Question about Whirlpool Duet GHW9150P Front Load Washer
Washer says f 2 - Whirlpool Duet GHW9150P Front Load Washer
  • 4 Answers
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is
flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later
the F/02 error code will be displayed.
Potential Causes
Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is
running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Posted on Nov 15, 2009
What is the Danco Flat Washer 2-1/4"X3/4"X1/8" made of?
The Danco Flat Washer 2-1/4"X3/4"X1/8" ismade of neoprene rubber.
Jul 15, 2012 | Danco Flat Washer 2-1/4"X3/4"X1/8"
I'm repacing the front sway bar bushings on my '91 chevy s10 blazer 4.3 4x4, and the
When you replace the sway bar bushing you buy the kit and it should come all that you need except tools. you should have 4 bushing,2 tube looking things,4 washer things,2 long bolts. 2 flat washer,2 lock washer,2 nuts, let me know how it went
Apr 23, 2011 | 1991 Chevrolet S-10
Need tub capacity
Instructions
Things You'll Need:
* Measuring tape
1.
Measure the depth from inside the washer with a measuring tape. Start from the back of the inside of the washer towards you to the front of the washer. Measure the depth from a top loading washer from the bottom of the inside of the washer to the top. For example, a washing machine may have a depth of two feet.
2.
Measure the height inside the washer unit. The height inside the washer is from the bottom of the inside of the washer to the top of the inside of the washer for a front loading washing. The height is from one side of the inside of the washer to the other side in a top loading washer. For example, the inside of a washer may be one and a half feet, or 1.5 feet.
3.
Divide the height calculated in step 2 by two, and square it. In the example, 1.5 divided by two equals 0.75, and 0.75 to the power of 2 equals 0.5625.
4.
Multiply the number calculated in step 3 by the depth of the washing machine. In the example, 0.5625 times two equals 1.125.
5.
Multiply the number calculated in step 4 by Pi to determine the capacity. Pi is generally estimated as 3.14. In the example, 1.125 times 3.14 equals a washer capacity of 3.5325 cubic feet
Dec 21, 2010 | Washing Machines
My toilet only leaks when flushed. It seems to be coming from the connection at the tank. The tank is not cracked and a new hose from tank to shut off valve has been installed. The toilet is only 4 years...
If you have 2-part toilet, then tank is attached to bowl with 2 bolts.
Look inside tank and you can see bolts with rubber washers located on either side of flush valve.
The 2 bolts hold tank and bowl together and between tank and bowl is a washer called the spud washer.
So spud washer could be leaking ... or 2 bolts could be leaking.
1) If bolts are leaking, there is usually dripping all the time, and drips are visible on bottoms of bolts
If spud washer is leaking, then tank could leak only when tank is flushed.
2) First thing to try is tightening nuts on the 2 bolts. Nuts may be loose. Tighten nuts a few turns, and check if toilet still leaks.
3) To fix a spud washer, you usually need a new generic one from hardware store.
Newer tanks with 1.6 gallon flush have special sized spud washer.
geno_3245_105.jpgTank is upside down and spud washer is fit over flush valve
If you cannot find new spud washer, re-use old one and smear retorseal on it during re-assembly to make sure it seals. Rectoseal is good for many home plumbing repairs. More about that in a moment.
4) To take apart tank: Disconnect supply line to tank. Empty water out of tank. Remove nuts from bolts. Lift tank off. Wash out tank with hose. Make sure there is no sand or sediment left in bottom that might clog up flush holes located inside bowl after tank is re-assembled.
5) Remove old spud washer, and put new one on. Do a google-image search for 'spud washer' if you need more photos. New spud washer fits over flush valve. That's it. And then reassemble tank.
If you want to apply rectorseal to washer, put washer on as shown in photo above. Then smear-or-gawm rectorseal over area of washer that sits on bowl. Rectorseal will make sure there is no more leaking.
Nov 24, 2010 | Bemis 1200 Slow Elongated Toilet Seat,...
My clothes smell as if the washer uses recycled water.
Purchase Affresh, Place 2 Tabs into your washer and run through a cycle. This will keep your washer smelling fresh. Do this every 2 or 3 months, or you can have the boot replaced.
Sep 19, 2010 | GE WBVH6240F Front Load Washer
In originally how is the warranty .
DEWALT Pressure washers warranty is as follows:
DEWALT pressure washers model year 2007 and prior (yellow frames) have a 2 year engine warranty, 1 year all other limited warranty.
DEWALT pressure washers model year 2008 (black frames) have a 2 year all components covered warranty.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 19, 2010 | Dewalt 3700 Pressure Washer
Washer
hi thanks for the question. the cabinet has to come off.to do this. 2 screws 1 each corner of the console. remove. lift the console. 2 brass clips on top. remove. disconnect the wiring for lid switch. pull cabinet off. put washer on a block to raise it . its easier. . remove the clips that hold the pump on the motor. remove the motor. 2 screws 2 clips. replace coupling thanks the appliance doc
Oct 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Windscreen washer.
WASHER MOTOR 1. With the washer motor installed to the washer tank, fill the washer tank with washer fluid. 2. Attach the positive (+) lead from the battery to terminal 2, and negative (-) lead to terminal 1. 3. Check that the washer motor runs and washer fluid is ejected.50a9b90.gif SERVICE ADJUSTMENT PROCEDURES 1. Check the washer fluid contact point. 2. Adjust the washer fluid contact point by using a metal wire to move the washer nozzle ball.4a5c2e0.gif48e95c0.gif 3. If the amount of washer fluid is too small, check for clogged, bent or crushed washer piping. Check the chipped points too, because the tube might be crushed.
Jun 25, 2008 | Hyundai Motor 1995 Accent
Whirlpool Duet GHW9150P Front Load Washer Logo
54 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
