Question about Fantom Titanium USB 2.0 250GB 7200rpm 480Mbps USB 2.0 USB 2.0 External (TFDU25072FT) Hard Drive
I have a Fantom Drive Titanium External USB 2.0 Hard Disk Drive. All of a sudden the drive in gone. I tired to unplug everything & redo but nothing appears. It does not have a disk. It is a plug & play. I have Windows XP Service Pack 3 Help!!!
  • 6,831 Answers
Hello
If you turn on the drive can you feel that the drive starts spinning? Can you feel movement and see a light flickering?
Does your computer acknowledge that there is something plug in when you plug in the Drive? Does it give you a notification, or does it make a sound?
If so, then this simple setting just might fix your problem.
Just follow these steps and you should be set.
Go to:
Start
Control panel
Administrative tools
Computer management
Storage
Disc management
Now you should see your drive in the schematic below.
Right click on the drive and choose to change the drive letter and paths.
Now click on change and change the current drive letter. If there is no drive letter assigned, assign one.
However, if the drive does not spin at start up, there is something wrong with your HDD.
Hope this can be of help.
Kind regards
Andrea
Posted on Nov 15, 2009
I am using Fantom Titanium 250GB External (TFDU25072B) Hard Drive i am not able to formate it i am using Windows XP Sp2 its giving me error " unable to formate " even i am not able to formate it...
The disk-drive inside the enclosure is problematic.
Open the enclosure, to get the model-number and serial-number from the label on the disk-drive.
Then, access Fantom's web-site, to check the warranty-status of the drive. If the warranty still is valid, they will replace it, at minimal cost to you.
If the warranty has expired, purchase a new, compatible, disk-drive, and transplant it into the enclosure, to "resuscitate" your device.
Oct 30, 2010 | Fantom Titanium 250GB External...
My Fantom II Hard drive only has a red light on
Sounds like the drive has gone faulty, all you can do is take drive out of case, get USB to HDD - USB "Dongle" and hook up HDD, and see if it works on PC & USB, If YES, then Case and interface are faulty, otherwise the HDD is faulty.
May 01, 2010 | Fantom Titanium II (TFD500C16) 500 GB USB...
My Seagate External Hard Drive is playing up. I
Re-initialize and re-partition the hard drive.
Select "Zero all data" option if "Invalid node structure" or "Keys Out of Order" error is detected.
Jan 29, 2010 | Fantom Titanium II (TFD250U8) 250 GB USB...
Unrecognized FANTOM HDD volume
have you try it with another system? if no try it and if it continues then try scanning it with antivirus program installed in your system. if all this no success then get and another okay.
Nov 11, 2009 | Fantom Titanium Hard Drive
How does a external USB SATA drive dock
yes you can but whether that would make it work or not is a different story.
It depends if the hard drive is still working or not however it would test for certain whether it is working or not.
Apr 14, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
FULL fantom external usb harddrive is not acknowleged after power outage running check disk.
ACS Data Recovery specializes in Fantom hard drives, and can perform successful recoveries on any model Fantom hard drive. If you have a crashed Fantom hard drive, please call us today to get a quote: 1-800-717-8974
unless you fancy trying to connect the drive inside the unit directly to a pc by taking the box a part.
Jul 18, 2008 | Fantom Titanium Hard Drive
Drive not appearing
You formatted, but did you create a Partition? Go back to Disk Management and create a Partition on the drive. You should be able to now see it in "My Computer."
Apr 15, 2008 | Fantom Titanium Hard Drive
Drive not being recognized
Have you tried this in another PC with, say, WinXP? If it worked then it may be 1 of 2 problems:
1) Driver Issue- you may use a compatible driver and not necessarily a "Fantom" driver. WinME needs drivers for these devices unlike WinXP
2) The USB port is not giving enough power to the drive for it to run (a problem common in older PCs). I have an external USB harddisk that needs to use 2 USB ports in my old Dell laptop since 1 USB port can't supply the power it needs. The cable should have a dual-USB jack on one end, this is so you could use the power from the other USB port.
Hope this helps
Jan 20, 2008 | Fantom Titanium II (TFD500C16) 500 GB USB...
Computers & Internet Logo
154 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
