Question about Ovens
My whirlpool range model#rf114px513 started
My whirlpool range model#rf114px513 started beeping and f1 came on. please tell me what i did wrong.i hit bake 350 start first. thank you
    Sergeant:
    Champion:
  • 215 Answers
You will need to press the stop /cancel button this will clear the display
Posted on Nov 15, 2009
What is error code F1
Here's a list of error codes for Whirlpool oven/range. Whirlpool Range Fault Codes
Sep 21, 2014 | Whirlpool Ovens
Our oven starts beeping and then displays a F 1 code and shuts down.
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Aug 12, 2011 | Jenn-Air Ovens
After a power outage / low current power problem this evening, my whirlpool range, Model # SF315PEKW0 started beeping annoyingly, and displayed the following code F1 E1. Also, after, the oven would not...
The "F1-E1" fault code signifies an EEPROM checksum failure within the electronic oven control. Disconnect power to the range for longer than 30 seconds. Re-apply power and observe the display for longer than a minute. If the failure remains, disconnect power and replace the electronic oven control board.
Jul 24, 2011 | Ovens
When I press bake and start it beeps and gives me a code of F1, can you please help me figure out how to fix the F1 so I can have an oven?
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Nov 25, 2010 | Whirlpool RBS305PDS Electric Single Oven
It displays F1 . Is this a fuse problem and where is the F1 fuse
HELLO THERE
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Feb 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
F1 error code, beeping
  • Disconnect power to stove
  • Gain access to the back of the clock (electronic range control or ERC).
  • Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  • Make sure everything is clear and will not short out when power is turned back on.
  • Turn power back on to stove.
  • Watch for the F1 and listen for the beep.
  • If you get the F1 and beep, replace the ERC.
  • If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    N
  • OTE: Some models incorporate the touch pad and the clock as one part.
  • Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Aug 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    Getting error F1 on digital display
    F1 Board failure Replace control board (also called ERC or clock).
    Mar 20, 2009 | Ovens
    My kenmore oven is beeping and will not stop. the display shows F-1.
    Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
    KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
    F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
    KENMORE - 911 Series (General Electric/Roper)
    F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
    KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
    F1-E0 EPROM Error - Electronic Range Control (ERC).
    F1-E1 EPROM Error - Electronic Range Control (ERC).
    F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
    F1-E3 Fuel Type Fail
    Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
    “9” for gas-If code changes again-replace Electronic Range Control (ERC).
    KENMORE - 790 Series Electronic Oven Control (Frigidaire)
    F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
    Runaway Temp = Replace Electronic Oven Control (EOC).
    Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
    Dec 16, 2008 | Ovens
    My kenmore electronic stove is having a beep with code F1 on the
    Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Ovens Logo
    62 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
