Question about Canon PIXMA iP3500m InkJet Photo Printer
Paper won't feed straight - Canon PIXMA iP3500m InkJet Photo Printer
  • 2,973 Answers
The rollers may be dirty with paper dirt on them. Clean with a damp (not wet) soft cloth and allow appropriate time to dry up. And also check the small rollers that keep the paper pressed for their tension. If the tension is not equal the also the paper will be pressed more from one side and change its direction. By bending the arm of the roller you can increase.decrease the pressure on the paper. Do that too if need be.
Posted on Nov 15, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: ordinary paper doesn't always feed in straight,
    The most common cause for this problem is contamination or foreign objects inside the printer preventing the printer from feeding the paper correctly. Turn the printer off, remove the paper and flip the printer upside down and shake it. That should remove any foreign objects also try the following link for a step by step guide on how to avoid and fix paper jams. http://bit.ly/9pfCXU
    Posted on Mar 02, 2010
    SOURCE: paper not feeding into printer straight
    Firstly I would check the paper guides on the paper stand, then check the path, turn it upside down and look for debris, I once found my childs sticky sweet in mine. Then try to clean any rubber rollers.
    Posted on Oct 22, 2009
    xptareq2000
    • 1447 Answers
    SOURCE: paper feed not straight straight therefore printing an angle
    it is problem transfer roller clean it then solve your problem
    Posted on Nov 21, 2009
    printmastert
    • 3344 Answers
      Verified Fixya Pro
      SOURCE: Lexmark X85 won't feed paper. When trying to
      There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
      1. Remove the sheets of paper from the feeder.
      2. Grab a flashlight and look inside for any debris.
      3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
      4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
      5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
      6. If cartridge area is clear, close the cover.
      7. Unplug and re-plug the printer into the power outlet to reset it.
      8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
      ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
      7. Close the printer cover and check for any errors.
      8. If no error appears, reinsert the other cartridge. Close the printer cover.
      9. Replace whichever cartridge is causing the error to appear with a new cartridge.
      Posted on Aug 03, 2011
      damnor01
      • 1179 Answers
      SOURCE: Paper does not feed straight
      Do the following:
      1.) Check the paper input tray, there is a slider on the left side only that must be slid to meet your paper, in order to get it to go through the printer in a straight fashion.
      2.) At the rear of the printer there is a large access hatch. On the left side of the hatch there is a handle to open it. Pull the left handle, the hatch opens from the left and then needs to be taken out pulling leftwards as the right hand side has pins that hold it in place.
      Check his area for obstructions. Now ensure that this hatch is properly seated. The right side pins need to be pushed into the two corresponding holes and then the left side is to be pushed into the rear of the printer, it should click into position securely.
      3.) Allign the printer's ink head by using the software that came with the printer. Go to your control panel and double click the printer to access HP's options menu.
      Do this last as it is possible that the ink head is fine and the only problem is that the paper is not being fed in straight.
      Take care!
      damnor01
      Posted on Aug 26, 2011
      Paper is not feed
      When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
      Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
      Try cleaning the rollers with methylated spirits.
      Nov 28, 2011 | HP Office Equipment & Supplies
      I cant get the paper to feed without jaming is ther a way to adjust the feed
      Nov 03, 2011 | Canon Pixma iP2600 Photo InkJet Printer
      When I hit print when the paper starts to feed the pushbar paper feed does so fast causing the paper to start slightly off caqusing a paper jam.. Is there anyway to adjust the feed
      Nov 03, 2011 | Canon Pixma iP2600 InkJet Photo Printer
      A paper jam on my canon ip4800 caused the print to be misaligned. now the edges are not straight. help!
      Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
      Sep 06, 2011 | Computers & Internet
      The paper does not feed correctly so that the paper goes into the machine crooked causing a paper jam.
      Aug 27, 2011 | Canon Office Equipment & Supplies
      Printer will not feed paper straight grabs one side and pulls the paper crooked and crumples the paper
      Aug 07, 2011 | Dell 922 All-In-One InkJet Printer
      My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
      Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
      My hp officejet pro k8600 won't print straight.
      Jul 20, 2011 | HP OfficeJet Pro K8600 Printer
      I have a borrowed Casio FR 105S printing calculator. How do I load the paper?
      Make sure the paper has a straight clean edge. Feed the paper into the slot in the back - make sure the paper is straight. Paper will go in about 1/4 inch. Push the feed button and the paper should feed through the printer.
      Feb 05, 2010 | Casio HR-8TMPlus Calculator
      Printing is crooked
      if paper comes out straight, and lines in paper are not straight then there is problem wit laser unit, its not installed corrrectly, also you can check drum unit and transfer belt for correct installation.
      Apr 27, 2008 | Konica Minolta Magicolor 2530 DL Laser...
      Canon PIXMA iP3500m InkJet Photo Printer Logo
      255 people viewed this question
      old marine
      old marine
