Question about Schwinn Meridian Adult 26-Inch 3-Wheel Bike
How do I attach the fenders? - Schwinn Meridian Adult 26-Inch 3-Wheel Bike
    Problem Solver:
  • 17 Answers
Um they should come with these small bolts that attach through a hole and fit on c that hole up top... How do I attach the fenders? - 53f9e8e.jpg
Posted on Nov 15, 2009
Replacing left front fender on 1994chevy g20 van
Get the replacement fender so you can tell where there at..they make some great epoxy for that now.. They should have it where they sell fenders
Jun 09, 2016 | Cars & Trucks
How can I replace passenger side fender?
Too many unknowns here. How bad is the fender damaged? Is there any damage to other parts of the body that the fender attaches to? If so, then let a body shop do it because they have the equipment necessary to straighten those body parts. If you still want to give it a go, then take out all the bolts and other fasteners that attach other things to the fender like hose clamps,plastic reservoirs etc. The inner fender well has bolts that have to be removed from the fender. The fender itself has bolts accessible from under the hood. Get them all out and any stiffener rods at the front of the fender. There are a couple of bolts on the bottom of the fender where it meets the body nearest the front door. You have to get those from underneath. Keep track of where all the bolts and fasteners go so reassembly will go smoothly.
Jan 01, 2016 | 2007 GMC Envoy
How too remoove driver side fender 2005 envoy
once you have removed the headlight assembly and remove the bolt behind the headlight assembly, continue locating the 10mm bolts attaching the fender along the top side, along the bottom in front and behind of the tire, open the drivers side front door, look into the opening between the door hinges and with a flashlight and a long extension on your ratchet you will then remove the two bolts between the fender and door, one on top and one at the bottom. you also have to remove the retaining bolts that attach the inner fender liner to the fender.
Jul 06, 2014 | 2005 GMC Envoy Xl
How do i remove the rear fender on 2012 nightster
Secure the motorcycle upright on a suitable lift and then remove the main fuse and the seat. Lift the motorcycle just sufficiently to remove pressure on the shock absorber bolts and remove the lower ones and then lift the motorcycle higher to increase clearance between the tire and the fender.THEN unplug license plate lamp connector and the right rear lighting harness connector which has a brown band on the harness near the connector and then also unplug left rear harness connector and carefully pull both rear lighting harnesses and the license plate lamp harness through the holes in the fender and free all of the harnesses from the fender harness clips and remove rear turn signal stalk nuts from under the fender on both sides. THEN loosen and remove the front fender support screw and washer and nut and then the rear fender support screw with washer and washer and nut plates if present and remove the screw and washer attaching the rear fender brace. If necessary remove license plate lamp module harness from the upper harness clips on the left side of the inner and separate the license plate bracket from the rear fender brace. THEN remove the rear fender strut covers and the attached turn signal assemblies from the fender struts and pull the turn signal harnesses through the fender holes and struts as the strut covers are taken off. THEN put suitable materials between each fender strut and fender to protect the paint. It might be best to have someone assist and hold the fender at appropriate times. THEN you can remove the seat post with its washer and screw.
Jul 04, 2014 | 2011 Harley Davidson XL 1200N Nightster
How do i remove rear fender on nightster
Secure the motorcycle upright on a suitable lift and then remove the main fuse and the seat. Lift the motorcycle just sufficiently to remove pressure on the shock absorber bolts and remove the lower ones and then lift the motorcycle higher to increase clearance between the tire and the fender.THEN unplug license plate lamp connector and the right rear lighting harness connector which has a brown band on the harness near the connector and then also unplug left rear harness connector and carefully pull both rear lighting harnesses and the license plate lamp harness through the holes in the fender and free all of the harnesses from the fender harness clips and remove rear turn signal stalk nuts from under the fender on both sides. THEN loosen and remove the front fender support screw and washer and nut and then the rear fender support screw with washer and washer and nut plates if present and remove the screw and washer attaching the rear fender brace. If necessary remove license plate lamp module harness from the upper harness clips on the left side of the inner and separate the license plate bracket from the rear fender brace. THEN remove the rear fender strut covers and the attached turn signal assemblies from the fender struts and pull the turn signal harnesses through the fender holes and struts as the strut covers are taken off. THEN put suitable materials between each fender strut and fender to protect the paint. It might be best to have someone assist and hold the fender at appropriate times. THENyou can remove the seat post with its washer and screw.
Remove front fender FLSTC
Hi Anonymous, un-plug fender tip light wires, there are 2 bolts on each side that attach the fender to the fork slider, simply remove bolts and slide fender out, squeeze the bottom of fender a little to facilitate removal. When re-installing torque fender bolts to 20 ft lbs. Good luck
Apr 09, 2014 | Harley Davidson FLSTC Heritage Softail...
How to remove front fender
Open the hood, look for the bolts that hold the fender to the frame of the car, remove all of those. Then look under the fender behind the tire, remove the plastic pins holding the splash guards to the fender and remove the guards and any plastic trim attached to the fender. Look for more bolts and remove them. Remove the fender carefully.
Nov 15, 2013 | 2000 Jeep Cherokee Fender
Tour pack is loose
you should have several holes available for attaching bags. a long piece of chrome on the back fender. must have special nuts to attach assembly.
Jul 03, 2012 | 2005 Harley Davidson FLHTCUI Electra Glide...
I am looking for a diagram of the bumper assembly for a 2004 Chrysler town & country.
Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
  1. Release hood latch and open hood.
  2. Remove the headlamp assemblies.
  3. Hoist vehicle and support with safety stands.
  4. Remove the five push pin fasteners attaching bottom of fascia/air dam to radiator closure panel.
  5. Remove front wheels.
  6. Remove front wheelhouse splash shields fasteners as necessary to gain access to bolts attaching front fascia to fender.
Fig. 1 133387737
Fig. 2 133387738
  1. Remove the two bolts and two nuts attaching fascia to the front fenders (Fig. 1) and (Fig. 2).
  2. Disconnect fog lamp wire connectors, if necessary.
  3. Lower vehicle.
  4. Remove two bolts attaching the upper grille support to the headlamp mounting panel at each side of the grille.
  5. Remove bumper fascia from vehicle.
INSTALLATION
  1. Position front bumper fascia on vehicle (Fig. 1) and (Fig. 2).
  2. Install the two bolts attaching fascia to headlamp mounting panel at each side of grille.
  4. Install the two bolts and two nuts attaching fascia to the front fenders. The fascia should be flush to fender.
  5. Install front wheelhouse splash shields fasteners.
  6. Install front wheels.
  7. Connect fog lamp wire connectors, if necessary.
  8. Install the five push pin fasteners attaching bottom of fascia to radiator closure panel.
  9. Lower the vehicle.
  10. Install the headlamp assemblies.
Jan 02, 2011 | Chrysler Town & Country Cars & Trucks
Looking for location of heater fan on a 1978 pontiac firebird
  1. Disconnect the negative battery cable.
  2. Disconnect the hoses and wiring from the fender skirt.
  3. Remove all the fender skirt attaching bolts except those attaching the skirt to the radiator support.
  4. Pull out, then down, on the skirt. Place a block between the skirt and fender.
  5. Remove the blower-to-case attaching screws. Remove the blower assembly.
  6. Remove the blower wheel retaining nut and separate the motor and wheel.
  7. Reverse the procedure to install. The open end of the blower should be away from the motor. Use new sealer on the blower case flange.
May 23, 2010 | 1979 Pontiac Firebird
Schwinn Meridian Adult 26-Inch 3-Wheel Bike Logo
208 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
