Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Replaced lamp in magnavox 50ML8105D/17 and now I only get sound for about 10 seconds with no picture then the tv shuts off
  • 668 Answers
I would double check the install of the Lamp and also make sure the Lamp door is closed tightly and secure.
I hope this helps,
Skyassoc
Posted on Nov 15, 2009
My 50" magnavox 50ml8105d/17 making a knocking
It sounds like you have a bad color wheel. If you are handy with electronics, it is a pretty simple fix. If not, I would suggest you take your set to a qualified service center.
Apr 01, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My magnavox model 50MF23ID/37 is 4yr old. tv wont
If you hear a clicking noise that sounds like the ballast trying to power on the lamp, but nothing happens, the lamp may be faulty.
http://www.discount-merchant.com/
Here you can get your lamp that most likely needs replacing.
Mar 26, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Replaced the bulb on a 50ML8105D/17, the bulb starts to light but turns off at 5 seconds and the red led light on the front comes on.
Hi,try to reset lamp timer by unplugging tv wait 5 min and plug it back again.Check for clicking sounds it could be the ballast which is the board that powers the lamp that it could be bad.God bless you!
Oct 06, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
No picture
Pull the front cover off at the bottom. You will see a panel which has to be removed using a screw driver. Inside you will see the lamp assembly. It is a removable box. The lamp can be changed out by just changing out the connections on the new lamp. Before you pull it though try reducing your picture size to 4:3 it helped us to get a little more life out of our lamp.
Apr 07, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox model 50ML8105D/17 shuts down after only a few seconds and overheat and lamp failure lights come on , I`ve replaced the lamp , but the problem still occurs
We reduced the picture size to 4:3 and was able to get quite a bit more life out of the lamp, without it shutting down. It does take awhile to get use to. But is much better than a dust catcher
Jan 31, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Shutdown
Try cleaning the air filter and see if that solves the problem.
May 26, 2008 | Televison & Video
TV Magnavox 50ML8105D/17 Problem
I have the same problem my DLP TV would shut off after 30 minutes or less all red LED's. Solution: The fan on the lamp assembly was not turning at the proper RPM (bearing going bad) so it was going into overtemp mode. The original part number was a SUNON KDE1209ptv3 12v 1.3W I had a hard time finding one to match that spec. DIGI-KeyCorp (www.digikey.com) was able to cross reference it to a 3 lead P11034-ND part number (NMB-MAT model fba09a12L).
I Installed the fan and problem went away.
Procedure:
Remove the lamp from the lamp assembly
Remove the back panel.
From the back, slide the main circuit board to the left (loose one screw)
Remove the power interlock on the lamp assembly (2 screws)
Disconnect Lamp assembly cooling fan lead.
Remove the 4 silver slotted screws on the lamp assembly, 2 in the front and 2 in the back.
Carefully remove the lamp assembly from the rear. WATCH the Mirror.
Remove fan, cut leads and solder or **** splice on to the new fan.
Repeat steps for installation
Feb 21, 2008 | Televison & Video
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
337 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
