Question about Pioneer VSX-90TXV Receiver
No audio through hdmi ports - Pioneer VSX-90TXV Receiver
    Problem Solver:
  • 6 Answers
I'm sure you will find the answer on this A/V enthusiasts message board:
http://www.avsforum.com/avs-vb/showthread.php?t=845293
Posted on Nov 15, 2009
How can i connect my hp pavillion s5610y to my bravia tv
This is a bit complicated since there is no HDMI output capability to the PC, only VGA and DVI. First, check to see if the Bravia has one of its HDMI ports listed as DVI capable. If it does, it should have accompanying audio jacks (red/white) for it. What you would need to get is two different cables for interface. The first is a DVI-to HDMI cable to run from the PC DVI port to the Bravia DVI-compatible HDMI port. You cannot run the DVI to a regular HDMI port because if you do you will get only picture and no sound. DVI outputs, unlike HDMI outputs, do not carry the audio signal. A DVI-compatible HDMI port on a TV set will connect the video from the HDMI port and the audio from the reserved audio port accompanying it. The second cable you need will be a mini stereo audio plug to RCA jacks. This will connect between the PC audio out (green), and the DVI audio plugs on the set. See pictures for cables below
Once you have this done, selecting the appropriate HDMI port on the set should result in audio and video getting to the unit. If you only need the video (you are going to use the PC speakers), then you don't need the audio cable and you can use any HDMI port, but you cannot control the volume using the TV set remote. You would need to use the PC volume settings. (Just as an afterthought if the set has no DVI-compatible HDMI port).
Jan 26, 2016 | HP Computers & Internet
I have no audio on P215H LCD Monitor
The audio cord is called HDMI, it's actually audio and video, now just because the monitor you have has a HDMI port does not mean your PC has one, you need a onboard video port that is HDMI or a graph card with HDMI.
Mostly good motherboards have HDMI or cards.
***** Now, the model you posted it does not have speakers so how do you except it to have audio ?
There would be HDMI on the monitor if it had speakers.
Apr 05, 2013 | Acer P215H LCD Monitor
Harman kardon 2650 auxiliary ports 2,3,4doesn't work
if you are talking about the hdmi ports, 3 are ins and one is out, but I use the hdmi from player direct to tv, and use coax or optical connection to my receiver for the audio
Mar 23, 2013 | Harmon Kardon Harman Kardon AVR 2650 7.1...
Element tv wont see laptop
Connecting laptop VGA port to HDMI port on a TV
VGA to HDMI converter is required to connect a laptop to a TV with HDMI input. The VGA signal does not have an audio component. You need to connect an audio cable from the audio/headphone port on your laptop to the audio connector on your TV. There are HDMI converters with Audio input so you do not need to connect an audio cable to the TV. The audio is connected to the HDMI converter and then passes the audio with the video data to the HDMI cable to HDMI port on the TV. Check out these WEB site for these HDMI converters. http://www.aten.com/products/productItem.php?model_no=vc180 http://www.sybausa.com/productInfo.php?iid=1174 http://www.topbuy.com.au/tbcart/pc/Audio-VGA-to-HDMI-Video-Converter-Box-HD-HDTV1080P-p164633.htm
Mar 14, 2013 | HP Pavilion Computers & Internet
Panasonic LG plasma no audio on hdmi 1
HDMI cord may be faulty. Try the cord that works on the port that doesn't If it works then the HDMI cord is bad. If it doesn't work then the HDMI port may be bad on the TV.
Dec 29, 2012 | LG 42PC3RA 42 in. HD-Ready Plasma TV
HDMI port lost audio
If two HDMI use the other one or if box has component outs use that instead of the one HDMI that does not work.
It is also possible this is a known issue with this set and it is even possible the problem lies with the direct box----reboot it to see if it cures the issue.
Mar 31, 2012 | ViewSonic N4280P TV
Just set up RX-A700 two things seem wrong. 1. HDMI 1 won't show video if HDMI is plugged in, once plug on HDMI is removed from receiver HDMI 1 works perfectly. 2. HDMI output needs to be held tight or else...
sounds to me like a bad HDMI cable. Just replace it.
If HDMI still wont show, move to another HDMI port. But based on having to hold HDMI cable with hand to steady the connection, it is either a bad HDMI cable, or a bad HDMI port on the receiver. Good luck
Jan 23, 2011 | Yamaha RXA700 Receiver
I have an Emerson 42in flat screen lcd. It has 3 hdmi ports, a pc port, etc. What I need is an audio out port and the only audio out port is the Digital audio out. My ps3 and xbox 360 are hooked up through...
If you have a home theatre system, most receivers have a digital audio input that you can use and hook that up to the digital audtio output on your TV. I have the same TV, and this is how I am doing it.
The other option is to get a new receiver that supports HDMI, and feed you HDMI into the receiver and then use the HDMI out from the receiver to the TV.
These are about the only options you have.
Dec 09, 2010 | Audio Players & Recorders
No sound on DVR HDMI port, but does work on other HDMI port
Not all HDMI ports support Audio or they do but only one way Audio out or Audio In. If you have an optical connection you can try that.
Apr 04, 2010 | Yamaha HTR-6130 Receiver
Pioneer VSX-90TXV Receiver Logo
182 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
