Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
I dropped my Seagate Freeagent 1.5 TB drive and now my Mac won't recognize it.
SOURCE: LaCie 1 TB Hard drive won't boot
I lave lots and lots of experience with LaCie Drives (I have 6 of the 2TB models). Every, every, every time a drive fails or runs slowly, it is the power supply. I have now replaced 5. They run very hot (so does the drive), and fail pretty often. It looks like the voltage drops just a smidge, and access times seem to increase, i.e., the drive "runs slow". Then it won't boot at all, and the blue light keeps blinking. Fortunately LaCie has replacement power supplies in the store. Buy a couple extra. I am married to the LaCie drives now, or I would probably switch brands. I kind of guess that they know about this because I contacted the help desk, and he wasn't surprised. Maxtor has a nice drive, and the Calvary drive is $150 cheaper. A drive is a drive I guess. By the way, if anyone is listening, how about building a QUIET, COOL drive with and INTERNAL POWER SUPPLY? GOT IT? All the cords and power supply bricks make me crazy. It might be nice to see a stackable drive where the top of one drive mates to the bottom of another, carrying network info as well as power to the drive above. Hint, hint. We all are building systems with ungodly amounts of storage. Too bad the manufacturers aren't building drives with the durability we need.
Posted on Oct 04, 2008
SOURCE: FreeAgent Drive cannot be Modified?
I would like to use my FreeAgent 300G Drive on my Mac and I have exactly the same problem.
Posted on Dec 06, 2008
mbase213
  • 728 Answers
SOURCE: seagate freeagent drive
Hi George,
The seagate freeagent should be reconigized by windows. The question is are you adding an additional partition or do you want to create a brand new partion. I'm assuming you want to add.
You can add more space to existing primary partitions and logical drives by extending them into adjacent, contiguous unallocated space on the same disk. To extend a basic volume, it must be formatted with the NTFS ile system. You can extend a logical drive within contiguous free space in the extended partition that contains it. If you extend a logical drive beyond the free space available in the extended partition, the extended partition grows to contain the logical drive as long as the extended partition is followed by contiguous unallocated space.
  1. Open Command Prompt.
  2. Type: diskpart
  3. At the DISKPART prompt, type: list volume
    Make note of the number of the basic volume you want to extend.
  4. At the DISKPART prompt, type: select volume n
    Selects the basic volume, n, you want to extend into contiguous, empty space on the same disk.
  5. At the DISKPART prompt, type: extend [size=n] Extends the selected volume by size=n megabytes (MB).
Value Description list volume Displays a list of basic and dynamic volumes on all disks. select volume Selects the specified volume, where n is the volume number, and shifts the focus to it. If no volume is specified, the select command lists the current volume with focus. You can specify the volume by number, drive letter, or mount point path. On a basic disk, selecting a volume also gives the corresponding partition focus. extend Extends the volume with focus into next contiguous unallocated space. For basic volumes, the unallocated space must be on the same disk as, and must follow (be of higher sector offset than) the partition with focus. A dynamic simple or spanned volume can be extended to any empty space on any dynamic disk. Using this command, you can extend an existing volume into newly created space. If the partition was previously formatted with the NTFS file system, the file system is automatically extended to occupy the larger partition. No data loss occurs. If the partition was previously formatted with any file system format other than NTFS, the command fails with no change to the partition.
You cannot extend the current system or boot partitions.
size=n The amount of space, in megabytes (MB), to add to the current partition. If you do not specify a size, the disk is extended to take up all of the next contiguous unallocated space.
Notes
  • To open a command prompt, click Start, point to All Programs, point to Accessories, and then click Command Prompt.
  • You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings might also prevent you from completing this procedure.
  • To extend a basic volume, it must be formatted with the NTFS file system.
  • You can only extend a basic volume onto the same disk.
  • You can only extend a basic volume if it is followed by contiguous unallocated space.
Hope this helps!
Thanks
Mark
Posted on Jan 04, 2009
  • 58 Answers
SOURCE: My macbook pro does not recognized freeagent 1 TB. It sucks!!!!
You could contact Freeagent technical support at their website.
Posted on Jan 10, 2009
  • 265 Answers
SOURCE: USB port broken in 1TB seagate Freeagent external hard drive
Yes you can just take the hard drive out of the case, can use it with any other case, you can also just put it inside your computer and connect it to the sata cable :)
Heres a case you could use for your drive... Click Here
Please rate
Many thanks
Posted on Feb 20, 2009
My 1tb seagate hard drive is beeping and not connecting
Andre,
Try Testdisk to see if there are any issues with the drive and if necessary repair or create a new boot sector.
Chappo07
Mar 22, 2013 | Seagate Freeagent Goflex Desk 1 TB Desktop...
I just bought a Seagate 2 TB desktop drive for Mac and PC, it works on my PC but nothing happens on the MacBook
If the Seagate hard drive has been formatted on a PC in NTFS then the MAC cannot read and write to this hard drive.
To exchange data between the PC and MAC then the Seagate hard drive needs to be formatted on a PC in FAT32 not NTFS.
Dec 12, 2012 | Seagate FreeAgent GoFlex Desk 2 TB USB 20...
My Seagate 1TB FreeAgent external Harddrive is not working on my laptop which is running on XP. In Manage Hardware section this device is shoing as unknown hardware.
go here
And download for windows. You see most companies like you to download the software from their website for older operating systems for your computer to recognize it.
Thanks, Cody
Sep 11, 2012 | Seagate Freeagent Go 1 TB Hard Drive
HOW DO I TRANSFER FILES TO MY SEAGATE FREEAGENT GOFLEX 2TB
might be write protected check the settings to see that files accepted include mac files and that admin rights allow for modification
we can assume this drive was formatted for mac, right?
May 29, 2012 | Seagate 2TB FreeAgent GoFlex Home
My seagate 1 tb dropped off my table and now its making a beeping noise. i tried changing ports and unplugging it but it still wont go. help?
if it is dropped, there is a possiblity that the Hard drive lens may be damaged. Kindly consult your local pc provider for immediate repair..
Sep 03, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My mac does not recognize my seagate goflex drive anymore
Try the drive on another computer. If it is recognized there, you might be looking at a larger issue on your Mac. If it doesn't, the GoFlex's drive or boards may have failed.
Jul 07, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
My 1Tb Seagate FreeAgent Go portable drive stopped being recognized. When plugged in the lights blink but I can't see it to recognize it.
Connect it to a different computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
Oct 27, 2010 | Seagate FreeAgent Go (ST910004FAA2E1RK) 1...
Jan 08, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
587 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
