Question about Panasonic Lumix DMC-LZ2 Digital Camera
Lens won't come out after dropping camera.
Hi...We have a Lumix DMC F27. It was dropped a short distance onto the wooden deck when the zoom was retracted. Now when we turn it on...the lens doesn't come out and the camera thinks the lens cover is on and the message says to remove lens cover and press button. Is it toast??? Thanks, Cherel
    President:
  • 2,761 Answers
Only lightly toasted. The drop likely damaged the lens tube (housing) or jarred the zoom mechanism off of its track. There is no safe DIY fix for either condition, but the camera can be repaired by the manufacturer or at a local camera shop. Make sure to get an estimate first -- you may need to decide if the camera is worth the cost of the repair.
Posted on Nov 15, 2009
Testimonial: "Thank you very much."
Is there a long lens for the Panasonic DMC-F27?
Camera is currently equipped with a Leica 12X zoom lens. I would like to be able to take pcs. from a greater distance than this lens permits. Can you recommend a lens that I can attache to the Panasonic DMC-F27 that will enable me to do so? Thank you!!
Apr 14, 2013 | Panasonic Lumix DMC-FZ7 Digital Camera
Zoom lever stopped working on Panasonic lumix DMC-FZ8
Does it say anything about the lever under zoom levers in your owner's manual?
Nov 07, 2012 | Panasonic Lumix DMC-FZ8 Digital Camera
Hi Camera has a black spot on screen. It is not on the photos. It does not zoom up. But stays the same size in the same spot. I think the LCD Screen must have a crack in it from the inside. Is this...
It's likely that the spot is a speck of dust that has found its way inside the camera and onto the sensor. Apparently when the lens barrel extends after the camera is turned on a small amount of suction is generated - enough to pull tiny specks of debris inside. Please refer to the following video:
https://www.youtube.com/watch?v=0nmwt0frZns
Jan 24, 2011 | Panasonic Lumix DMC F3 Digital Camera
Dropped camera which landed on zoom lens.
Have you tried manually trying to pull out the part that is pushed in?
Sep 24, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
I have a lumix DMC-F27 camera it will no longer zoom. No I not in movie mode.
Do you mean DMC-FZ7?
I own one. Assuming that the camera is working normally, then I know two settings that will cause the zoom to be fixed.
Suggestion No. 1:
If the zoom is fixed at the wide end:
1. Turn the mode dial to "P". Now turn on the camera.
2. Press "MENU SET".
3. Press the up arrow button.
4. Now, a menu item named "CONVERSION" should be highlighted. Press the right arrow button.
5. A sub-menu screen should now pop up, select and set "OFF".
Suggestion No. 2:
If the zoom is fixed at the telephoto end:
1. Follow Suggestion No.1.
Suggestion No. 3:
If none of the above solve the problem, then the lens might have been knocked slightly out of position.
~If the camera has been dropped.
~If the camera has been thumped or banged.
~If while zooming, the lens was obstructed.
The zoom motor also could have died, it costs about $50.00 U.S. at Panasonic.com.
My best advice would be to contact panasonic customer service.
Jul 19, 2008 | Cameras
Panasonic lumix dmc-fx01 won't focus
See the post for the same camera: "Buttons stopped working": there is a small 2 position switch connected to the zoom button. In my camera the zoom switch was stuck in one of the extreme positions. You have to put it back in the middle an re-assemble.
Mar 29, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Replacement lens cap for Panasonic Lumix DMC-FZ7 digital camera
Please see below for a link to the Lens Cap with String. This is an original part direct from Panasonic. Used specifically with this camera.
Lumix DMC-F27 Lens Cap with String
Mar 26, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Zoom and shutter not functioning
that is a symptom of being dropped and stuck in a mode.
it requires total dissemble of the camera to fix or replace the lens. your lucky it takes pictures at all. most cameras refuse if the lens is stuck.
Jul 28, 2006 | Panasonic Lumix DMC-LC33 Digital Camera
Panasonic Lumix DMC-LZ2 Digital Camera Logo
426 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
