Question about Garmin eTrex Legend GPS Receiver
NZ just changed to Topo50 tried setting my Legend to deal with this, NZTM not available used WGS84 as instructed with no luck
  • 59 Answers
Hi - does it have the User Grid function in the Position Format list? I'm sure it will. You can set up NZTM by using the numbers in this helpful NZ web site: http://www.maptoaster.com/maptoaster-topo-nz/articles/nztm/nztm.html
If you can't fit the number 10,000,000 in then use 999,999.9 - it'll be only a few metres (less than 10) out of true.
I also made a similar post on the NZ Hunting & Fishing site here: http://www.fishnhunt.co.nz/forum/YaBB.cgi?num=1257315450/7#7 If any further help needed get in touch - simply Google KiwiGPS. All the best - Tony.
Posted on Nov 21, 2009
How do I change the zone on my Soniq E32W13D-AU?
You should have got a red card with the AU and NZ customer support numbers on it. If you phone them, they will tell you how to unblock the player to make it region free.
On the Soniq QV191LC TV and DVD player, you follow these steps. It may work for your model but if it doesn't, try the support line.
1. Switch on
2. Switch to DVD mode (use Source button on remote)
3. Select DVD setup menu (press DVD button on remote)
4. Select Preferences page (use > key on remote)
5. Press '0' key 4 times on remote: the Region Code menu will appear
6. Use up and down on remote to select region (0 of course)
7. Press exit button.
You should now be region free.
Try these numbers:
AU 1300 765 663 / (61) 3 9543 5111
NZ (64) 9 2667512
If it's any help, you can download the manual here:
ftp://ftp.quatius.com.au/Manuals/E32W13D-AU.pdf
Jul 31, 2014 | Sony Playstation 3 (PS3) Console
We are trying to set up our Navigation options correctly on our Triton 500. How should we have them set up? We are in the USA, Idaho.
In the USA you would set: Lat/Long as Deg.min.sec or UTM .. Compass at True North and Datum at WGS84. This assumes that your maps were constructed at datum WGS84 which is current standard.
Jun 20, 2010 | Magellan Triton 500 Handheld GPS Receiver
Consistent error entering garmin etrex coordinate in google earth
Consistent errors are usually projection or datum related. If you are taking coordinates collected in one projection and displaying them in your GPS in another, you the points will offset. I'm not talking about the decimal degrees 00.000n 000.0000w vs 00 00 00N 00 00 00W. I'm talking about the geographic model to represent the surface of the earth. Google Earth generally uses a geographic projection with WGS 1984 or WGS84 Datum. Make sure you are using the same settings on your GPS.
Apr 09, 2010 | Garmin eTrex Legend GPS Receiver
91 acura legend will not start
Take off the hose to the throttle body and look for any obstructions. This has been know to cause performance issues similar to those described
May 07, 2009 | 1991 Acura Legend
My map on my garmine 60csx doesnt line up with the actual locations
The most common cause of consistent offset is DATUM selection. The DATUM was likely set to WGS84 at the time of recording then viewed later in NAD27, or vice versa.
Geocaching.com uses WGS84. The USGS generally uses NAD27
Also see this Garmin page. The DATUM is set under Settings | System if I recall correctly.
Oct 22, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Merlin Legend (Lucent) phone--changing vm list of extension
I do not fully understand you message but it sounds like you want to get into administrator programming of your voice mail.
I don't deal with voice mail programming. My only suggestion is to try and determine exactly which voice mail model you have and find the "administrator" or "programming" manual for the voice mail.
All manuals are available free at www.avaya.com
Apr 25, 2008 | Lucent PARTNER18 Corded Phone
Etrex legend
Have you checked if you have selected the correct Datum for your location, usually is WGS84
Apr 18, 2008 | Garmin eTrex Legend GPS Receiver
Panasonic dmr-eh57 multi-region unlock code
I sent an e-mail to Panasonic New Zealand to ask about this, and they advised:
"Panasonic NZ no longer pre set DVD recorders or players for all region multi-zones.
However, we will multi-zone for all regions on request. This needs to be done by an Authorised Service Centre, as a special service remote is used. Once delivered to one of these agents, the service company will charge the fee to Panasonic NZ."
If you're not in NZ, try contacting Panasonic in your own country. Just call up www.panasonic with your country code after eg. US = .com and NZ = .co.nz. It seems a *lot* easier than all those complicated hacks on the net. Now all I have to do is work out how to disconnect my DVD recorder again, and try to
PS. I realise this question is 11 months old by now, but I hope my response helps someone like me just cruising the internet looking for help.
Feb 11, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Navman S50 - New Zealand Unlock Code
Try www.computerdirect.co.nz they have the best deal on the map unlock codes (especially with online cash discount)
Jan 10, 2008 | RIM BlackBerry Pearl 8100
Won't give me the correct location
you should search for mapdate (kaartdatum in dutch) and select WGS84, it's a preference all geocachers use
Nov 27, 2007 | Garmin eTrex Legend GPS Receiver
Garmin eTrex Legend GPS Receiver Logo
2,167 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
