Question about Car Audio & Video
I have found a Oz Audio Vector Power 15 but this is all I can find on this beast: http://www.carreview.com/mfr/oz-audio/subwoofers/PRD_173701_1808crx.aspx I need numbers to formulate a box and to determine what kind of amplifier to pump it with. I tried to find a homepage for Oz but got nothing. Can you help?
    Guru:
  • 256 Answers
On the amplifier side, I will need the wattage, and frequency of the speaker to tell you what amp you will need.
Subwoofers differ in only one way. You get an "Open Air" and a "Closed air" subwoofer, That being said, you'll have to check on your magnet which one you have to make the boxes for that sub. If it is an "Open air" Subwoofer, you should see a "wire mesh" or "grid" in the centre, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.
If it is a "Open air" sub, your boxes should be sealed with silicone, and no ports are to be cut in your box.
With "Closed air" subs, you should have 2 ports below your sub and the port sizes should be around 50mm in diameter. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require.
On a 15 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 27 liters, meaning that you will end up with a box of 16 inches high, x 16 inches wide, x 16 inches deep. Or 320mm high, x 320mm wide, x 320mm deep.
Enjoy!
Posted on Dec 02, 2009
Where can I purchase 4 oz, 6 oz and 8 oz clear glass jars with cork closures for bath salts?
http://www.uline.com/Product/AdvSearchResult.aspx?keywords=4+oz+glass+bottles&pricode=WZ500&AdKeyword=4%20oz%20glass%20bottles&AdMatchtype=p&gclid=CPGq_5L5jcMCFWgF7AodM0cAxQ&gclsrc=aw.ds Uline
Jan 12, 2015 | Blenders
How do i recone an OZ audio matrix elite subwoofer
Do a google on "speaker reconing" - you will find some services that can do this as well as companies that sell kits for you to do this.
I have not done this myself, but would recommend a service - unless you are quite gifted with your hands using tools.
May 12, 2014 | Car Audio & Video
Amp wont play
Quick test...with your Lanzar volume all the way down, connect MP3 player or other type audio source directly to the subwoofer input connection. Play audio and slowly increase volume control. If subwoofer is working using this method, reconnect and check for audio output to Lanzer connection problem, or subwoofer "settings" issues with the receiver.
Nov 11, 2013 | Lanzar VCTBS8 Vector 8-Inch Super-Slim...
Looking for software for OZ-730. Found that www.mywizard.com is no longer an accessible site.
CALL thewizardshop.net 803-736-4382 they have software and sharp organizers.The wizardshop can help you with ALL your Sharp Organizer needs.
Cords,software for Windows XP and 7. They have Sharp OZ-730,OZ-770 and YO-520. They also repair ALL Sharp organizers with a keyboard.
www.thewizardshop.net
803-736-4382
Nov 29, 2010 | Sharp Wizard OZ-730
Does any of you know how many milliliters are in an ounce?
Here is a quick conversion chart:
100 ml = 3.3 or 3.4 oz
50 ml = 1.7 oz
30 ml = 1 oz
15 ml = 1/2 oz
10 ml = 1/3 oz
7.5 ml = 1/4 oz
5 ml = 1/6 oz
3.7 ml = 1/8 oz = 1 dram
Note that all of these are approximate; strictly speaking, 1/2 oz is 14.787 ml.
A standard perfume sample is in a 1/32 oz (1 ml) vial.
Nov 23, 2010 | Health & Beauty
At a farmer's market you buy 6 3/10 pounds of red onions and 4 1/3 pounds of yellow onions.What is the total weight of the purchase?
If you don't have a calculator to help you with the division by 16, here is a list of all the decimals relating ounces to a pound:
  • 1 oz. = .0625 of a pound
  • 2 oz. = .125 of a pound
  • 3 oz. = .1875 of a pound
  • 4 oz. = .25 of a pound
  • 5 oz. = .3125 of a pound
  • 6 oz. = .375 of a pound
  • 7 oz. = .4375 of a pound
  • 8 oz. = .5 of a pound
  • 9 oz. = .5625 of a pound
  • 10 oz. = .625 of a pound
  • 11 oz. = .6875 of a pound
  • 12 oz. = .75 of a pound
  • 13 oz. = .8125 of a pound
  • 14 oz. = .875 of a pound
  • 15 oz. = .9375 of a pound
Jun 29, 2010 | Core Learning Fractions Step-By-Step...
Would a Pyramid 15" subwoofer work for my Yamaha synthasiser?
Do yourself a favor do not get anything Pyramid they are cheap for a reason and you will not get good bass response from them even in a optimal enclosure.If you want nice bass for little money go with lanzar opti 1535D sub you can pick one up for around $265 and will blow away Pyramid any day.
http://review.zdnet.com/product/subwoofers/lanzar-opti-drive-opti1535d-car-subwoofer-driver/33649420
  • Custom Tooled Die-Cast Aluminum Basket
  • COC Composite Cone
  • Jumbo Dense Foam Surround
  • 3’’ High Temperature Dual 1.2 Ohm Voice Coil
  • 100 Oz x 3 High Density Barium Ferrite Magnet
  • Power Handling: 1600 Watts RMS /3200 Watts Peak
  • Frequency Response: 30 - 500 Hz
  • Impedance: Dual 1.2 Ohm Voice Coil
  • Efficiency: 88dB
  • Includes Installation Hardware and Template
  • Packaged In a Wood
  • lanzar-opti1535d.9909657.jpg lanzar-opti1535d.3004946.jpg lanzar-opti1535d.9909658.jpg lanzar-opti1535d.1054589.jpg lanzar-opti1535d.1785277.jpg lanzar-opti1535d.9909656.jpg default.jpg
    Apr 18, 2010 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
    Car Audio
    http://www.carreview.com/mfr/cerwin-vega/speakers/PRD_112315_1805crx.aspx
    I would think the sound stage in your vehicle is up to you and most popular place would be the door panels, high or low is up to you and what might be in the way. Unless you can customize it.
    Jul 03, 2009 | Cerwin Vega IT-6.02 Car Speaker
    Specs for Ported Box for 2 12" MA AUDIO HK12X2 Subs
    Hello joseph_delac,
    MA Audio's website has the recommended box volume and port size online here. A ported enclosure needs 3.0 CuFt of internal volume and the port should be 48 sq/in and 14.5" in length. A 4X12" rectangular port would give you the recommended 48 sq/in. Using 3/4" MDF, a box 16X18X25 has an internal volume of 3.25 CuFt allowing .25 CuFt for the sub and port displacement.
    Hope this helps.
    May 13, 2009 | MA Audio HK12X2 Car Subwoofer
    Need to pick perfect amp
    I suggest to use separate amps to your sub, get a 2 channel amp for your sub and 4 channel amps for your speakers.
    Here are my Top 5
    • Lanzar -OPTI4000D
    • MA Audio- HK-4000D
    • JL Audio 1000/1V2
    • OPti 22.2 Power Amp
    • AudioBahn-A5100T
    Apr 05, 2009 | Power Acoustik FUBAR-12W Car Subwoofer
    Car Audio & Video Logo
    244 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
