Question about Bosch Axxis+ WFR 2460 Front Load Washer
F:61 error code - Bosch Axxis+ WFR 2460 Front Load Washer
Rinnai R85 starts to warm then stops and blinks 61??
I went to the Rinnai website and this is what I found for error code 61.
Error Code 61 Problem: Fan failure
Solution: Measure the resistance on the fan motor, check the damaged or loose wiring and connections. Make sure that the fan spins freely.
Sounds like either your fan is broken or something is keeping it from spinning freely.
Hope this helps.
Gary
Feb 24, 2015 | Rinnai R85ePLUS Tankless Water Heater
Code 61
is it a network error code.
Could mean FTP TX interruption or SMTP connection rejection
check ftp settings are correct
http://www.manualslib.com/manual/421595/Konica-Minolta-Bizhub-223.html?page=63
Could mean smtp problem check settings
http://www.manualslib.com/manual/421595/Konica-Minolta-Bizhub-223.html?page=216
Apr 21, 2014 | Konica Minolta Office Equipment & Supplies
E:61:10
The error e:61:10 signifies a stuck internal lens. Shut it off and tapping it on the side might work. If not you could have it repaired. In that case you may as well buy a new camera. Sorry.
Jan 07, 2012 | Sony Handycam DCR-SR100 Camcorder
Nsm heritage jukebox error code 61
EMAIL ME FOR THE MANUAL AND SERVICE PROGRAMME I HAVE ON DVD DISC ITS FREE philhemmings@hotmail.com
Jun 17, 2010 | Audio Players & Recorders
I have error code E:61:10. Any suggestions?
HI there error code E:61:10 means
E:61:10 Zoom operations fault Inspect the lens block zoom reset sensor
Hope you understand. Thanks & waiting for your feedback.
Mar 24, 2010 | Sony Handycam CCD-TR818 Camcorder
I have daikin air con brc1c51/61 showing error code J2.
you cannot fix this mate... you will need a fridge mechanic.. try cleaning your filters id say that's your only chance
Nov 11, 2009 | Heating & Cooling
F 61 Code
The if the "bad sound" is coming from the speaker(s) it probably needs the output ic. If it is coming from the player itself check that the fans are working. F61 is an amp error code but a non-rotating or unplugged fan will also set it off.
Feb 09, 2009 | Panasonic SC-HT920 System
Windows XP Error: category 102 event id 1003
look like a system crash.
try to go into save mode and do a scandisk
if not, remove any newly install hardware or software.
restart the laptop.
Nov 10, 2008 | Microsoft Windows XP Professional
Error code e 61
same description , the same problem:I
had a power surge and now my G.E. dryer is showing Error Code 61. How do I reset it? I have turned the breaker off and on but this doesn't fix it.
I am JD and my e-mail is : averescribe@hotmail.com
Thank you all¡
Feb 02, 2008 | GE DCVH515GF Gas Dryer
Bosch Axxis+ WFR 2460 Front Load Washer Logo
684 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
