Question about Blue Rhino Round Table Top Outdoor Heater 62900
Our outdoor table heater will start but will go out, It doesnt seem to catch- any reason why?
  • 561 Answers
Ensure you have enough gas in the tank as the gas gets low this way happen.
ensure gas tank is full switched on.
ensure you keep the control knob in long enough to overide the blow out cut off.
anything else may need specialist attention.
Posted on Nov 15, 2009
Can you run your heater without a roll out switch?
The roll out switch is a safety switch. It is there for safety. The purpose of the switch is to cut the gas off if there is flame or excessive heat low in the heater as found when the heat cant exscape out the top. Many reasons for a roll out failure if you are tripping the roll out it is always a symptom of a larger problem.
Low gas pressure or lack of combustable air causes soot in the heater like that of a chimney. This will restrict the air flow through the heater. A spider web in the gas oriface or burner can cause a roll out flame to hit the roll out fuse. Indoor applications can easily be an issue with the exaust venting or fresh air supply. Outdoor applications it could be a wind down draft through the heater. Whatever the reason it is tripping the roll out fuse, by bypassing it you are allowing the gas and burn to continue in an unsafe condition which mean larger problems will arise possibly even the heater catching fire.
Jun 24, 2014 | Rheem Pool & Spa
My Sunjoy L-PH007PSS-B wont stay lit.
Blocked pilot too small needs cleaning , or clean end of thermocouple ,or replace thermocouple
Nov 02, 2012 | Uniflame Table Top Outdoor Patio Heaters -...
Our Outdoor Table Top Heater has been working well for 2-3 years. This season I am not able to accomplish lighting the flame. Seems to have no spark.
Being outside does corrode the contacts and other parts. connections may no longer be good in the starter circuits. Find it fix er.
Feb 05, 2011 | Garden
Started overheating one day when idling, but hit the gas and temp went back down. now overheats within 5 minutes and doesnt go back down. coolant seems to disappear slowly, coolant in radiator is bubbly,...
Sounds like you have a leak somewhere. A good place to check first is the heater core. It is on the passenger side under the dash. Check the floor carpet and under the carpet if it is wet or any signs of antifreeze. If so than your heater core is leaking, and since you don't have heat it is of course broken. This could also the the reason why you have bubbly coolant, with air leaking into the system.
I would start with that.
Good Luck! :)
Nov 04, 2010 | BMW 325 Cars & Trucks
The heater will not stay lit unless you hold the button in. Thanks, Susan
Try cleaning the thermo coupling, sometimes soot will cover this and it cannot detect a flame, light abrasive sandpaper will work. ( The thermo coupling is what the pilot flame touches
Jan 04, 2010 | Stainless Patio Heater - Steel Outdoor...
Electric start doesnt seem to catch and turnover
bad starter. while cranking tap the strater litely witha hammer
Dec 25, 2008 | Garden
Blue Rhino Round Table Top Outdoor Heater 62900 Logo
87 people viewed this question
Top Blue Rhino Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Blue Rhino Pool and Spa Expert? Answer questions, earn points and help others
