Question about Microwave Ovens
My plate does not always spin, microwave seems to be working when plate spins otherwise it just make noise but doesn't heat up. When I move plate manually it sometimes help, so I replaced electric motor but problem hasn't been solved by that anyway, I'm desperate.
  • 456 Answers
The heating issue is related to the high voltage fuse and the magnatron assembly as well as checking the high voltage cao and the protective diode if the unit has one. As for the spinning dish u neeed to make sure the voltage of the new motor is the same as the old one. otherwise u may have issues with the motor not being able to spin efficiently. Good luck.
Posted on Nov 15, 2009
My plate just cracked while microwaving popcorn
Make sure you don't put any dishes in the microwave with something like popcorn because they retain more heat and have nothing to transfer the heat too. If you mean the built in spinning plate that you set stuff on and you have an older model the fan might be broken. Something similar happened to my microwave as it is pretty old i just removed the panels and cleaned everything/blew it off with an air hose and it started working again. I'd check with the manufacturers also!
Sep 25, 2012 | Panasonic NN-T694SF Microwave Oven
Bosch hmt9666 microwave plate stopped spinning while being used? Can't seem to find replacement part. Help needed
Try www.bosch.com contact customer support and the technical department, also check www.ebay.com type make and model of the microwave oven and scroll through the list.
Jun 15, 2012 | Bosch Microwave Ovens
Hello, The microwave is not heating up. It turns
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 13, 2011 | Frigidaire FMV156DC Microwave Oven
Platter spin, Vent Works, when using the microwave
check the high voltage diode inside the unit,its connected to one leg of the high voltage capacitor and the other side to the metal shell of the unit,if this opens you don't get the high D.C. voltage necessary to operate the magnetron,be careful,the capacitor can store up to 2100 v.a.c.so discharge it first to be safe
Mar 18, 2010 | Maytag MMV4205 Microwave Oven
Microwave is not heating at all
you probably have a h.v. diode,h.v. capacitor, and the triac or magnetron is defective
Aug 04, 2009 | Microwave Ovens
Hotpoint Over the Range Microwave is LOUD
It is very likely that the motor that spins the plate is wearing out. You can find a replacement on ebay and many other sites.
Jun 06, 2009 | Hotpoint Microwave Ovens
Turntable won't spin so microwave won't heat
Is it possible to take the glass plate out, if so, please remove the glass plate, switch on the microwave for 10 secs and watch through the door to see if you can see the centre spindle turning round? Try this and get back to me please
Mar 12, 2009 | Goldstar MV-1615 Microwave Oven
Revolving plate no longer rotates . All else works, it continu;es to cook, but we need to move the items of food from time to time
Remove the plate, and check if the square shaped gear that normally spins the turntable is rotating.
If it is rotating, then replace the turntable gear.
If it is not rotating that means that the motor that spins the microwave turntable does not rotate, and must be replaced.
Mar 01, 2009 | Amana Radarange Microwave Oven
GE Spacemaker - microwave works but the inside plate doesn't spin
you have a bad turntable motor or a bad control board.. start with the motor 9 time out of 10 this is your problem.. you can pick up this part at your local parts house or order online.. look for universal part. this will be alot cheaper then the oem.. just take the screws out of bottom panel under microwave. panel will drop down. you will see little round motor about 2in' make sure unit is unplugged.
May 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
149 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
