Question about Kohler 3386-6 Rialto Skylight Round Front Toilet
How do you adjust the float valve in a kohler one piece toilet
  • 119 Answers
You will see a metal clip on the rod that connects to the square float lightly compress the clip for more water in tank lower clip for less raise the clip if this does not work you need to service the valve
Posted on Nov 15, 2009
How do I adjust FLOAT VALVE in a Kohler San Martine toilet tank ?
On the fill valve float there will be either a plastic screw or a metal bar with a metal slide clip on it. If its a screw, use a screwdriver to turn it cw or ccw to adjust water level. If its a clip, compress the clip between your thumb and forefinger and slide it up or down along the bar to set the float level. You need to test it after adjusting. Level should be 1/2" below top of overflow tube.
Aug 23, 2014 | Home
Water level is set too high and runs over the overflow. how can i adjust the water level in the tank?
Inside the tank, on a lever arm there should be a cylindrical float that rises and lowers with the water level. Attached to the float is a float rod with a clip that can slide up and down the rod. You can adjust the water level by sliding the clip down to reduce the amount of water entering the tank. As the water fills the tank, the float rises, pushing up the float rod, which in turn pushes up the level that controls the valve allowing water to enter the toilet.
Jul 29, 2011 | Kohler K-3515-0 Memoirs Comfort Height...
How do I adjust the pressure in a Kohler pressurized flush toilet
You cannot adjust the pressure on the toilet. But you can adjust the stop setting screw at the top of the float arm. If the water is coming in too fast you can adjust the valve where the toilet water line connects to the wall water supply. Closing the valve a little will slow down the flow of water and it will take a little longer to refill the toilet water tank.
Mar 06, 2011 | Kohler - Toilet - Two-piece - Highline -...
I have a kohler model 703 # sb78drn, the toilet keeps running. i changed the flapper and now the toilet doesn't stop running. please help?
Try adjusting the float level. The float is what tells the toilet to stop filling. If the float is set too high, then water will just go down the overflow tube and never be able to get to the level it needs to turn off.
Mar 04, 2011 | Kohler Toilet - One Piece with Ingenium...
Float does not trigger valve to stop water - continues to run even though tank is full
What kind of flush valve is it? kohler.com shows a couple of different towers with their ingenium toilets. Is it a Kohler item or is it a Fluidmaster?
Usually you adjust water height by turning a threaded rod that runs up and down. See page 5 of this pdf
http://www.plumbersurplus.com/pdf/1058802_2.pdf
Jan 29, 2011 | Kohler Toilet - One Piece with Ingenium...
The tank is filling to the top of the tube. How do I lower the level in the tank?
Adjust the float attached to the fill valve. Some simply slide up and down on a racheted adjustment bar. Others screw up and down for adjustment. Flush after each adjustment until the proper fill level is acheived. Make sure there is still a sufficient amount of water at a given level to flush the toilet properly.
Dec 01, 2010 | Kohler Toilet - One Piece with Ingenium...
Kohler 81100 water fills tank area and over flows
check and adjust float level or float/arm possible set to high or fill tube damaged or has debris jamming valve opening
Apr 20, 2010 | Kallista Michael S Smith Loft One-Piece...
Water shooting out from the top valve when toliet flushed
According to the Make and Model listed in the heading there is a couple of areas on the fill valve.
  1. The coupler nut may be loose. This holds the float valve, Tighten.
  2. The 'O' ring by the coupler nut may be worn/damaged. Replace.
  3. On the other side of the float valve Assembly is a cap and underneath the cap is a seal. check this for wear or damage.
I hope this helps in what to check for a Kohler K-3467 one piece toilet. Thanks for using FIXYA. Good luck and have a great week. Jeff
Apr 07, 2010 | Kohler K-3467-55 San Raphael one-piece...
Kohler two peice toilet the water just circles and will not flush.there is plenty of water in holding tank that run through
These models need to have a flush valve flapper that has a styrofoam float on the lift chaninof the flapper. Go to hardware store or home improvement store and get a 'Korky brand toilet tank flapper with float 'ball". Cut the rubber ring piece away from the flapper and you don't need it (see cut here marks on flapper). Install flapper and adjust the float fairly close to the flapper.
When the water level drops in the tank and reaches the level of the float on the opne flapper, the flapper quickly closes causing the toilet to have a "surge" of siphon action which forces the water in the bowl to be drawn out.
Jun 29, 2009 | Kohler K-3422 - Wellworth Elongated...
Kohler 3386-6 Rialto Skylight Round Front Toilet Logo
331 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
