Question about Sony SPP A1050 Cordless Phone
My handset beeps 4 times when I remove handset from base. All connections are good. Low battery light does not come on. Sometimes I will get a dial tones other times I won't. Can it be the battery even though the low battery light doesn't on?
    Sergeant:
  • 297 Answers
It can b........but first try to reset ur phone..........every thing wil b fin
Posted on Nov 16, 2009
I have the phonemate 2970 answering machine/phone and satellite extension phone. When I turn the sat phone on I get a series of beeps and the HOLD light flashes for about 6 times then shuts down. I...
1. Remove the AC adapter plug from the back of the base unit (not from the wall); leave tel cord connected.
2. While holding down the "set code" button under the cassette lid, plug the ac adapter back into the base. The screen will then display some numbers (110) etc.
3. Hold down the HANDSET keys 1 and 2 simultaneously and then press the speaker button on top within 20 seconds.
4. Press any 3 digits on the handset i.e. 1-2-3.
5. After hearing a BEEP from the handset and base, press 2 on the handset. The base should then say "twenty-five", and the handsets will beep, confirming the new security code is enabled. Press talk or speaker on handset to confirm communication.
6. The time/day stamp and remote access code will be cleared.
7. Best to do this with the answering mach turned off.
8. Restart this procedure if anything goes wrong (may hear a series of error beeps).
I saved my manual and in it I had a fax Casio sent me with these instructions (i had this prob a few times years ago). Good luck!
Jan 18, 2011 | Casio PhoneMate PMP3875BK
My uniden DSS7855 with 1 base station and 3 handsets wont connect when i dial a number and hit the talk button it tries to connect and then comes up "'out of range" much appreciated for any help...
Clear the Handset's Base Data
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
Note: This requires that the base and handset can communicate with each other.
Clear the Base Handset Data
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
Nov 12, 2010 | Uniden Lands Phones
I have a three handset 6.0 v tech. the one handset keeps beeping. What is going on?
With vtech phone (many times) a beeping handset indicates a low battery or an inability to connect to base station. check to make sure the battery is connected correctly and that the phone is setting in its docking station correctly. (remover and obstructions that would prevent correct charging) If this fails go to your local store that sells batteries for cordless phones and purchase to correct type.
Oct 13, 2010 | Vtech 5.8 Ghz Handset Cordless Phone...
Find HS doesn't work
Had sets will not beep if the battery is too low or drained of its charge. The power for the beep needs to come from a good battery charge, so if you are missing a hand set and its been out of the charge cradle for a long time, or the unit is more than 4 years old and the batteries wont charge anymore, then you can't use the find handset feature and probably can't use it to talk as well.
If you know that the batteries are good, then there are 2 other possibilities: the seek signal needs to be reset by unplugging power to the base unit for one minute and allowing the circuits to reset themselves, or the seek button is not making good contact inside and this would require someone with knowledge to open the base unit and clean or repair the button contacts. Finally, many hans sets have an on/off/standby feature. If the handset is in off position, the it isthe same as if you removed the battery and it will never beep; it must be on standby.
Oct 04, 2009 | Uniden DECT 6.0 Cordless Telephone...
Handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
Nov 17, 2007 | Xact Communication XG2200 Cordless Phone
Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Jan 27, 2007 | GE 900 MHz Phone
Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
Jan 14, 2007 | Xact Communication XG2200 Cordless Phone
Signal indicator flashes constantly
The following worked when I had what appears to be the same problem. Solution :- Remove batteries, remove power connection, wait 30 minutes, re-connect power and replace batteries then press button on base until it beeps. Both handsets started continuous beeping which eventually stopped and everything was returned to normal. Admittdly this sounds almost identical to the process used by 'versailles' above, but at least it confirms that the technical info given by the BT Helpline does work
Nov 28, 2006 | British Telecom Freestyle 2200 Trio...
BT Freestyle 2200 I am having problems obtaining a dialing tone on both of my handsets. When I press the green button for a line out it just beeps 3 times and cuts off. There is charge in both the...
hi just want to help others as desciption aint complete above
Registering a BT Freestyle 2200 handset
1. If there is a handset in the base remove it whilst you are registering the new handset.
2. Press and hold the PAGE button on the base for about 10 seconds until you hear a beep and the In Use light starts flashing.
3. On the handset to be registered, press and hold redial & CALLSd buttons together until display shows 65-.
4. Enter the base number. If this is a new handset then the base number is 1, the display shows 65-1 then PIN. which is normally 0000
5. Enter and registration starts. When the handset beeps and returns to standby registration is complete.
Nov 08, 2006 | British Telecom Freestyle 2200 Trio...
Sony SPP A1050 Cordless Phone Logo
199 people viewed this question
Top Sony Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
