Question about Boating
There is a clacking noise coming from the rear of the boat. It is a Chaparral with a 260hp Alpha drive. It started suddenly and seems to be getting worse each time we drive the boat. Engine runs good and boat works ok.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
With boat on trailer put drive in gear,engine off,remove bellow cover on the lower unit and check u-joint for any slack or noise when you try to rotate prop.Does clacking happen more when you raise lower unit?
Posted on Nov 15, 2009
This sounds like the cross bearings in your drive. With the engine off and the drive down shift in to gear and lock prop by turning to left.
remove trim rams that move drive up and down. remove all 6 nuts that hold drive on to back of boat. pull drive off boat. look to see if all is dry inside no oil,water,rubber grab hold of the shaft and see if there is a lot of play at this time I say replace both cross bearings they run about $40.00 ea and pick up a new drive gasket set to reinstall drive. One more thing put your hand in the bellow hose and put your fingers in the gimbal bearing and move to make sure it moves smooth and has no play. reinstall drive and don't forget to lock prop to the left when inserting drive in to boat..
Posted on Dec 30, 2009
My ram 1500 makes loud clacking noises and it gets worse when the t-case is locked in four wheel drive hoping it's the tcase and not the front end but not sure how can I tell
I suspect that it is "U" joints or cv joints that is the problem
remove drive shafts and lock the t case in 4x4 and see it it makes the noise
refit the rear drive shaft after checking joints and if still no noise connect the front shaft. if the "U" joints checked out then it could be the joints in the drive axles at the pivot point ball
remove a hub drive plates and see if the noise is there
if it isn't then I would consider the joints in the axle shafts to be candidates for repair /replacement
it all has to do with the torque wind up when in 4x4 and any worn or failing joint will clack as it tries to work
Aug 02, 2016 | Cars & Trucks
Why is there strut and axle noise in rear?
2005 TrailBlazer Clacking and Clunking From Rear End ...
? 4:10
https://www.youtube.com/watch?v=HIA151KxImM
Mar 14, 2013 - Uploaded by sameasiteverwas122
2005 TrailBlazer Clacking and Clunking From Rear End ...Trailblazer clunking noise over bumps (the number 1 and 2 ... How To Find Suspension Noises 101 - EricTheCarGuy - Duration: 23:57. by EricTheCarGuy 1,497,067 views ... How to Install a Water Pump: 2002 - 2009 Chevrolet Trailblazer 4.2L L6 ...
Trailblazer Driveline Noises Discovered - YouTube
? 2:27
https://www.youtube.com/watch?v=GLhTUoHWdNM
Nov 4, 2013 - Uploaded by Roland Caston
the Trailblazer has developed some nasty noises. ... loose in thedifferential and the right front strut has torn through it's bushing.... How To Install Replace Front Axle Disconnect Housing 2002-09 GMC Envoy Chevy Trailblazer ... How Much Abuse Can a Trailblazer Take Part 2 : How to Replace a Rear Axle ...
Noise coming from back on trailblazer - YouTube
Jan 01, 2016 | 2002 Chevrolet TrailBlazer
Machine makes a LOUD clack clack clack while running. Seems to be coming from rear belt roller area...
It is probably the join on the belt itself as it passes the over the roller. It could be a sign that the belt is breaking.
Feb 24, 2015 | Bowflex TreadClimber TC5000
Why does my washing machine make a clacking noise during agitation...it goes clack, clack,
Hi
Clacking noise comes when either the agitator or the transmission or clutch assembly goes bad. To check which part# has gone bad you'll have to open the unit and first check the agitator. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Theres a strange noise coming from my 99 millenia's motor but seems when i accelerate it the noise goes away but wen idle the cars just clack clack clack even when driving it makes the noise unless you are...
It sounds like you have a valve or rocker issue, I would run an engine cleaner through the engine. I suggest draining 1 quart of oil, pour in the cleaner and run engine for 5 min. Let engine cool and drain the oil. Pretty much another oil change. This will hopefully clean a sticking valve if this is the issue. But I also would check for anything hitting the pulley's or fans that may have came loose. I've seen this a lot. Good Luck. It may take 2 cleanings for the engine, so don't get disappointed.
Sep 19, 2010 | 1999 Mazda Millenia
What will cause a Clacking/Clicking noise coming
It maybe a loose heatsheild on the manifold, converter, or underbody heatsheild.
Jun 03, 2010 | 2000 Jeep Grand Cherokee
Loud Clacking Noise
timeing has slipped or cam broken
Aug 24, 2009 | 2003 Ford Crown Victoria
1999 chevy blazer starts, but makes noise and no acceleration
Smoke coming out from the middle of the two rear tires right? Sound like your rear differential is out of lubricant. Leftover lubricant is probably getting burned by heat from the friction. Have your rear differential lubed up.
May 01, 2009 | 1999 Chevrolet Blazer
Clacking noise hard drive on HP Pavilion dv2700 Laptop
Laptop hard drives can be a bit louder than the new desktops and because you're closer may be more noticable. The sound from that youtube is about normal - this video is the sound of the heads crashing - mechanical drive failure. http://www.youtube.com/watch?v=LRj6dP1Pi1Q
Just to be safe - BACKUP your important data and if you don't have the install disks, make a set.
Feb 28, 2008 | HP Pavilion dv9000z Notebook
Boating Logo
150 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
