder
Video Inputs for a Sharp TV Model 25EM50
video inputs for any srandard tv are rca type round yellow jack.red jack for sound,and white jack is also for sound second channel.
Jan 17, 2008 | Sharp 25R-S100 25" TV
Sharp Aquos Color Variations
Put the OPC off and check the conection for Pb signal.
Nov 13, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
54 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
