Question about E-Machines eMachines Desktop PC
Emachine T5508 desktop will not power on. There
Emachine T5508 desktop will not power on. There is a light on motherboard when plugged in. 300w power supply. I've heard if power supply is bad....most likely motherboard is as well?
  • 2,973 Answers
If the light on the motherboard is lit then the power supply is sending power to the may be fine. Is there any sign of life when you power on the PC? If yes then remove the RAM DIMMS and reinsert and reboot. Remove the HDD from both ends and reconnect and reboot. Reconnect the main power connector to the motherboard and reboot. If the answer to my question is no, the you may be correct in assuming that the PSU is faulty. It may need repair or replacement. A repaired PSU may not be very dependeble hence I would recommend a new PSU.
Posted on Nov 15, 2009
  • 54 Answers
Thats not true but the fan skould be running if the power supply is working. take the power supply out and take it to best buy they can check it for you.bobg22
The only thing i know that the power supply shows 300w max. computer is about 3 years old & will no longer turn on. there is no noise to indicate that it is working or getting power
These use a standard Power Supply that you can get from almost any computer shop
Better to get one slight higher rated so maybe a 350 or 400w PSU
you can replace these yourself as the connections are pretty easy to follow and only four screws around the supply hold it in
It is a common e-machine issu so long as it has not taken out anything on the motherboard you should be fine.
I have seen the emachines pwer supply take out the main board on occasion although it is quite rare
Feb 04, 2011 | eMachines D3123 Desktop Computer With AMD...
I want to know if the power supply i have right now is 450watts can supply all the components below, or do i have to upgrade any? thanks My Specs: 4core dual-SATA2(motherboard) DVD-rom nvidia geforce...
Unless you have problems, your power-supply is totally adequate.
Probably, even a 300W power-supply would be sufficient
(one DVD-ROM, one disk-drive, one video-card).
Nov 15, 2010 | E-Machines eMachines Desktop PC
Only amber light is on when start...no green lights...
its a power problem. Your power supply is not giving enough power
Dec 08, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have a 3507 emanchines computer.When I push start button all it does is show green light clicking . Then it will stop and the white light will below will blink 7-8 times. The green light will click about...
sounds like an issue with your motherboard or something like that...try resetting the motherboard by unplugging the power, taking out the battery of the motherboard inside the computer and pressing the power button several times to drain the power. then put the battery back in, plug in the power cord and try to start it up. if it doesnt work then ur gonna have to contact emachines because ur mobo is either defective or broken...
Nov 12, 2009 | eMachines W3507 PC Desktop
Emachine T3958 wont turn on
make shure that the 4 wire plug to ther mother board from power supply is plugged in..other wise try a new power supply
Oct 09, 2009 | E-Machines eMachines Desktop PC
Nothing on my Emachines computer will turn on.
I would recommend rechecking your connection to the motherboard. All wires from the power supply to board and making sure the front panel switch connection are correct. Also, make sure the power supply is compatible to the motherboare. even though a 20-Pin ps will connect to a 24-Pin board, it still does not work. Good Luck
Franklin
C2Solutions
Aug 02, 2009 | eMachines D3415 PC Desktop
No Power
no it means its a dead motherboard.
Mar 03, 2009 | E-Machines eMachines Desktop PC
Powerbutton connection wires were disconnected from motherboard
Look in the manual there is a diagram and pin connections for each wire.
Feb 06, 2009 | E-Machines D2046 PC Desktop
Emachine T2862
have you try to test your power supply if it actually works? try 2 remove it from your pc plug the power chord on it and short the GREEN and BLACK wires using a pin or any conductor u can use. see if it turn on lights and fan turns on when you do that.
Feb 01, 2009 | E-Machines eMachines Desktop PC
Emachine 5210
Emachines used to use a poor quality power supply made by Bestec, I believe the quality is supposed to have improved in the last few years but inconsidering the number of dead Emachines that wind up in my workshop I doubt it.
The problem you have is that being a poor quality power supply there is a very high risk that it damaged the motherboard when it went out.
If you can borrow a power supply just to test with all the beter BUT be carefull some Emachines are proprietary and the main motherboard plug is not always wired in the standard way.
Check here for a replacement power supply if you can prove your motherboard to be OK.
http://www.affordablesurplus.com/
Have a look on this site for examples of standard and proprietary power supply wiring colours.
http://pinouts.ru/pin_Power.shtml
Aug 21, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
