Princeton APP530 monitor black screen after seconds
Before when my princeton APP530 monitor first stopped working it would just stay on for a second then go black with the green lite still on, when i turn it off then on. Now it flashes an orange alert? saying '' OUT OF RANGE'' under that it says ''60 hz/64khz'' also only for a few seconds also with the green still on.????
I had a similar problem with my hanns.g which i was advised to get a kit to change the diodes? or something which I did but it still doesnt go on.???
Working on them both today. Any help would be appreciated. Thank you
  • 78 Answers
But it is really a electronic problem the is some bad diodes and capacitors and some rewellding issuses shoud be done in your monitor
Posted on Nov 15, 2009
Monitor Goes Black
there is a blown capacitor on one of the boards inside display
Feb 09, 2013 | Princeton Digital Computers & Internet
Describe your (VL1916) 19" LCD
Did you try this monitor with another PC and already verify that the VGA cable is OK.
Common problem with Princeton monitors are due to bad DC filter capacitors in the power supply board, see example here:
http://s807.photobucket.com/albums/yy352/budm/PRINCETON/
Sep 10, 2011 | Princeton Digital VL1916 19" LCD Monitor
My Princeton monitor will show the normal screen for about one second when I push the power button, but then immediately goes off (screen is black). If I push the power button off, and then back on it does...
It more likely to have the same failure as other Princeton monitors here.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed PRINCETON monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 11, 2010 | Princeton Digital VL1916 19" LCD Monitor
Blank screen
You said it correct the fluorescent bulbs are going bad, unfourtunately the are part of the screen (panel).
to replace the panel make sure you get the exact part # from the panel inside rear and check prices online and on ebay.
Aug 03, 2009 | Princeton Digital VL2018W Monitor
Same problem
Check the Inverter card Connector which goes to pannel,Next Panel to AD card signal Cabble,..
Jul 10, 2009 | Princeton Digital VL1918 Monitor
I have a Princeton VL1918 LCD monitor. Need help
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. If you don't see any bad capacitors then the next thing would be bad CFL (backlight tubes) in the screen itself. If it is that then the monitor needs to be replaced because of the tech skills needed to replace then. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jun 29, 2009 | Princeton Digital VL1918 Monitor
Monitor isn't working...shows desktop screen for a second then goes black.
reinstall windows ur screen resolution is not accepted by monitor
Apr 26, 2009 | Computers & Internet
Microtek 997M monitor doesn't stay on...
The inverter is the most common item to fail on a LCd monitor. Capacitors usally fail the most. Are the tops of any of them popped up. If you had any shorted transistors the fuse would probably be blown. Usally labeled F1. I would replace all the capacitors first and go from there. Capacitors are cheap.
Jun 20, 2008 | Computers & Internet
PRINCETON LCD-15BLK MONITOR
Looks like one of your backlights is bad, first indication is the red or pink tint, replacement of the lamp is fairly easy. If one lamp is bad the inverter will not work. You can get a replacement lamp from Mouser electronics for about $12
Sep 27, 2007 | Princeton Digital VL180 18.1 in. Flat...
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
