Question about Philips TV Tuner Video Capture PCI Card - Phillips Digital (652101138177)
Using HDMI : PC - TV picture isn't clear? - Philips TV Tuner Video Capture PCI Card - Phillips Digital (652101138177)
  • 192 Answers
Check the resolution you have that port (monitor) set to. Most likely you have it set at a resolution that the TV doesn't like, or perhaps it is set at its lowest possible resolution. Just make sure it is set at whatever the highest your TV handles, 1920x1080, 1280x720, etc.
Posted on Nov 16, 2009
Testimonial: "Thankyou i realised that i had the wrong resolution settings."
I've been trying to fix the resolution settings, but it won't let me. I bought a 1080p, but it's only playing at 420i.
Posted on Feb 21, 2010
I have a new Sharp LC80LE94OX 3D TV. I cannot clear the following error message despite following all of the suggested remedies. The error messaeg reads, "HDMI settings are reset because a new HDMI device...
not sure if your display button is not functioning, try using different remote control. reset HDMI settings to defaukt then try re installing or registering your HDMI device
Mar 14, 2014 | Sharp Televison & Video
Computer wont detect hdmi1 on tv
HDMI 1 and 2 are physical sockets. If you need it on HDMI 1, plug it into the HDMI 1 socket.
Feb 27, 2014 | Computers & Internet
Pc to tv no picture hdmi
Also make certain you are using the correct source (HDMI) on your TV, and also verify your display settings (you didn't list what version of windows, etc. but you can check to make sure that windows is seeing your secondary display. Post back with more info if you want specific help for your version of windows.
Jan 27, 2012 | Panasonic Computers & Internet
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
Cannot connect my PS3 to Panasonic TV via HDMI, my PS3 will connect to other HD TVs using HDMI but not Panasonic
Does your TV work on VGA, it maybe worthwhile getting a HDMI---VGA lead and try that as it sounds like your TV isn't working, and you've tried the obvious. Do any other HDMI devices work on your TV, like DVD HD/SAT?
Apr 22, 2011 | Televison & Video
My picture is not cystal clear. Do I need a Hdmi cable with this tv or some kind of cable for a clear picture?
All HD televisions need HDMI cables for clear picture. If you don't have one, you're not utilizing HD. Opt-World has some good, low priced cables for HDMI.
Dec 01, 2010 | Element Electronics Televison & Video
I have a dell studio 1537 and i am not able to get picture when i connect my laptop to tv using a HDMI. i have tried everything possible but i cant seem to get the picture
make sure your pc is powered completely off(not a restart but a shutdown). hdmi cable should be unplugged. plug cable to tv first, then turn on tv. Now power up pc and it should recognize the tv. Use projector mode if available on your pc. do not unplug hdmi cable while pc is on or you may have to repeat process.
Mar 17, 2010 | Dell Studio 1537 Laptop
I have a 37'' Samsung LCD flaf screen tv and the picture all of a sudden is not clear. It is hooked up to directv box and the two other tv's that I have are clear. I also have a Wii hooked up to the tv and...
Try different ports. Use and HDMI cable and see if it is doing on it. If you are using a HDMI cable now hook the connection up with the component cables and see if it is doing the same thing. If it is clear on one of the other ports you have a port on your mainboard that is bad.
Feb 10, 2010 | Samsung 37 in. Flat-Panel LCD HDTV
Vizio hd L37 tv not showing a clear picture
what type of input and device are you using? what type of connection? HDMI, Component, AV? DVD player, VCR, Cable/Satellite? Using HDMI will give you the best picture and sound. Best way to test is with a blueray or DVD player using HDMI input. If your picture is still bad, change the main board.
Dec 17, 2008 | Vizio L37 Television
Using a Compaq WF1907 monitor with a Playstation3
No. HDMI transfers picture and sound, but DVI does not. You need a audio line as well.
Oct 25, 2008 | HP Compaq WF1907 Monitor
Televison & Video Logo
455 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
