Question about Ridgid 15682 300 Complete Threader
My ridgid 300 has a problem with the motor. After 15 secs it starts to smoke. Brushes are good.
4 Suggested Answers
seanpwright
  • 2030 Answers
SOURCE: My Ridgid portable table saw is cutting out after
hmmm it sould be or it could be abad armature winding as well
Posted on Mar 31, 2010
kjhbretge
SOURCE: My ridgid WD06250 shop vac has bad motor brushes
Hi, replacements can be found at amazon, click here and take a look: WORKSHOP Vacs Suck It Up Get It Done. I hope this was helpful. Cheers
Posted on Dec 17, 2014
emissionwiz
  • 76649 Answers
SOURCE: drive gear in motor got tore up, put new gears in motor. now makes a grinding noise. teeth inside the ring gear look ok no distortion tried 2 other motors from other good working machines same problem
Not sure what your question is here other than stating what is already known, that rigid is a low cost cheaply built brand of tool.
Posted on Jan 18, 2017
Runs Rough
The noise you have is armature failure from bearing failure or shortening out from burnt/ worn brushes. It may be poling out from failed bearings/bushes or you have a short in one of the bars in the commutator bars. Have an appliance electrician check it out.
Jun 30, 2013 | Ridgid Saws
I was working with the dremel and it shut down and would not turn back on, the motor was not hot. I'm wondering if it has anything to do with the brushes in the side of the motor housing?
My dremel started doing that too. If I rubbed the sanding drum along a piece of wood, it would start up again. I think the brushes and the copper armature get glazed over with non conductive dust and possibly insulation smoke which disconnects it enough to stall out. Change the brushes to the new ones in the kit. After a year of heavy use mine slowwed down to about 300 rpm and then died. A very nice tool but I prefer the Makita which is about three times this size just because it is longer lived.
Apr 09, 2011 | Dremel 395 Variable Speed Multipro Rotary...
I have a dewalt dw364 circular saw. the motor is running slower and sparking internally. The motor also starts smoking while using. A suggestion was to replace the brushes.
I agree with replacing the brushes, and don't use it until you do, so no damage is done to the motor. If it is smoking there is some overheating. Best regards and good luck.
Dec 31, 2010 | Garden
Motor will not start on my Ridgid table saw
Check the brushes and the commutator for wear and buildup between the insulated areas of the commutator..It should be clean and not full ofcopper residue.That will make the motor click only upon triggering the starter switch
Jun 03, 2010 | Ridgid Reconditioned 10" Jobsite Portable...
How do you get to the motor for the ridgid wet dry vac model #WD 12450
the manufacture does not replace the brushes...depending hon how old it is you might be able to get the powerhead replaced. The motor is made in China. I heard of some guy cross refrencing the motor brushes at ACE hardware if you can believe it
Sep 14, 2009 | Vacuums
Moto Brushes Problem... Who could help?
where can i fine moter brushes for my ridgid 5.25 hp 16 gal. wet dry vac.
Oct 02, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Ridgid 15682 300 Complete Threader  Logo
113 people viewed this question
Top Ridgid Tools & Hardware - Others Experts
rickb63
Jerry Kramer
Jerry Kramer
Are you a Ridgid Tool and Hardware - Other Expert? Answer questions, earn points and help others
